| Register | FAQ | PM | News | HF Locator | Groups | Blogs | Calendar | Mark Forums Read |
| Finless Bob's Helifreak Tech Room Finless Bob's Helifreak Tech Room - Tips and how-To Videos |
Goals:
Trex 700E - SuziHans,V-Bar,JR8717/BLS251,X-Era 4030/3Y-460,12S Turnigy 5000 Trex 700N - 7100R/JR8717@8V/GY611 Trex 600 - Stock Motor/ESC; FP4900, Radix blades and Paddles 2xTrex 500 - 1 V-Stabi/6S, 1 Flybar/5S,GY770/DS3400G About a dozen others. |
Radio Setup:
Transmitter
Receiver
Trex 700E - SuziHans,V-Bar,JR8717/BLS251,X-Era 4030/3Y-460,12S Turnigy 5000 Trex 700N - 7100R/JR8717@8V/GY611 Trex 600 - Stock Motor/ESC; FP4900, Radix blades and Paddles 2xTrex 500 - 1 V-Stabi/6S, 1 Flybar/5S,GY770/DS3400G About a dozen others. Last edited by Finless; 10-28-2008 at 04:04 PM.. |
Operation:
Startup
Flying
Calibrating RPM Limiter
Variations:
The above setup eliminates "hot starts" that result from the Flight Mode switch. It does not prevent you from starting when the throttle stick is up. There is a mix that will prevent ALL hot starts, even throttle stick based hot starts. The cost is that the RPM limiter will not work in "Normal". To use this variant, change MIX1 as follows:
Note that throttle trim DOES contribute to the "tipover". Again, you can see this on the monitor screen. This prevents hot starts that would be caused by the trim being all the way up, or similar. Note that I personally DO NOT FLY this variant... it is for the truly paranoid!
Nice work... should be stickied IMO
Got Aim or Yahoo? Click the icons on the left and talk to me! I'm almost always around. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#6 |
Caution:
DO NOT use the RPM Limiter during break-in of your engine! It can "hide" behaviors that you should be seeing as the engine leans out and similar. Therefore, DO NOT use the above mixes (or any other form of limiter) until you have a good, working, fully broken in setup that flies on throttle curves.
#7 |
Great work! Needs a sticky fo-sho! You don't know how long I played with the mixes to try and acheive this affect.
Questions: So you're running on the rpm limiter in Norm mode but only above 25% throttle right? Are you getting the glow to lite when switching into hold from any flight mode? I will tach the head upon trying this setup but are these %'s actually what you're using? Could you hook us up with the real %'s if these are listed as examples? Also, which rates do we adjust to change the set HS's for N, IDL's 1 & 2?
Jesse T700N FBL - V-Bar w/ 3DX Head T250 Super Pro - HS-5084MG Tail Servo X9303 |
#8 | ||||
So, a "Truth Table" for the GEAR and FM switches looks like this: Code:
Gear Up Gear Down Normal Limit On, Glow Off Limit off, Glow On FM1 Limit On, Glow Off Limit off, Glow Off FM2 Limit On, Glow Off Limit off, Glow Off Also note that Switch Down always= No Limit, Up = Limit. Easy to remember. I don't like starting in hold because you have no Throttle Trim when in Hold on a DX7. Quote:
Calculations are shown in each mixer, but here's a rephrase for clarity: For Mix1, it's -x where 100-x=the rate. For Mix2, it is the same... just because of the DX7, Mix2 stays active as Mix3 kicks in, so Mix3 has to be different. Assuming you want higher headspeed in FM2, Mix3 becomes the % to add to Mix2. And, yeah, my examples are "real" for the T700.
#9 |
Team Taco Member
Hi Danal Estes, thanks for the info . I have very carefully followed your steps in setting up the mixes , but the Switch Glo goes off when you power up the heli with the gear switch in the up or down position. This was happening even before I tried the mixes. Anyone have any thoughts. I did calibrate the rev limiter and it turn on at 25% throttle. I have not used the limiter or the Switch Glo yet. Only 7 tanks throw theYS so far.
Logo 500SE Vbar, Jive100LV, BLS451, BLS251, Edge 553 T 600E, DX7,600XL, HVCC85, TT,RADIX, 9451, 401/9254, 3xFP5000 T 700 Vbar , YS91SR , Hatori SB19 , DS8717 , AR7100R , Radix 710 |
#10 | |
When you say "goes off", do you mean runs and then quits? Or, do you mean "won't stay enabled?" SGs time out after 10 seconds. Use the servo monitor screen and look at the GEAR channel. With all switches back/away, it should be at about 75% (to the right of the mid mark). Switching only the GEAR switch down should cause it to move to the left, all the way slightly past the normal endpoint, about -120%. Let me know what's happening on that screen.
