| Flybarless Helicopter Systems CSM Cyclock, Helitronix Multi-mixer, Spartan AP2000i, Firmtronix Digimix-3, Gyrobot, SK360and AC3X |
#21 | |
Hope you enjoin your raptor wih flybarless. Regards |
#22 |
Hi Cao Tri,
Your fellow VN flyer in Florida. Where can I fly in HCM VN ? Thanks |
#23 |
Any where : In catlai, In Metro,.. My group Rc-easy fly heli on saturday morning. Just call me when youa re in Vietnam . My tel 091 391 6290.
catch you later.caotri
Logo 500-610Blades:BLS252/V-BAR-9254/Z50A-600 -Jive80HV/ NanoTech 10S4000mAh + Quadrotor History: Lama V3, ESKY CP2,,BeltCP, T450V2, Gl500, HDX500, Hurrican 550, T600E, T450Pro, Logo500SE, ... more to come |
#24 |
#25 | |
The bladegrip keep stock design. caotri
#26 |
![]() ![]() I had to file 1mm off the bottom of the black aluminium washout slider, which when mounted upside down, would be very near the bottom of the head block. Reason is that the slider needs to be about 0.5 to 1mm higher so that the "SUPER PRO" arms will be horizontal when elevator lever is square. But come to think of it, I needn't have bothered. |
#27 |
Hi, did you testfly yet and does it fly well?
#28 |
Have had about 10 flights with the Gyrobot 900. It flies well.
Have not got my GB900 tuned perfect: - Tail stops are not as clean as I like. It is OK at high HS, but has a single mushy kick at low HS, when stopping. - I find that I have small roll oscillations only at the end of a pack, weird. |
#29 |
Hi, it is cool to hear that you liek this mode.
You also can cut down the centerthub abit and used the hold for sesaw befor to put the crew for main sharft in.. it make the head lower and look for cool and allso fast roll.
#30 |
Hi guys, I was just wondering if I could just buy a set of new washout control arm and simply fix it without mod? Thinking of trying. Pls pardon me if my question sounds really silly, I have no idea on FBL heads.
Trex700N LE, Trex600ESP,Mini-Titan & Trex250SE Feeling of Hover at (28/12/2009) - PRICELESS! Biggest mistake - selling my Beam...crap! |
#31 |
i like your conversion, its cooler and cleaner!
ill try to find out if i can do it on my hk450gt pro... your conversions are so neat! as of the moment, this is my setup: ![]() ![]() ![]() ![]() the arms needed a spacer or the blade grip links would look like this ^_^ the mix arm were too close to the head shaft! ![]() and found i could use the original bearings of the inner flybar cage as spacer for the mixing arms! ![]() to make the blade grip link straight ![]() made a lock screw here ![]() then removed the cable tie it was just for testing purposes and fix everything! ![]() ![]() |
#32 |
AMAZING!!!
