Old 10-04-2008, 07:23 AM   #1
sal98
Default 450 XL CCPM Headspeed
Hi everyone, this is fresh post for me so I hope someone can help me out a little. I have the stock 420LF motor on the heli with a 14 tooth pinion. I am looking to setup the govener mode on the CC 35 ESC but wanted to know what type of headspeed I should be looking for at zero pitch? .
Someone told me that I need to go back to the 13 tooth pinion for this motor because it is not as powerful as the newer motors out there. If this is true then can anyone also give me an idea of what head speed this gearing should produce?
sal98 is offline        Reply With Quote
Old 10-04-2008, 10:08 AM   #2
pwoodyp
Assuming:
3s Lipo
3200KV Rating of the 420LF
150T Main Gear
85% Drag
Calculated headspeed
14T Pinion = 2818rpm
13T Pinion = 2617rpm
12T Pinion = 2415rpm
11T Pinion = 2214rpm
Head Speed/Battery Calculator for Windows
pwoodyp is offline        Reply With Quote
Old 10-04-2008, 05:24 PM   #3
sal98
Wow Thanks for the info, I can know go and setup the gov in the esc the right way.
Old 10-04-2008, 08:49 PM   #4
alienteabagger
um.... why not just run a flat throttle curve?
Zit: T-Rex450SA w/ 430L 13t pinion - My flying backscratcher
Tiny: Raptor .50 w/TT .50 engine - One bad machine!
One DX6i to rule them all!!
Have a gyro/tail/wag problem? Check here http://helifreak.com/showthread.php?t=66036
alienteabagger is offline        Reply With Quote
