Go Back   HeliFreak > R/C Simulators Support > Other R/C Flight Simulators
Other R/C Flight Simulators Other R/C Flight Simulators
Old 10-11-2008, 03:08 PM   #1
lightfoot500
Default Helisim setup problem
hello,
i am using the latest version of helisimrc with the dynam transmitter. i can locate and calibrate the transmitter and mapping fine EXCEPT for the throttle/collective pitch. when i first install it works fine. then somehow the settings get changed and the throttle and collective pitch curve dont work together. sometimes i have no throttle and cant lift off and sometimes i have enough throttle for lift off but no 3d. i have hard time getting back to default settings and i have reloaded different model setups but it didnt help.
i think the problem may be from minimizing the helisim and then typing on other webpages and the helisim takes the keystrokes as commands which screws up the settings. i have tried uninstalling/reinstalling to no success.
what to do?
lf
lightfoot500 is offline        Reply With Quote
