Old 10-01-2009, 09:01 PM   #1 (permalink)
Default Blade 400 electroics help
Ok guys,
I am a heli noob.
I got this in a trade so I did not pick out the electonics/servos. Please tell me what you think I need to change on the electronic side. I beilve I need a better gyro.
I have Hextronik HXT900 cyclic servos, JR DS290G tail servo, xmhobbies gyro. first 2 flights ended in broken parts. I had to send the DX6i in for the recall so what can I do to get her ready for when it comes back.
I just got a CC bec the other day that is going to be installed.
Thaughts?
MrLucky13
MrLucky13 is offline        Reply With Quote Quick reply to this message
Old 10-01-2009, 10:11 PM   #2 (permalink)
you might just want to buy new cyclic servos, i'm really liking the hs65mg's all metal gears, loads of torque! if your hell bent on upgrading that is,or you might want to just buy a few spare sets of blades and gear sets for the servo's you have until you learn the ropes, chances are that wont be your last crash! at first i couldn't afford to upgrade becuase i was in the hobby shop sometimes 3 times a day buying and replacing broken parts from crashes, i'm still in there every few days...
sethf8403 is offline        Reply With Quote Quick reply to this message
Old 10-01-2009, 10:11 PM   #3 (permalink)
Looks like you're all set for electronics. Maybe a new ESC if yours is overheating, otherwise it should be fine.
Dogs come when called. Cats take a message and get back to you later.
Cailid is offline        Reply With Quote Quick reply to this message
Old 10-01-2009, 10:51 PM   #4 (permalink)
I ran the same setup for a long time and I still have it on my Blade #2 except I still run the stock gyro on it. Had two of the xm gyrds and neither one lasted more than a couple weeks.
If you want any future upgrades I would suggest metal gear servos and a real GY401.
If you have money burning a whole in your pocket I would suggest a good sim if you don't already have one.
#nodroneshere - 104
Old 10-02-2009, 01:23 AM   #5 (permalink)
If you got it second hand or new, tear it apart and rebuild it. That way you can be sure its built right.
spootman is offline        Reply With Quote Quick reply to this message
Old 10-02-2009, 06:53 AM   #6 (permalink)
While the hitec 65mg's are a great servo, the HXT-900 servos you have on cyclic will do just fine if you're still learning. They're plenty fast enough for hovering and mild 3D and FFF.
When you start constant 3D stuff, upgrade the cyclics to the hitecs and a better gyro.
jteee is offline        Reply With Quote Quick reply to this message
Old 10-02-2009, 06:54 AM   #7 (permalink)
+1 on a flight sim if you don't already have one.
Old 10-02-2009, 06:56 AM   #8 (permalink)
What is a good sim? Is there one that I can hook up my DX6i? Thanks for the information guys.
Mitch
Old 10-02-2009, 08:24 AM   #9 (permalink)
Real Flight or Pheonix are both good. I use Real Flight but people say Pheonix is more geared to helis.
FlyAndFix is offline        Reply With Quote Quick reply to this message
Old 10-04-2009, 01:40 PM   #10 (permalink)
Got a GY401 on order should be hear this week. I also picked up more replacement parts for my next crash.
Also looking at the Phoenix sim.
Thanks guys.
Old 10-04-2009, 01:46 PM   #11 (permalink)
+1 an absolute must to do...the setup you have is fine if your just starting out, you can always upgrade your servo's and gyro at any time.
65MG's are the weapon of choice for most unless you feel you need digital then 5065's for your gyro the choices are many, 401 will serve you well.
A larger ESC along with a BEC will insure cooler operating electronics on board.
nightflyr
JR9303 / JR9503 / Futaba10CHP
Old 10-07-2009, 12:14 PM   #12 (permalink)
Well I have the 401, CC BEC installed and am now just waiting for the DX6i to get back from the recall.
I also have a box awaiting my arival today at home. The Phoenix flight sim. But need the remote for that is well.
How long does it take to get the remote back? Do they e-mail you a tracking # when it ships?
Thanks for the help guys
Old 10-08-2009, 12:34 AM   #13 (permalink)
I sent three in, each come back within 3 weeks with a new AR6100. They didn't send me notice I don't think. They come back FedEx and went out UPS
Blade 400 X 8, CopterX CF SE V2 EXI-450, Clone CF V2 Pro
DX6 X 2, DX6i X 4 Need one? DX7 X1 not in use, it's CRAP!
