Old 10-17-2008, 06:23 PM   #1
benzee1
Default AR6100e upgrade
I've seen threads that indicate HH will replace/upgrade the 6100 with a newer version. Anyone have links for those threads? I tried HH website, and the only thing I could find was an upgrade on the 6100 for a plank. Something about the rx will apply elevator by itself.
HeliSimRC
Spektrum DX7, DX6i
TREX 450, Blade 400, Blade CX2
Myspace.com/heliwhore
benzee1 is offline        Reply With Quote
Old 10-17-2008, 07:06 PM   #2
carljw
If your 6100 have a 1.2 V on the end Horizon will upgrade it to 1.6 V free of charge if you send it in to them. I read some place you have to get a form from Horizons web site but never found it . I have two with the 1.2 V on them I might send in this winter
If I can find out where to get the form you need.
Carl
carljw is offline        Reply With Quote
Old 10-18-2008, 12:11 AM   #3
TowPilot
Carl
I called the Service 800 number.
Was given instructions on how to return them for the free firmware update service.
I returned 6 receivers which were 1.2 version to have updated to 1.6 version.
Spektrum Contact Info
TowPilot is offline        Reply With Quote
Old 10-18-2008, 06:40 AM   #4
Dynarace
Here's the full info...
http://www.spektrumrc.com/Articles/A...ArticleID=1756
Dynarace is offline        Reply With Quote
Old 10-18-2008, 07:15 AM   #5
blahblah9
i don't like the update, gotta turn controller on and off between every battery to stop blinking light
blahblah9 is offline        Reply With Quote
Old 10-18-2008, 07:35 AM   #6
nargargle
The rx blinks to tell you it had a "brown out". While a pain it just might save you form a crash if your bec starts acting up and you don't catch it. Worth looking at before unplugging battery after each flight. Just my thoughts
nargargle is offline        Reply With Quote
Old 10-18-2008, 09:56 AM   #7
benzee1
I was wondering why the rx on my t450 was blinking the other day. hmmm......
HeliSimRC
Spektrum DX7, DX6i
Old 10-18-2008, 10:53 AM   #8
BennyTRD
I noticed that with the 6200 I put in my 500. Between every battery I had to turn the TX off and on to stop the lights from blinking. Is this all this firmware update does? If so, I'm going to stick the the 1.2.
BennyTRD is offline        Reply With Quote
Old 10-18-2008, 11:32 AM   #9
blahblah9
yea my new rx does this also, i don't wanna wear out my tx turning it on and off all the time, so i just let the sucker blink. doesn't effect anything that i see.
Old 10-18-2008, 11:52 AM   #10
tyrick69
If power to the receiver drops below a certain voltage due to heavy loading of the servos, etc.. the v1.2 receiver could take several second to reconnect to the transmitter, resulting in a crash. The v1.6 receiver will reconnect almost immediately possibly saving you from meeting terra firma. It's your call but I'd much rather deal with a little blinking light or having to turn my transmitter off and on than crash my heli due to electronic failure. I usually give my heli a rest between packs anyway to let the ESC and motor cool a little.
Helis - Raptor 30, T-rex 450SA, Blade 400, Blade CP, CX2, mCx
Planks - GP Revolver, Seawind EP, Typhoon 2, Mini Pulse XT, T28 Trojan, SuperCub on floats
tyrick69 is offline        Reply With Quote
Old 10-18-2008, 11:53 AM   #11
BennyTRD
You bring up a good point. This winter I'll send it in.
Old 10-18-2008, 12:24 PM   #12
nargargle
To tyrick69 on that.
