Old 10-05-2008, 02:23 PM   #1
benzee1
Default Where to buy dx6i parts?
My thumb wheel broke today. I can't find any parts doing a search. The radio section of this forum seems to mimic that. Does anyone know if we can get parts anywhere?
HeliSimRC
Spektrum DX7, DX6i
TREX 450, Blade 400, Blade CX2
Myspace.com/heliwhore
benzee1 is offline        Reply With Quote
Old 10-05-2008, 02:27 PM   #2
george0079
Nope. The only part that you can buy for it is the antenna.
You're gonna need to send it in to Horrizon
If, at first, you don't succeed, then skydiving is probably a bad idea for you.
george0079 is offline        Reply With Quote
Old 10-05-2008, 02:29 PM   #3
RMG2
My trim lever (rocker) broke on my DX6i and it is a simple fix but Horizon would not sell me the part! They insisted I send the TX back to them at my expense so they could spend 1-minute doing the repair and send it back to me at my expense! I just CAed the broken lever/rocker and built CA gussets and so far holding fine.
I was told all parts and repairs must be sent to Horizon!
RMG2 is offline        Reply With Quote
Old 10-05-2008, 02:34 PM   #4
benzee1
What's a gusset?
HeliSimRC
Spektrum DX7, DX6i
Old 10-05-2008, 02:59 PM   #5
george0079
Originally Posted by benzee1 View Post
What's a gusset?
An added re-enforcement piece.
Old 10-05-2008, 03:28 PM   #6
benzee1
I'm thinking I'm going to cut a hex wrench and use that piece to fix it.
HeliSimRC
Spektrum DX7, DX6i
Old 10-05-2008, 04:04 PM   #7
ginnz
my thumbwheel broke a couple months back also....! the dang thing is plastic! i ca'd it back together, and its been holdong up fine, im just real easy on it....
i emailed horizon about this, and asked them to just send me the whole board that the wheel is attached to, they said they couldn't. i didnt want to lose my radio for any amount of time, so ill send it in around dec. as its too cold to fly here, and ill request the throttle gimble be looked at as its kinda loose, and get a new selector wheel put in..... basically do a re-build.
im seriously considering getting a spare Dx6i, for when this stuff happens.....
heck, ill prolly get a Dx7 used, and keep my 6i as a backup.....
MSR/Trex250/3-Hoss X4E/Flasher 450/BlackHawk500SePro/Trex500CF/HossX5R/Hurri550 Scale Jet Ranger/Trex600E/Dx7!
ginnz is offline        Reply With Quote
Old 10-05-2008, 04:10 PM   #8
benzee1
I figure after my mod, I'll never have a problem again! (at least not with that specific part)
HeliSimRC
Spektrum DX7, DX6i
Old 10-05-2008, 09:05 PM   #9
Flying Foot Doc
I had the thumbwheel break on mine too. Also had it stop sending on the aileron channel once and the rudder channel once. I've sent it back to Horizon for a second time under warranty, so I'm waiting to see what they have to say. Hopefully they'll replace it. I wonder if the DX7 has issues? Andy
Flying Foot Doc is offline        Reply With Quote
Old 10-05-2008, 10:31 PM   #10
Pagoda
I had to fix a DX7 trim button with CA. The plastic inside for this control is very flimsy.
Pagoda is offline        Reply With Quote
Old 10-06-2008, 12:11 AM   #11
benzee1
I tried the CA, didn't work for me. I'll post this in the forums, but here's my mod.
http://www.helifreak.com/showthread....897#post900897
HeliSimRC
Spektrum DX7, DX6i
Old 03-28-2011, 10:11 AM   #12
newpoppy
Default Replacement part
Here is a site that sells a replacement.
http://www.eastrc.org/estorerollerbutton.htm
You can make the repair your self like I did by using a small piece of aluminum tubing that the ID is the same as the broke off part.
First drill out the roller from the other end using drill bit that is the same size as the OD of tubing. Glue the broke off plastic piece into the Alum. tube using a very small amount of CA glue being careful not to get any on the hex end that must stick out far enough to insert into the adjusting control. Then slide the tube into the drilled out roller knob making sure to leave it stick out only 6 mm to the tip of the hex end.
I made the repair and it works just fine. I did order the one made of all Aluminum that is available from the link I listed above also just for a spare incase my fix doesn't work.
newpoppy is offline        Reply With Quote
Old 02-09-2014, 09:03 AM   #13
Nade
Thanks much newpoppy for providing the wheel link. Thought I had an isolated problem. Ordered mine as soon as I found your link. Looks like Spektrum has a design issue they need to correct.
Life holds no guarantees. You wannna play? You gotta pay!
Heli-max Novus N200. Stock & custom Blade CP Pro2's, Blade SR's, Blade 230s. Blade AH-64 Apache & Black Hawk. Walkera HM 4F200LM. Goblins 630 & 770. Vario Bell 47GII.
Nade is offline        Reply With Quote
Old 02-09-2014, 09:14 AM   #14
alhuggy
the menu select stopped working, scrolled ok, email horizon and they told me to phone the service department and I ordered a replacement wheel and board for the costly some of 4.20 delivered. should be here Tuesday. No trouble at all very helpful
Trex 450 pro FBI clone
Blade MSRX
450 v2
450 dfc dx6i
alhuggy is offline        Reply With Quote
Old 02-09-2014, 10:08 AM   #15
tango 9
Default thumb roller
East RC has the thumb roller
tango 9 is offline        Reply With Quote
Old 02-09-2014, 10:44 AM   #16
kheinink
back when I flew fb helis my rudder trim switch broke on my dx6i, my fix was swap it with the throttle trim switch that was never used
mcx/msr/mcpx/trex 550e super combo/600esp dfc conv ama#1037612
kheinink is offline        Reply With Quote
Old 02-09-2014, 02:46 PM   #17
CompleteDestruction
My LHS has fixed my dx6i in the past. The get there parts from spektrum.
They have replaced switches and adjusted the sensor things inside for me.
OP, pm me and I will give you there info if you want. I don't want to post there info, in case they are not supposed to do this.
Keep your skids up!
TEAM FLYBAR
130x, X3 Sprint, Goblin 500 ikon, Align 600 Nitro fb, Logo 600 ikon, DX7, No more money...
CompleteDestruction is offline        Reply With Quote
Old 02-09-2014, 03:56 PM   #18
rosinx
What's a gusset?
Search it up on google images!
Nano CPX dfc~ Dx6i ~ Phoenix~
Gaui X3 - In progress
"Let's see them do that with a plane!"
rosinx is offline        Reply With Quote
Old 02-09-2014, 07:23 PM   #19
aerocal
Click on top and roll on the bottom and you wont break it.Its like trying to push a door open from the hinge side if you try to click it near the pivot.Uber loads are placed on the pivot.
Too many helis & Too many planks
Lots of DX radios & A couple Futaba 72mhz radios
AMA member & Full scale plank driver
HELIFREAK !!!
aerocal is offline        Reply With Quote
Old 02-20-2014, 08:28 PM   #20
benzee1
I can't believe my old posts still get hits lol. I wound up coming up with a mod and fixed it myself. Eventually, I got a dx7. Now I don't have any helis except my cx2.
HeliSimRC
Spektrum DX7, DX6i
