Old 10-14-2008, 09:30 PM   #1
jlharv
Default 90 deg. rotation on punch out
Hey all,
About two weeks ago I developed a new problem.
Symptom 1. When ever I do a medium throttle punch out the heli rotates about 90 degrees CCW.
Symptom 2. Often when I am in forward flight and do a banking turn to the right (I have not noticed it ever happening to the left), the heli does not respond right away to the rudder input and tail continues to go straight. Then after a delay it comes around.
Symptom 3. When entering a flip the tail does not hold. This puts me in an unexpected orientation, and resulted in a crash.
I am measured my headspeed at 2800. Flying pro woodies, HS65s, GY401, Fut. 9650, DX-7/AR700. The belt, boom, main, feather, and tail shaft are all new. The tail slider moves very freely, the gyro moves the tail back and forth when I rotate the heli, the heading hold appears to work, I can take my hands off the left stick and it holds for ever. The tail pulley seems to be holding strong, the tail servo seems to have plenty of torque (I held resistance on it while slowly moving it with the radio),
That is all that pops in my head right now that I have tried, I'm sure there is more. But I am running out of ideas. Has any one seem this, or have any suggestions what else to try. I am running out of flying season and need to get this thing back in the air..
Thanks,
John
John
nCPX ,mCPX BL, 130x - T-Rex 500ESP DS510, mini VBar, 13T
T-Rex 600ESP 12s, scorpion 4025 630, VBar, DS650, DS610, 14T- T-Rex 700E V2 VBar
jlharv is online now        Reply With Quote
Old 10-14-2008, 10:37 PM   #2
Pagoda
Post your Throttle and Pitch curves
Pagoda is offline        Reply With Quote
Old 10-14-2008, 11:39 PM   #3
gone cold
i had a 502 gyro on a 90 and it did that. it was a bad gyro. i was lucky and didnt crash it before i figured it out.
gone cold is offline        Reply With Quote
Old 10-15-2008, 09:04 AM   #4
jlharv
I only fly in idle up 2 (idle2, stick slightly less than 50%, turn off th. hold, let soft start spin it up, take off...)
th=100-90-100
pitch=(-12)-0-(+12)
John
Old 10-15-2008, 11:58 AM   #5
t-driver
i had a similar problem, the only difference was i had 180 turns......
it turned out to be the belt slipping!
check for it's tension
TT Raptor Gasser with RC270 Zenoah
CopterX450SE V2
t-driver is offline        Reply With Quote
Old 10-15-2008, 12:08 PM   #6
jlharv
I tightened the belt and rotated the main gear slowly while keeping tension on the tail, just in case some of the teeth were not gripping. I could not make it slip no matter how hard I tried. I am thinking that "gone cold" might be right about the gyro. But if I hold the heli with the nose facing me, and move the tail left or right, the tail pitch changes accordingly. And if I hover, it seems to keep its heading?? So it looks like the gyro is working??
John
Old 10-15-2008, 12:12 PM   #7
pwoodyp
Low headspeed due to bogging??? What motor and what pinion?
pwoodyp is offline        Reply With Quote
Old 10-15-2008, 12:14 PM   #8
Pinecone
2800 isn't that high on the Trex. The tail drive was changed to slow down the tail when headspeeds got into the 3K range.
Grab the main hub and tail hub and twist against each other with moderate force. It could be a pulley slipping.
Have you done the Chinese weight mode? A weak servo or too much tail force could show the same symptoms.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote
Old 10-15-2008, 12:54 PM   #9
jlharv
I also thought of the tail pulley slipping. And did the test that you suggested main hub and tail hub. I put pressure on both all the way through the length of the belt in case there were theeth missing or loose that I could not see. Also grabbed the tail pully with pliers and tried to turn the lower gear and it would not budge.
I don't hear any noticable bogging of the head. It does not take full throttle to make it spin out. I am running 12t with the stock V2 motor. I used to run in normal mode as low as 2500 and I never had this problem, so my head speed is way higher than it used to be. Also I do not have to have any increase in head speed or pitch. If I am flying straight and go into a right bank, sometimes the tail will not respond to the rudder input. In that case I did not increase the pitch or throttle.
Thanks for the suggestions so far. And if you have others, please keep them coming. I have a friend that is willing to let me try his 401, I think I will give that a try too.
John
Old 10-15-2008, 12:57 PM   #10
jlharv
Oh, I forgot to comment on the Chinese mod. I have not done that. But I don't think that is the problem. I have pressed against the servo and it seems to have plenty of torque. I am not a strain gage so I don't know exactly how much, but it feels very strong. And like I said, it happens on slow casual flight too, when there is not much stress on it.
John
Old 10-15-2008, 11:49 PM   #11
cudaboy_71
i just went through a similar issue. i had just upgraded motors (put on a scorpion HK2221-12) and overpowered my tail setup.
i moved the ball to the outermost hole in the servo horn and that did the trick. no more blowouts on hard punchouts. and, this with the 'antiquated' 401/9650 setup and no chinese tail mod.
˙ʇı ʞɐǝɹq 'ǝʞoɹq ʇ,uıɐ ʇı ɟı
cudaboy_71 is offline        Reply With Quote
Old 10-16-2008, 12:15 AM   #12
KiwiFlyerNZ
I had this problem on my 500, and the solution was the tail servo placement. I had a hard landing the flight before and the servo had moved down the boom. Check to see if the tail linkage geometry is as it should be.
