Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > BCX/CX2/CX3
BCX/CX2/CX3 Blade (eFlite) CX, CX2 and CX3 Helicopters Information and Help
Old 09-24-2008, 03:57 AM   #1
Dvor
Default Inner shaft refuses to come out
So I got the CX2 about 2 months ago and it's fantastic. It's my first helicopter and first RC experience in about 10 years. I love it so much that I decided to get the aluminum swash plate and lower rotor mount (I was having problems with swashplate separating so decided to upgrade it).
I've been scouring the web for instructions and helpful hints, and I pretty much got the idea on how to install these parts, but have been having a hell of a time. The screws holding the inner shaft retaining collar were a pain to remove as they were very tight and had adhesive holding them in place, but I was able to use pliers to loosen them. The main gear was also tough but I managed to remove that as well.
But I'm stuck now, as the inner shaft refuses to budge. It still rotates cleanly on its bearings but doesn't have even a millimeter of play and I've tried a decent amount of force trying to pull it loose (while trying not to damage it). I've tried hitting the base of it with a small plastic hammer with no luck. I've also tried loosening the screw on the "outer shaft retaining collar" thinking that might help, but it refuses to budge even using pliers.
Is there something I'm missing that's holding the shaft in place? Any help or tips would be greatly appreciated. I've attached 2 pix showing the current state of it.
ID:	63776   Click image for larger version
Dvor is offline        Reply With Quote
Old 09-24-2008, 05:57 AM   #2
iflymyhelishigh
just pull it.
iflymyhelishigh is offline        Reply With Quote
Old 09-24-2008, 07:50 AM   #3
Steve Joblin
Appologize if I am stating the obvious, but are you trying to pull out the inner shaft from the bottom of the helicopter? If so, it will never work! the inner shaft is attached to the rotor mount for the top blades... simply pull the top blade assembly from the top of the helicopter and the inner shaft should slip through.
Steve Joblin is offline        Reply With Quote
Old 09-24-2008, 12:17 PM   #4
Geese Howard
You grab the flybar(welp, the head might be better but meh) and pull it out from the top.
Helicopter Own:
Blade CX2, Blade CP Pro, Blade 400.
Geese Howard is offline        Reply With Quote
Old 09-24-2008, 02:12 PM   #5
Dvor
Yes, I understand it sounds like I'm missing the obvious because everything I've read says that the shaft should just slide out the top. But when I grab the flybar end and pull it doesn't even budge. I was wondering if perhaps the bearings at the bottom (in the picture I posted) were holding it in, but there is no resistance when I spin it, it still spins 100% freely. Oh well thanks for the replies I guess I'll keep working on it.
Old 09-24-2008, 04:21 PM   #6
Geese Howard
Remove everything from the outershaft up top before trying to remove the inner shaft.
Helicopter Own:
Old 09-24-2008, 07:01 PM   #7
railroad11
dover just remove the screws on the bottom of the gear collar on the bottom of your heli and hold on to the fly bar on top of the heli and the inner shaft will come out. with no promblem.
i have a cx heli and i just love the heli. my e-mail is down.
railroad11 is offline        Reply With Quote
Old 10-01-2008, 02:26 PM   #8
EPBDDSB
Just give it a smart rap from the bottom. There's probably just a little burr on it. It will come out.
EPBDDSB is offline        Reply With Quote
Old 10-01-2008, 03:50 PM   #9
Heli Jim
It sounds like the shaft is frozen to the inner race on one of the bearings--most likely the lower bearing.
Heli Jim
Blade 120 SR, Blade mCP X, DX6i
"If you're not flyin, you're not tryin' "
Heli Jim is offline        Reply With Quote
Old 10-03-2008, 07:00 AM   #10
flightcrazed
The first one I replaced was very hard to remove. Just give it a real good pull, it'll come out.
flightcrazed is offline        Reply With Quote
