Go Back   HeliFreak > R/C Helicopter Support > 250 Class Electric Helicopters > 250 Aftermarket Upgrades
250 Aftermarket Upgrades 250 Aftermarket Upgrades
Old 01-02-2009, 03:27 AM   #41 (permalink)
ttt
Old 01-02-2009, 02:50 PM   #42 (permalink)
Hi Heim Joint,
thank you for the videos!! I went through my tail looking at the bind points you mentioned and it has really helped out my bird to remove the binding especially in the bushings.
You mention that the spacers will fit with two bearings, what size bearing? 1.2mm or 2.0? I'm unsure if I would have space with two 2mm bearings. I am unfamiliar with the Gaui bearing size, hence the question.
Cheers,
Leslie
leslie is offline        Reply With Quote Quick reply to this message
Old 01-02-2009, 03:23 PM   #43 (permalink)
Originally Posted by leslie View Post
Hi Heim Joint,
Cheers,
Leslie
Leslie,
The bearings that will work with the spacer set are a 681X bearing (1.2mm wide). They are the same as the original 2 bearings that were in the first T250's before they changed to the single 2.0mm wide bearing. That 681X size bearing is all over the 250 in various places. The Gaui bearing number I mentioned is a 681X.
HEIM JOINT
HEIM JOINT is offline        Reply With Quote Quick reply to this message
Old 01-05-2009, 10:56 AM   #44 (permalink)
Heim Joint,
Any idea yet on pricing for the T-Rex 250 chinese weights ?
Also - are you able to tell me 450 and 500 pricing ?
Thanks in advance...
DX7 Mode-1 | 450 pro 6s | 450 pro | Schweizer 300C Gasser Scale | T-Rex550e | Aeolus 50 | HeliX T-Rex700 fbl Gasser | HWC600 Gasser | Henseleit MPXLe | Henseleit 3DNT | Suzi-Janis 700 | Gaui NX4 | Gaui X5 | Blade 350QX
jockstrap is offline        Reply With Quote Quick reply to this message
Old 01-05-2009, 01:13 PM   #45 (permalink)
+1 for jockstrap's post (man that sounded really weird)
specialk is offline        Reply With Quote Quick reply to this message
Old 01-06-2009, 01:15 AM   #46 (permalink)
All I know is I want them as soon as I can get a set .I've had my tail stick every time I've flown it . I've grounded my 250 until the tail gets fixed. Pm me with a price and where I can get it , Please?????
tweav is offline        Reply With Quote Quick reply to this message
Old 01-06-2009, 02:19 PM   #47 (permalink)
Originally Posted by jockstrap View Post
Heim Joint,
All 250 450 500 Trex weights are $16.50 +$2.00 S&H in US
250 and 450 will be ready in about week.
Thanks, HJ
Old 01-06-2009, 02:36 PM   #48 (permalink)
Keep in mind that the Chinese weights and the preload spacer set are two different things.
The Chinese weights will NOT FIX a sticky tail. They could make a sticky tail worse. They will only greatly reduce the pushrod force on a properly funtioning tail.
The preload spacer set will enable you to reduce the slop in your blade grips to a very low level. But in my testing in the video the preload spacer set itself did NOT FIX the high pushrod force problem. I had to replaced the original blade grip bearings and then the pushrod force dropped to the expected 10-12 oz. (without chinese weights). If you have a new single bearing tail you will have to buy 4 of the 681X bearings to use with the preload spacer set. You will also have to trim a little off the blade where it touches the new longer screw that goes thru the bearings. I will post a video here of the preload spacer set install in a few days.
Thanks, HJ
Old 01-06-2009, 02:54 PM   #49 (permalink)
Question UK shipping?
Can you give us a price for S&H to the UK please HJ.
Thanks,
Richard.
rwleigh is offline        Reply With Quote Quick reply to this message
Old 01-06-2009, 03:00 PM   #50 (permalink)
Thanks,
Richard.
$3.00 to anywhere in the world for up to 2 sets
Thanks, HJ
Old 01-06-2009, 07:19 PM   #51 (permalink)
Yes I want both the weights and a spacer kit . When ever you get them ready . I did throw a few washers between my bearings and it did fix some of the slop , but I'd rather just fix it and be done with it. I'll take a set of weights for a 500 too.
Old 01-10-2009, 10:55 PM   #52 (permalink)
Getting towards mid Jan, getting excited!
Old 01-11-2009, 12:39 AM   #53 (permalink)
Are you going to put up an order page or de we PM you? Also, do you take paypal?
cbrian4 is offline        Reply With Quote Quick reply to this message
Old 01-23-2009, 10:03 AM   #54 (permalink)
What ever happened to these???
kkent25 is offline        Reply With Quote Quick reply to this message
Old 01-23-2009, 10:12 AM   #55 (permalink)
Pm me for now. I will have a web store soon.
Thanks, HEIM JOINT
Old 01-23-2009, 10:13 AM   #56 (permalink)
Spacer sets are in stock. The weights will be ready to ship feb 2
Thanks, HEIM JOINT
Old 01-23-2009, 12:24 PM   #57 (permalink)
Thanks, HEIM JOINT
Will you have enough for "everyone" then?
Do you also have the 600N weights in?
T-rex 600N, 8717, V-bar, 8900, YS50.
MSH Protos, 3517, Mini V-Bar, 3500.
JR DSX9
Rune
Roadrune is offline        Reply With Quote Quick reply to this message
Old 01-23-2009, 01:52 PM   #58 (permalink)
Yes plenty for everyone. 600 and 700 Stock plastic and 600 and 700 kasama are in stock. 600/700 allign metal several weeks away
HEIM JOINT
Old 01-26-2009, 09:29 PM   #59 (permalink)
The 500 and 600 Kasama pieces are dead on.
Perfect balance.
Post the website info soon as you get it...
Are you making anything for the 450's?
Jim a.k.a. BrockJ
BrockJ is offline        Reply With Quote Quick reply to this message
Old 01-27-2009, 02:41 PM   #60 (permalink)
can we make this a sticky? This should be a sticky. I've entered too many tail servo conversations without knowledge of this only to deliberate over finding any servos with more torque for the same basic cost/size/close-to-speed of the specific-designed tail servos (JR, INO LAB, etc) when those are just fine.
This is a mystery this isn't entirely standard by now, with servo manufacturer's apparently already of the idea that little torque is needed...the heli manufacturer's go with it not realizing that lots of torque, per their own design, is really needed and needs modded..the right way..instead of leading people to go sprawling off into massive servo overkill territory
Thrashaero is offline        Reply With Quote Quick reply to this message
