| Engines and Mufflers Having problems or need advice on Engines or Mufflers? |
hi all what is the proper way to turn a heli.i always seems to pull back in my turns slowing the heli down. any tips.
I use aileron and a tiny bit of rudder
I use rudder and a tiny bit of aileron!
Are you coming from a plank background?? Most plankers tend to "bank and yank" just using the right stick for changes in direction. Heli's need ALOT more input on the rudder stick to coordinate a nice turn. I read once....- Airplanes you lead with aileron and follow with rudder. Heli's you lead with rudder and follow with aileron. |
No elevator?
I always have to use a little elevator in the sim (I'm not doing forward flight yet with the real thing) to maintain altitude. This is exactly the same as when I was flying planes, both real and model. Neccesary to compensate for some of the lift going into transverse motion. Not a lot, but some. So, at least when I turn on a sim, to perform a really good, coordinated turn, I use some initial aileron and elevator along with some rudder; when the turn is underway, maintaining altitude, A/E input is virtually zero, with constant rudder input to keep the turn coordinated; then opposite A and no rudder to level out when done. Of course there are constant small adjustments with A/E throughout the turn to compensate for perturbations from wind and stuff, but that's not actually part of the turn control input (it's no different than what you have to do hovering or flying straight on). |
Depends on the setup. I have two helicopters that I fly regularly. One helicopter I have to pull back a bit while banking in a turn or the speed will increase. The other helicopter I have to give it a little forward cyclic while banking in the turn or it will pitch up and lose speed. I don't feel a person should get too wrapped up in what is the "right" inputs. Just give the inputs it takes to make nice smooth level banking turn. If that means you have to stand on your head while balancing trained seals on a ball, so be it.
Velocity 50 FBL w/Beastx, T-rex 500ESP, 450 size scale UH-1N, T-Rex 450, mCPX BL, mCPX, Traxxas QR-1 micro quad, JR X9303, Realflight G3.5, AMA# 923167, Vice Prez Farragut Flyers |
#6 |
first off you dont need to add a lot of other crap for scale cordinated turns. do a search on my posts before you want to try and insult me I fly scale only the OP never said what kind of flying he does he asked for the proper way to turn a heli I DO NOT have to apply any elevator on my scale ships to make a nice cordinated turn. so enjoy your foot in your mouth you fool.
#7 | |
T-Rex 500 |
#8 | |
As far as turning goes, on my helis, I do need to provide a little bit of elevator, otherwise I will lose altitude. It also depends on if I'm trying to keep speed, or coming out of a turn to a slow approach.
Helis: T-Rex 600E, T-Rex 450SA/SEv1, mCX Planks: PA Addiction, Parkzone T-28 Trojan, Parkzone Su-26m mini Sukhoi on its way (woohoo!!) |
#9 |
Do a turn with GYRO in NORMAL mode and your scale ships will do a proper balanced turn as we say in full scale flying. I am from a plank background and found it difficult to do balanced turns while in HH mode, but the minute I did it in NORMAL mode it reacted and responded like a plank. I get commented on my co-ordinated turns and my local club...
TRex 250 BeastX, Trex 500-Vbar 5, Henseleit TDR, Banshee -VBar 5 All Kontronik ESC Hyperion 1420, Mega Power Gemini Chargers! JR XG11 Old hand at Planks To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#10 | |
Is that directed at me?? ![]() You need to chill out. Thats so far out of left field I don't even know where or why you got all butt hurt. |
#11 |
You've got to play with the power in a turn as well. When you bank to begin a turn, you're changing the lift vector and as such, you have to add power to maintain altitude. This added power will also help pull the heli through the turn without a decay in airspeed. It's no different in models than full scale.
A model with its gyro in HH will require more TR input to maintain coordinated flight than a model with its gyro in rate mode.
-Kevin No helicopters were harmed in the creation of this post. AMA CD # 7309, Turbine Waiver# RW 890 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#12 |
My HF Map location Join Date: Jul 2007
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
I'm just going to ignore the flames and continue with this thread.
I think many plankers take for granted that they always have forward thrust, so "bank and yank" seems natural to do when they start flying helis. A leveled-off or pitched-up plank will still move forward; a leveled-off or pitched up heli will hover or fly backwards, respectively.
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Nankin Hobby Field Rep, Compass Support Team Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX Experience is something you obtain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
#13 |
I am a noob, but here is my normal turn process that I get pretty smooth turns from. This is for a left banking turn.
I start with a little left cyclic (until the heli starts to get to the attitude I want), now I control the turn with my rudder more. I try and keep my tail a little below horizontal in the turn and that keeps me from dropping altitude. Now, while in the turn I am gradually rotating my cyclic more towards rear cyclic to bring the nose through the turn and then as I start to get to where I want to be heading I continue bringing my cyclic around towards the right to flatten the heli out of the turn and then slowly towards front to keep the heli from rising and keep it going forward. The motion I make with my cyclic is sort of like "G". It will be either forwards or reverse depending upon the direction of the turn, but it works great for my turns both in the sim and real life. Just make sure you end the "G" at the top instead of finishing.
--T-Rex 450 V2 (mostly) 430XL - CC35, GY401 W/S9650, HS65MG, AR7000e, 325 Carbons --T-Rex 500 all metal head, GY401 W/S9254, HS5245MG, AR7000, 425 carbons -- DX7, Hyperion Duo, flight leader case |
#14 |
#15 |
Well, you're doing a bang up job of not making any. Maybe you should consider another forum for your anti-friend making efforts...
#16 |
In a plank you increase lift by adding back pressure to the elevator to increase angle of attack.
In a heli you increase lift by adding more collective to increase angle of attack. In both, when you add angle of attack, you increase drag, so you have to add power to maintain the airfoil speed (in plank the actual speed of the aircraft, in heli the rotor speed).
Terry AMA#47402, IRCHA # 3395 Blade CP "Pro", Trex 450SE, PiccoZ, Quick of Japan EP8v2 EX, Hurricane 550, Hurricane 200, JR Vibe 50, Blade mCX, Bergen Intrepid Gasser, Pantera 50, Blade mSR, Novus CP |
#17 |
ban my ass see if I care. Nothing here but a bunch of whining crybabys. I see why mark ryder banned half of the jackass's here bunch of craybabys and jerks.
#18 | |
William James To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. If you fly you are going to crash. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#19 |
The words 'pot', 'kettle' and 'black' come to mind.
Anyway, interesing topic apart from the playground stuff. I guess there will benvariations on technique depending on the type of flying being done, balance and setup of the heli, etc. |
#20 | |
450SE v2 Hitec HS-65MG on cyclic, Gy401 & JR 3400g, AR6100, Thunder power 2200 extreme, 2100 prolite, True blood dampeners. |
