Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 09-10-2008, 03:36 PM   #1
tbirg
Default Tight Feathering Shaft
I took the plunge at the Gathering last weekend and bought a 700(thank you Bally's Atlantic City).
I started building the bird the last night and the feathering shaft is super tight on the bearing in the blade grips. I was finally able to get the feather shaft in place(almost had to get a hammer though). But now one blade grip is moving freely but the the other is stiffer.
Anyone else having this issue? Did I get a bum feathering shaft?
tbirg is offline        Reply With Quote
Old 09-10-2008, 05:07 PM   #2
Mercuriell
Doesn't sound right - are you sure your bearings are seated absolutely square in the grips - I would have checked the bearings on the shaft before assembly make sure there's no problem there but I guess one of your bearings isn't seated quite right !
John
Mercuriell is online now        Reply With Quote
Old 09-11-2008, 08:07 AM   #3
tbirg
The bearings are not cocked....the shaft just seems to be to big.
Old 09-11-2008, 10:38 AM   #4
cbdane
The biggest issue that I had with assembly was the fact that the hole in the spacer washers was very near the diameter of the feathering shaft making them tricky to slide into place.
Something doesn't make sense about one of your grips not rotating freely. The grip rotates with the outer races of the radial bearings and should not be affected by an over-sized feather shaft that is a tight fit on the inner race. That is, unless during installation, you hammered or pressed in such a way as to damage the bearing.
If you ever have to place forces on a bearing to seat it into place and these forces are transmitted through the balls, i.e. pressing on the outer race to move the inner race along a shaft or pressing the inner race to move the outer race into a pocket, then the balls indent into the races and leave the bearing notchy and it is ruined. In a severe case, a bearing can also be forced into a mis-sized part causing the inner race to expand or the outer race to compress, leaving it tight and unable to freely rotate. However, this usually requires a mechanical press or (heaven forbid) a hammer.
Just some thoughts.
Have laser, will travel.
cbdane is offline        Reply With Quote
Old 09-11-2008, 09:24 PM   #5
Gary L
Are the thrust bearings installed correctly ?
Gary L is offline        Reply With Quote
Old 09-11-2008, 11:07 PM   #6
HeliSmith
Take it back apart. I had the same problem for me I could see which oval plastic insert thing was not as deep. Turning it over fixed it right up.
(Compass Warp 360 w/Stock Motor (17t) running from a YGE60 governed at 3200RPM by the Vbar Black, sporting MKS DS95 on cyclic and JR3500G on tail)
Proud Field Representative for the following
HeliSmith is offline        Reply With Quote
