Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite)
Blade Helicopters (eFlite) Blade Helicopters (eFlite) CP, CX, mCX CX II, CX III. and others
Old 10-05-2008, 03:40 PM   #1
Cullen Colapietro
Default HELP can't charge my new blade mcx
Hello all, I am new to heli's but not to rc. I am having a problem with my bmcx charger. When I insert the battery, the red charging light comes on as anticipated. However, after 1 hour charge time, the light is still on and the battery has no charge. I have lipos and have tested them all, so it's not the battery. I'm frustrated because this heli is great!
I took the issue to my LHS and the owner replaced my charger. I returned home with the new charger and to my dismay, I had the same issue. I've tried freshly charged 2500mAh AA's as well with the same issue. Should I buy new alkalines? I only have 8 or so charges on the cells included with the heli.
Any ideas?
Cullen Colapietro is offline        Reply With Quote
Old 10-05-2008, 04:21 PM   #2
estone
id try alcalines the individual cell voltage is higher it would be 1.2v higher than rechargeables. the batts that came with me only made it about 4-5 charges then it did the same thing as yours.the alcs they send are junk u should be able to get 15-20 charges per set
cp+ retired, cx2, trex 450, trex600e, numerous foamies
estone is offline        Reply With Quote
Old 10-05-2008, 04:22 PM   #3
Cullen Colapietro
Thanks, I'll go buy some fresh batteries.
Old 10-05-2008, 07:20 PM   #4
Cullen Colapietro
Feeling a little stupid, the new batteries did the trick. I should have thought of that, thanks. I just assumed since the rechargeables did the same thing that it was the charger. I have tried freshly recharged batteries and they will charge the mcx lipos. We'll see how many times.
Old 10-05-2008, 10:01 PM   #5
estone
ur rechargeables might be getting weak, i just tried some duracell 2500s and they work in mine we'll see for how many charges
Old 10-06-2008, 05:59 PM   #6
hfReader
Default Charging revisited
Got my mCX today and tried to charge using NiMH cells.
Although I charged the NiMHs before, charging never
completed (waited more than one hour).
So I disassembled the E-Flite charger:
- remove the 4 sticky rubber pads at the bottom
- remove the 4 screws
- remove the 2 screws of the charging jack
- cut off the black and red wires at the jack
- solder new wires to the jack
and crafted my own recharger cable.
When charging with 100 mA it will take 1 hour.
So I increased charging current to to 200 mA (ca. 2C)
yielding 20-30 min charging time.
5 cycles without problems so far.
Btw the mCX is a great improvement
compared to the bigger coax helicopters:
No TBE, minimal yaw axis drift, precise steering,
rock solid hover, weather independent indoor flying :-)
ID:	64887   Click image for larger version
hfReader is offline        Reply With Quote
Old 10-14-2008, 05:40 PM   #7
DaddyDan
awesome idea! i was thinking at making a 5v powersuply with a protoboard, you idea is much easier!!
i hate the fact that i can't use my nimh 2700mah for more than 4-5 charges since they are only 1.2v even if they are in good shape, after 4 or 6 charges the voltage gets too low (1.2 is too low for the charger)
DaddyDan is offline        Reply With Quote
