Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > BCX/CX2/CX3
BCX/CX2/CX3 Blade (eFlite) CX, CX2 and CX3 Helicopters Information and Help
Old 09-29-2008, 10:43 PM   #1
JStilt
Default 3rd hole instead of 2nd?
so I was wondering if any one else has moved there servo arm out to the third hole. I have it in the 2nd and when flying today I was wanting more action from the swash and wasn't getting it. I decided to get tricky and go all the way out to the 4th hole but after testing it I relized I moved the arm to much causing the plastic arm on the swash to bend, so I moved it back to the 3rd hole. I will try and fly more tomorrow to see if action is any better.
JStilt is offline        Reply With Quote
Old 10-01-2008, 12:01 PM   #2
benzee1
I run mine on the outermost holes. You gotta be careful because as you move your links out, you increase chances of blade strikes. The first time I moved mine out, I was flying outside, did a fast maneuver and I heard "CLACK" and the heli dropped like a brick!
If you don't have extended shafts, I would get them. The easiest way is this product http://cgi.ebay.com/Helitek-Super-Shaft-2-0-upgrade-CX-CX2-V3-V4_W0QQitemZ270279272212QQcmdZViewItem?hash=item27 0279272212&_trkparms=72%3A1205|39%3A1|66%3A2|65%3A 12|240%3A1318&_trksid=p3911.c0.m14.
Also, if you want the heli to be more responsive, buy a set of Trex 450 weights ($), cut your flybar just behind the current weights and put the trex ones on. View my photos to see what it looks like.
HeliSimRC
Spektrum DX7, DX6i
TREX 450, Blade 400, Blade CX2
Myspace.com/heliwhore
benzee1 is offline        Reply With Quote
Old 10-01-2008, 04:28 PM   #3
JStilt
thanks for the link. I am running the rivesud V3 extended shafts but have mixed feelings about them. you have to use the stock swash becasue they lowered the lower head and the cnc swash is thicker and hits the collar on the shaft.
I got to fly for alittle bit yesterday with the links in the 3rd hole, alittle better but still not enough for my liking. I haven't had any blade strikes since installing the V3 but.........when my dad was flying it yesterday he had a blade strike, I was like what the hell. needless to say it fell about 50ft to the ground and busted it up pretty good. what i'm most upset about is that it broke my carbon flybar. I don't want to drop another $20 on a stupid flybar so I guess it's back to metal. speaking of flybar, did you cut just behind the wieghts on a stock flybar or an already short one? I have better wieghts that came with the rivesud flybar, not sure if there the same as the 450. are heavier wirghts going to give me more action?
Old 10-01-2008, 06:09 PM   #4
benzee1
I cut about 1/8" behind my stocks. A heavier weight will make the heli more stable, but less responsive. The Trex 450 weights are slightly lighter than the stock ones.
A shorter flybar will also make the heli more responsive. You can start with the weights out, then adjust them in as you want more responsiveness. Once the weights go in too far, heli will fly like crap. So they can't go in too far.
BTW, That link I gave you, you'll have to use the stock outer shaft with it.
HeliSimRC
Spektrum DX7, DX6i
Old 10-03-2008, 01:09 PM   #5
VNAMUS
I moved mine to the third hole and had a blade strike. Back to the second hole for me.
VNAMUS is offline        Reply With Quote
Old 10-03-2008, 01:15 PM   #6
benzee1
Extend your shafts. The link above is the cheapest and easiest way to do it. The company that sells it on ebay also has a kit with shaft and flybar for about $16. If you do the extended shaft and move your links out, and shorten your flybar, it'll be like a whole new heli. Very cheap and easy mods.
HeliSimRC
Spektrum DX7, DX6i
Old 10-03-2008, 11:11 PM   #7
dilipc
I bought some stuff from Rivesud - must say I'm very unhappy about the quality. They convinced me to blow up about $70 by saying their parts will keep the heli light as opposed to aluminum parts. But IMO Rivesud parts are of very poor quality. Their carbon boom is such a clumsy part to put on. Instructions are almost non-existent. Like Jstilt has said above, their other stuff is also no good.
I had to dish out another $100 and upgraded my CX2 with aluminum parts from Jamie.
dilipc is offline        Reply With Quote
Old 10-04-2008, 12:46 AM   #8
benzee1
I've heard some people like their stuff, I've heard some say it's crap. I don't really know myself though. Not gonna spend $70+ to find out. You can do homemade mods too. It's fun if you like to create stuff from scratch. I've done homemade extended inner and outer shafts. I bought the extended innershaft from ebay to see if my head wobble would go away. It didn't. I also have blade grips for another heli on my cx2. From the Venom series. Ocean rescue I think. Needed shims (washers) to make it fit. No more broken upper blades.
HeliSimRC
Spektrum DX7, DX6i
Old 10-04-2008, 01:34 AM   #9
JStilt
Im going to have to agree with everything you just said. I wish i had done more research then I did. I would have defintley gone a different rout. as far as the tail boom I can't say it's crappy because I havent had another brand to compare it too. it does vibrate alot but maybe thats normal. I would defintley like a tail boom that mounts different, the rivesud one is really woobbly were it connects.