T-rex 450S
T-rex 500 GF
JR9X - Spektrum Module
KiwiFlyerNZ is offline        Reply With Quote
Old 10-16-2008, 05:53 AM   #13
jlharv
The tail servo is giving full travel in both directions to the tail slider, it goes as far as it can with out binding and then centers after a few quick back and forth strokes. So I think that is OK. And I have not changed the motor (stock V2 motor) or the placement on the servo horn. It has been flying like this since the beggining of last summer. Is it possible that a gyro just gets old and flaky?
Like I said before this is not just a punch out issue, it looses control of the tail in nice easy forward flight and a simple turn. So it does not seem to be a high torque or head bogging problem.
John
Old 10-16-2008, 07:40 AM   #14
kevntri
If it looses it in slow flight I would say it is a Gyro issue....
Try the different 401 and let us know
TREX450 pro FBL - Exceed Blue ray PE 450 - Hughes 300 semi-scale Blade 400
- Blade SR120 - Blade MCPx
kevntri is offline        Reply With Quote
Old 10-16-2008, 07:46 AM   #15
TRex888
Probably already said before one of the following can be slipping:
- pinion on motor (I use a CD mark and draw a short straight line of 3mm across the centre of the shaft and pinion, if they are out of line then the pinion is slipping)
- one way slipping (stick in a spare main gear with new bearing and try, the new SE blue main gears are always round now and do not require the mesh to be set each time so it's an easy try)
- front tail pulley slipping (same straight line marking trick)
- Tail pulley slipping (no easy way to be sure but to replace)
Try also moving the tail servo ball in if possible. It may not have enough torque to fight the tail (possible that gears are worn too). I have play in my tail slider which I know is coming from a worn S9650
- Swash slipping (I had a the similar tail holding issues just before my swash came apart, no easy way to check unless you have a spare swash)
TRex888 is offline        Reply With Quote
Old 10-16-2008, 08:26 AM   #16
markb
OK, this first one is going to sound dumb, but I did it, and it produced similar symptoms. I flew 3 packs the other day, without figuring out that my gyro switch was in normal mode instead of heading hold. I came home to figure out what was wrong with my tail setup! It wouldn't hold under any kind of torque, and kept showing these weird heading changes that we're really messing with my flying. I figured it out later at home, DOH! I never touch that switch! I'm probably going to program it for HH in both positions! Anyway... sanity check. make sure its in HH mode.
Second, the chinese weight mod is a good thing. The force it eliminates is NOT just in high power situations. Its ALL THE TIME. whenever that tail rotor is spinning, your servo has to fight the CRM centering force, to hold pitch. Even if it doesn't fix your problem, its a good thing.
You said your tail servo: "... goes as far as it can with out binding and then centers after a few quick back and forth strokes."
A few quick back and forth strokes??? That sounds bad. Does it do that if you hook it directly to your radio (no gyro)? If so, it may be time for a new servo.
Edit: And, if it only does the centering "overshoot/hunt" when connected to the gyro, it sounds like your gyro has a problem...
Mark
Logo 600se, Scorpion 5020-450, mini-V, Jive 80HV
Trex 600 ESP FBL, Scorpion 4025-740, cgy750, CC85HV
Trex 450 Vx FBL, Scorpion 2221-10, RJX head, mini-V, Ice 50
markb is offline        Reply With Quote
Old 10-16-2008, 11:35 AM   #17
jlharv
Trex888. I will try some of those test when I have a chance. Most of the items I have tried, but not the test method that you described. So I can retest them with your methods just to double check.
markb. No sugestion is dumb. (or sounds dumb). I did make sure that I was in heading hold. Both on the radio and I get the red heading hold light on the gryo. And I agree that the Chinese mod is probably a good thing and I might do it. But I don't think it is the root of this problem. These components have been working perfectly together for a year and a half now. So I want to fix what ever component has gone bad. And the "centering after a few back and forth strokes" is a function of the gyro. If you give it full left and right rudder three or more times rapidly, the 401 will center the servo when you let the stick return to neutral rudder. It helps you to know how to put on your servo horn at 90 deg and center the tail travel.
John
Old 10-16-2008, 12:06 PM   #18
kevntri
any theory yet????
Old 10-16-2008, 12:42 PM   #19
jlharv
My theory is that my gyro is going bad. But it was raining last night so I could not prove it. Tonight I am going to the LHS to see if they have a decent deal on a gyro. If not I will be ordering one. I still have the option of borrowing a friends, but that ,means him taking it off of his heli and since I am about to build a 500 any way, I might as well just buy one. Then if it is the problem, I will have to get one to put on there permanently.
John
Old 10-16-2008, 08:42 PM   #20
jlharv
OK, so tonight I was able to borrow a 401 and try it out. Same thing. Rotates 90 CCW on punch out. And when making a right turn the rudder does not respond about 20% of the time for about 1/2 of a second.
Here is my thinking...
1. Forget the punch out.
2. Slow forward flight, only 1 out of every 5 passes, only when turning right.
3. Since it is slow and no sudden burst of throttle or change in pitch, it is not bogging the head.
4. Correct me on this if I am wrong.. looking down on the heli, the mail blades spin clockwise. So a right turn should be easier than a left, because you are asking the tail to resist the inertia of the mains less.
5. If a right turn is easier (by my theory) what would make the problem only show up on a right turn? Wouldn't that eliminate something slipping? Slipping would appear when there is more stress on the system not less.
6. That leaves what?? Binding in the tail shaft? It is smooth as can be, and the tail is brand new so I know it is not bent.
7. Binding in the pushrod, it seems free.
I just don't get it..
John
