Old 07-01-2009, 07:04 AM   #21 (permalink)
I havent mapped down the Hacker, so data is unknown unfortunally.
Try Castle since that is pretty linear and see, but be aware that actual result might differ.
http://heli.dacsa.net
Old 07-01-2009, 07:10 AM   #22 (permalink)
I am only looking for somewhat close. Within 50 would be nice. I will tach my L400 on the weekend and see what get.
I am running 150kv hacker on 20t governed to 77% with 6s v-plus 30C and the performance feels good.
It is hard to tach when you are flying by yourself
Synergy E7 ~ Logo600SX + 600SE + 550SX ~ Synergy N7 + N5C ~ Mini P ~ Trex 450L
beans07 is offline        Reply With Quote Quick reply to this message
Old 02-06-2010, 04:09 PM   #23 (permalink)
MrMel !
That's cool ! I build my logo and plan my pinion. Your calculator is very very big help for me
thx
Pilot Peter Martin My Galery: www.rcpilot.hu
martn1sw is offline        Reply With Quote Quick reply to this message
Old 02-23-2010, 05:02 AM   #24 (permalink)
Ive Jive and Futaba Tx.
I set my Endpoint at -84/+84.....
For correct use of HS calculator, should I set my endpoint at 100 or 84 ?
nono is offline        Reply With Quote Quick reply to this message
Old 02-23-2010, 05:05 AM   #25 (permalink)
You need to see what YOUR endpoints should be with futaba;
83/83 is only for spektrum.
Watch this video and make the same as I do in the second part of the video, i.e. lower ATV, raise it until it arms.
[ame]http://www.youtube.com/watch?v=oA5_Pg-ym_A[/ame]
Old 02-23-2010, 05:11 AM   #26 (permalink)
I remeber that it arms at 81...and for secure I set 84.
But, Does HSCalculator show HS for 100/100 or for adjusted point ?
My question is because i check with ET system my stuff ( Pyro 700-52 and Jive80HV )
I use 12Tpinion on mod1.
HScalculator show at 65% 1840rpm, but my ET show 1930....hence I think that my Pyro is out of his range.
Old 02-23-2010, 05:21 AM   #27 (permalink)
Ok, excuse me for my request, I read NOW in "tip" that that programs wants endpoint correctly matched....
bye
Old 02-23-2010, 05:38 AM   #28 (permalink)
Yes, it need "adjusted ATV"
Pyro and most german motors using a different method of checking KV, you can press the hint on Motor KV and you get the story about that.
Old 05-06-2010, 04:25 PM   #29 (permalink)
Hi
I have a Logo 600 with a Scorpion 4035 500kv motor, 11t mod 1 pinion, 12s lipo, Jive 80HV (using mode 11)
and Turnigy 6s 30c 3600 mah batteries. EC5 connectors.
I used a high quality microphone and Audacity 1.3 to calculate my headspeed today
I plotted graphs from the headspeed calculator vs my headspeed/throttle%.
The result is that I need to have 8% higher throttle curve to obtain the same headspeed as suggested in the calculator. Or said in another way. I get 100 rpm less than suggested in the calculator at any point.
For 2000 rpm I need 79% throttle and for 2200 rpm I need 98%.
My questions are then:
  • Is this because of I use Mode 11 on the Jive?
  • Is my 500 kv motor a much lower actual kv?
  • Should I just increase my throttle% till I get the right rpm in Audacity?
  • When changing between normal/idle 1/idle 2, do you have to land and spool up over again to get the right head speed (sounds strange to me, and not likely)
Regards perfeet
perfeet is offline        Reply With Quote Quick reply to this message
Old 05-06-2010, 04:27 PM   #30 (permalink)
(using mode 11)
Calculator apply Mode 4, i.e calculation at spoolup...
I havent tested Mode 11, and it really is hard to get down since it wont be affected by temp and weather and pack same as mode 4, it all depends on what your FIRST spoolup was.
Old 05-06-2010, 04:30 PM   #31 (permalink)
Thanks for the quick reply, Mr. Mel
I did the spoolup with some average batteries at zero degree pitch.
Regards perfeet
Old 05-06-2010, 04:31 PM   #32 (permalink)
Yep.
Old 05-07-2010, 05:18 AM   #33 (permalink)
Why don't you use this Pyro
Originally Posted by perfeet View Post
Hi
Henseleit TDR V-Bar Pyro 700-52 BLS451/251 TP
Logo 500SE V-bar Pyro 600-11 BLS451/251 T
shadowmastervn is offline        Reply With Quote Quick reply to this message
Old 05-07-2010, 05:47 AM   #34 (permalink)
If its any use to anyone the final gear ratio for a henseleit rigid is the equvilant of a single stage with a main gear of 158.1
Skint Eastwood is offline        Reply With Quote Quick reply to this message
Old 05-07-2010, 06:19 AM   #35 (permalink)
A little off-topic, but...
Because it cost twice as much, and the Scorpion 4035 is a very nice motor .
Regards perfeet
Old 07-26-2010, 08:09 AM   #36 (permalink)
Is the HS calc still working? I've tried to use it for the last two days and nothing comes up!
Hulley is offline        Reply With Quote Quick reply to this message
Old 07-26-2010, 08:13 AM   #37 (permalink)
Our dns had expired, should be up within a day now.
Old 07-26-2010, 09:08 AM   #38 (permalink)
I have an ideal. How about adding a field that shows the gear ratio. I know it is simple math, but it would be cool to see. Also if there could be motor data somewhere like the number of poles, etc....
Skids Up.
http://twitter.com/jbdww/
http://www.jbdww.com
jbdww is offline        Reply With Quote Quick reply to this message
Old 03-23-2012, 04:53 PM   #39 (permalink)
I was inspired by MrMel's calc and did a simple headspeed calc with some fancy jquery and AJAX calls to a motor database.
http://mikeaarset.zxq.net/HeadSpeedCalcAJAX.php
maarset is offline        Reply With Quote Quick reply to this message
Old 11-20-2015, 02:34 PM   #40 (permalink)
MrMel's calc is not available???
Not Found
The requested URL /calcv3/Default.aspx was not found on this server.
Apache/2.4.7 (Ubuntu) Server at heli.dacsa.net Port 80
2x Logo 600sx, Logo 480xx, JR, Torq, MKS, YGE, Vbar, Skookum...
szaki75 is offline        Reply With Quote Quick reply to this message
