Old 05-08-2009, 10:39 AM   #1 (permalink)
Default Sudden loss of power?
Hi all,
I need some help. I have the stock ESC and motor settings:
Brake disabled
Mid Timing
High cutoff voltage
Slow start+gov
Quick speed
5.5 V
When i fly it would intermitantly cut the motor for about a second then power up again? Range is perfect, no iterferences, throttle curve Norm(0-50-100-100-100),Idle(100 straight).
Any help appreciated, maybe my ESC setting are wrong?
Erozion is offline        Reply With Quote Quick reply to this message
Old 05-08-2009, 12:04 PM   #2 (permalink)
No brake!!!!
ferret30 is offline        Reply With Quote Quick reply to this message
Old 05-08-2009, 12:58 PM   #3 (permalink)
Mine did that at first. Motor would just briefly drop power intermittantly. I was using Futaba fm tx and rx that I took from one of my nitros that I THOUGHT was working fine. I changed settings, tried another esc etc. Broke my landing gear. Drove me nuts for 2 days I contacted the mfg and they said that the tx or rx could also cause it.
HUH but the tx,rx worked on my other heli. I switched over to a Spektrum DX6 and the problem was gone... Interference? IDK. Any idea guys??? Should I send the Futaba tx,rx in for a checkup?
d4wheelin is offline        Reply With Quote Quick reply to this message
Old 05-08-2009, 01:04 PM   #4 (permalink)
Sorry i meant brake disabled
Old 05-08-2009, 01:21 PM   #5 (permalink)
Originally Posted by Erozion View Post
Hi all,
Brake DISabled
Mid Timing
High cutoff voltage
Slow start+gov
Quick speed
5.5 V
I run this setup except without the GOV. Maybe that is cutting the power instead of reducing?
Other problem may be battery going bad. I see this happen with my older eflite batt's from my cpp when I run them on the bench too long. Can't fly with them at all.
jck
Last edited by johnckendall; 05-08-2009 at 01:21 PM.. Reason: change brake setting
johnckendall is offline        Reply With Quote Quick reply to this message
Old 05-08-2009, 01:30 PM   #6 (permalink)
John i tried with and without GOV and still does it, im using the Align 850 batteries,got 4 and does it with all 4. Using 35mhz, but it will loose power right infront of me so not sure there interference.
Old 05-08-2009, 01:32 PM   #7 (permalink)
Hrm. Is the ESC close to the receiver? Post some pics of your setup...
jck
Old 05-08-2009, 01:35 PM   #8 (permalink)
The ESC is on the bottom and receiver on the right side of the heli. i dont have a camera to post pics.
Old 05-08-2009, 01:37 PM   #9 (permalink)
Does it start cutting out at the beginning , middle or end of the flight?
Can you re-create the cutout on the bench?
jck
Old 05-08-2009, 01:42 PM   #10 (permalink)
I would say more to the middle and end of the flight, i checked temp of ESC and motor both ok, i havent tried recreating it on the bench i will give it a go.
Old 05-08-2009, 01:45 PM   #11 (permalink)
Any chance you're going below 50% in normal mode when it happens? Can you also make it happen in idle up?
Rotorjunkie is offline        Reply With Quote Quick reply to this message
Old 05-08-2009, 01:49 PM   #12 (permalink)
Rotorjunkie it only seems to happen in idle.
Old 05-08-2009, 02:29 PM   #13 (permalink)
Those align esc's are hit and miss. Bought 2 kits, replaced them both in a month. Try not using a high cutoff voltage. If your system draws too much, it will shut down for a second then power up again.
Rollin_3z is offline        Reply With Quote Quick reply to this message
Old 05-08-2009, 02:31 PM   #14 (permalink)
Originally Posted by Rollin_3z View Post
Those align esc's are hit and miss. Bought 2 kits, replaced them both in a month. Try not using a high cutoff voltage. If your system draws too much, it will shut down for a second them power up again.
Good idea. It could be your pack voltage sagging under load and tripping the voltage cutoff.
Old 05-09-2009, 08:55 AM   #15 (permalink)
I have tried all the settings on the heli and it still turns off for a second then powers up again. Do you thibk i should replace the ESC?
Old 05-09-2009, 11:47 AM   #16 (permalink)
The only things I can come up with that could cause this are:
* losing signal briefly causing the receiver to go into failsafe
* triggering voltage cuttoff in the ESC
* bad electrical connection
* bad servo
* bad ESC
Do any of your electronics get hot (servos, ESC, motor)?
Have you been able to reproduce this on the bench? If so, try unplugging all your servos to see if that has any effect.
Old 05-09-2009, 03:25 PM   #17 (permalink)
I went out to the park today to try see if there was maybe an interference close to my house. It seems there is because it flew like a charm without any drops in power. The only thing i can think of is a wireless router causing issues. Im not sure its all a bit strange.
Thanks for all the help guys.
Old 05-09-2009, 05:34 PM   #18 (permalink)
I would hazard a guess and say it is a radio glitch.
Are you using PCM or PPM?
PCM will be much better but it will still be suspectible to interference from the drive system.
In a heli this small the seperation of components is virtually zero.
Could you post a good close up pick of your electronic layout??
Mick
aussiemick is offline        Reply With Quote Quick reply to this message
Old 05-10-2009, 01:28 AM   #19 (permalink)
These are the best i can do, the camera doesn't focus up close. Its PPM.
ID:	96306   Click image for larger version