Rotorjim is offline        Reply With Quote Quick reply to this message
Old 10-08-2009, 10:56 PM   #14 (permalink)
Default My reciever may have a short
Would someone please help me with my Blade 400? Today I was outside hovering when all of a sudden my tail rudder started to twitch. My first thought was my gyro rate was to high, so I lowered it, that did not stop the twitch. It was after about 4 min. of flight time so I changed to a new battery; that is when things got really crazy. All the servos started to twitch. I did a range test, which was fine. I put the heli on the bench to see what was wrong, I was first going to bypass the Gyro and check the rudder servo when I noticed that some of the servo plugs where fused together. After getting them separated and by-passing the gyro it still did not stop. I noticed that when I touch the receiver with my finger all the servos twitched. I removed the receiver and tested all servos and it seems like there is some kind of short in the receiver.
I would appreciate any help or feedback you might have for me.
Thank you in advance for your help.
Ickie is offline        Reply With Quote Quick reply to this message
Old 10-08-2009, 11:13 PM   #15 (permalink)
mine acted similar when my esc fried, do you check it for temperature? It's a good idea to check it after every battery, and make sure it's cool before you start it up again...i treat my esc temp sort of like my gas milage on my car, if my mileage is worse, something is probably wrong. if your temp goes up, something is probably not right, like your bearings, gear mesh, and belt tension. they fry pretty quick if you touch the leads backwards, i fried mine doing that, and afterward converted to dean plugs, because the leads don't touch unless you plug it in correctly...
Old 10-09-2009, 12:46 PM   #16 (permalink)
Seams the I fried my receiver. Just install the new one and It's fine. How can I tell if my ESC is any good? I have a temp. gauge the I use for my nitro cars. What is a good temp and what is to hot? The ESC never got so hot that I couldn't touch it but I it has gotten what I would call very warm. What is the # I should be looking for? Should I go to a 35A ESC?
Thanks for the help
Old 10-10-2009, 02:40 AM   #17 (permalink)
The # 1 thing to check is the voltage going to the Rx. If you are running the stock ESC then it should be 5.0V. The Rx can handle up to 9.6V but the servos only 5.0V. So if it is above 5.0V then don't connect it to the Rx. This would mean the internal BEC is bad. I would replace the ESC in that case even if it is still operating the motor.
If the BEC voltage is good then use your temp gun to check the ESC after a couple min of flight. It should be 100 - 160 deg F. Normal is probably 120 but it is totally dependent on ambient air temp. 160 would be hard flying on a hot day and would be stressing the ESC. Above that and something is probably wrong.
A 35A ESC with a external BEC would be the best setup and would give you the ability to go to a higher Kv motor in the future.
B400, DS285MG x3, DS3400G/GY401, CC ICE Lite 50, HK2221-8, Align 335mm Woodies, CNC Tail hub/grips, DX6i Tx
Blade mCX,Blade mSR
Flying Helis since April 09 Have mastered FFF ckts and nose in landings. Starting on mild aerobatics.
ingrahal is offline        Reply With Quote Quick reply to this message
Old 10-11-2009, 12:35 AM   #18 (permalink)
Just installed the Align 35G ESC. Seams to working good, haven't got out yet to fly hard. It was easy to install and program. My setup is 1-2-2-2-3. I think I made the right move, will see. Any other feed back would be helpful.
Thanks to all for your help, I will post back with my findings.
Blade 400/Hitec/Align
Old 10-11-2009, 09:26 AM   #19 (permalink)
Just got back from flying and here's the update. The new ESC is working great, temp. has not gone above 105 degrees doing some lite sport flying. What I have now a slow glitch in my rudder servo. You can almost but a stop watch to the glitch it is that consistent about 8 sec. apart. I tried to fix it with sub trim thinking that it was some kind on servo drift but it didn't help. The servo is a JR290DS gyro servo. Any thoughts on the glitch will help before I go out and buy another $40 servo.
One other Question: The new ESC has what look to be a magnet about 4" from the end of the servo plug.
1, Is it possibly causing some interference with the gyro.
2, Where should it be placed, in the bird or outside of it.
Old 10-11-2009, 12:52 PM   #20 (permalink)
I would do some bench testing and maybe try another servo before buying another. Do you still have the stock servo? Use it to toubleshoot the problem. I had a tail glitch when I first installed the DS3400G but it went away all by itself. ???
The ring on the ESC to Rx lead is not a magnet. It is a ferrite ring. It is there to supress noise. Just tuck in inside the frame.
Blade mCX,Blade mSR