I'm trying some new blades, some brand my LHS had. they seem pretty durable but don't have near the lift my extreme blades have. I also try this flybar mod that I read about over at RCuniverse. you basically put a carbon shaft over the metal rod and then add your wieghts. seemed like a cool idea and the guy that made this mod says his heli flys like a dream. not so much for me, add the extra mass your puching through the air plus the blades I'm trying have weak lift, it seemed like it took over 1/2 stick before lift off, plus it has weak response when it comes to lift when your already in the air. needles to say I went back to just the meatl rod. the worst part is it doesn't fly as good as it did with the carbon bar. I think I'm going to buy the goldslinger flybar and see how that works.
as far as other stuff I would like to see how it flys with the extreme tail boom, I like how it mounts and doesn't put any stress on the servo case. alot of people talk about wieght but it's not like were stunting these things. I am only doing basic flight with some FFF once in awhile.
Old 10-04-2008, 03:59 PM   #10
TowPilot
The Rivesud outer shafts prior to Version 3 bent like butter.
I like the BoomTown version of the carbon rod tail. Easy to install, stable, easy to remove to service the heli.
TowPilot is offline        Reply With Quote
Old 10-05-2008, 09:10 AM   #11
JJ's Hanger
If you shorten the flybar, put on the lighter weights and don't extend the shaft or go to the third hole will you still get better responsiveness? (I tend to take the conservative approach to things and want to avoid blade strick at higher altitudes).
JJ's Hanger is offline        Reply With Quote
Old 10-05-2008, 11:02 AM   #12
benzee1
You will get better responsiveness, but you will probably get blade strikes. What happens is when heli is moving in a particular direction and you change direction quickly, the blades flex as the copter moves and they strike each other. I understand the physics pretty well, but can't explain really well LOL.
Move your arms out and try it. I went from inner hole to middle to outer. The middle hole I used it for a day. It may be ok for you. That's one of the great things about the CX2, you can try stuff to your hearts content.
HeliSimRC
Spektrum DX7, DX6i
Old 10-05-2008, 02:17 PM   #13
JJ's Hanger
Thanks for the advice. Sounds like the reality is that extending the shaft is worth it to lessen the chance of blade strikes if I plan to modify the handling. I did have one strike already even with the stock setup. At first I didn't know why it dropped out of the sky but when I looked at the broken blades and read about strikes it made sense. I think that one was due to a little wind gust combined with a quick direction change that smacked the blades together.
Old 10-05-2008, 02:24 PM   #14
benzee1
That would do it. It'll be amplified with the arms out more.
HeliSimRC
Spektrum DX7, DX6i
Old 10-05-2008, 06:28 PM   #15
JStilt
moving the arms out deffintley makes it more sensitive. I moved mine out all the way because I want to be sensitive like my dads b400, I think having them in on the 1st or 2nd hole is better if your just learning how to fly but when you get comfortable enough move them out, it's a whole new challenge to fly.
Old 10-07-2008, 01:58 PM   #16
TowPilot
The stock blades flex VERY easily when moving the sticks.
Blades that are used with blade grips flex far less.
That is a key advantage to changing over to blade grips.
Old 10-09-2008, 01:33 AM   #17
teshreve
Even in the 3rd hole out you will bind the swash before full throw, so going any further out is pointless. The swash binds far earlier than you think and the effects are fairly big when only one set of blades binds.
1) Bindage
2) Causes rotation
3) Gyro compensates by giving less power to other set of blades
At the very least you will lose altitude. At the worst, an oscillation will occur, creating all kinds of problems such as blade strikes.
Probably the best setup is 2nd hole out with stock radio or 3rd hole with a radio that can set endpoints, such as a DX6i or DX7.
teshreve is offline        Reply With Quote
Old 10-09-2008, 02:59 AM   #18
dilipc
Endpoints? I have a DX6i (since yesterday) and would be grateful to be educated.
Old 10-09-2008, 08:47 AM   #19
Miller time
The endpoint adjustment is on the transmitter, in short it allows you to set how far the servo arm will travel when your transmitter is full throw in that direction. There should be full details on it including how to set it in your transmitter manual - I don't have that model but I do own other Spektrums and their documentation is generally well done.
What teshreveis saying is that by setting the linkage on the third hole, the servo arm will travel beyond the point where the swash is at full travel, causing it to bind. If you use a radio with adjustable endpoints you can move the linkage to the third hole then reduce your endpoint adjust for that channel so that full throw on your control stick equals a point just before the swash binds. This way you get the full potential action without the added problems cause by one set of blades meeting resistance while the other spins freely.
Miller time is offline        Reply With Quote
Old 10-09-2008, 10:47 AM   #20
benzee1
Funny, I do not have any binding on mine.
HeliSimRC
Spektrum DX7, DX6i
