Go Back   HeliFreak > R/C Simulators Support > Phoenix Flight Sim
Phoenix Flight Sim Phoenix Flight Sim
Old 03-13-2010, 03:16 PM   #41 (permalink)
Default Update
O.K. I had a Esky USB adapter end cable, plunged into the Phoenix USB cable and then into the Esky 4 channel transmitter, calibrate and it worked perfect.
So I'm either not setting up the DX5e transmitter the right way or the transmitter is broken.
Millerzone is offline        Reply With Quote Quick reply to this message
Old 03-18-2010, 02:19 PM   #42 (permalink)
To the OP and all respondents...I've found this thread really helpful. Made the transition from RF G4.5 to Phoenix this week, and am highly impressed! So thanks to all
..there are many like it but this one is mine..
heli-c is offline        Reply With Quote Quick reply to this message
Old 03-20-2010, 09:39 AM   #43 (permalink)
ok.. i've read all the post and try'd the suggestions from what i can understand... and my 3d is NOT workin i have the HP6DSM tx and the Phoenix sim... when i go into "f mode 1" my collective pitch and throttle are maxed out ( any stick position) and my cyclic pitch and roll are all over the place .. colective pitch and throttle are set to ch1 and cyclic pitch ch 3 cyclic roll ch 2 ..... i dont get it .. im using the Blade 400 set with a lower weight ( about a lb less) to match my cpp2 and want to practice invert hover.. please help me... some body ... any body...... ?? i just dont get it
UPDATE:: to get invert i put throttle on ch5 and kept pitch on ch1 * DOWN SIDE* always at 0 or 100% throttle
it's not a competition, it's a hobby
EXI 450 + FUTABA t7c Tx =
Phoenix Sim "it's free to crash on a sim"
kevinbattista is offline        Reply With Quote Quick reply to this message
Old 04-07-2010, 11:32 AM   #44 (permalink)
Thanks to all for the setup tips. finally got to do inverted flight. Thank goodness these crashes are free
Heli-ADDICTION:
Xxtreme700, X7F and all Logos & 600esp (初恋)
Feeling of Hover at (28/12/2009) - PRICELESS!
feudallordcult is online now        Reply With Quote Quick reply to this message
Old 04-07-2010, 12:02 PM   #45 (permalink)
Hi Bum,
I just got my phoenis. Runs great. My questions is, I follow your instruction to copy the heli model and setup to heli # 2 on my DX7. How ever, how to change the pitch on the phoenix to be close to my set up 0-40-70-85-100. I see some pitch curve options which I can change it but there are no % reference once I change it.
oscarfeiby is offline        Reply With Quote Quick reply to this message
Old 04-07-2010, 12:28 PM   #46 (permalink)
Default Re: Phoenix Setup FAQ
If you followed the instructions in the first post for settings in the sim, the pitch curve in the DX7 will solely determine the collective pitch response in the sim. By copying the existing real model to a sim model and making the swash type change, you should already be there as far as the pitch and throttle curves are concerned.
HeliFreak Support
Graupner MZ-32
Old 04-13-2010, 08:07 PM   #47 (permalink)
Default Cant get throttle hold to work.
DX7 here, I went thru the FAQ and set my Idle up and T-hold to "unmapped", and now my idle up works but the T-hold does not. Not sure what to try next, any ideas?
hellafreaky is offline        Reply With Quote Quick reply to this message
Old 04-13-2010, 10:44 PM   #48 (permalink)
Did you enable TH in the model setup in the DX7? It's disabled by default on a reset model.
HeliFreak Support
Graupner MZ-32
Old 04-14-2010, 01:04 AM   #49 (permalink)
Aha! that was it, throttle hold was set to default "INH".
Bum, you are a genius, thanks you!
Old 04-18-2010, 03:17 AM   #50 (permalink)
Default How to get flaps to work
Can anyone help try to get my flaps setup for the sim?? I've got my radio (Walkera 2801 Pro) setup for both heli's and airplanes on the sim. In heli mode everything works great but when I switch to airplane mode everything works great but I cant figure out how to get my flaps to work??? Any suggestions??
Beating the air into submission!!!!
3d-wanna-b is offline        Reply With Quote Quick reply to this message
Old 04-21-2010, 01:57 PM   #51 (permalink)
Hello, I have a problem that does not appear here, or I did not see it.
first, sorry my English as I try to describe my problem.
I have a DX7 and recently bought phoenix sim. I did everything to calibrate from quick and factory design "dx7" set ups to advance and others.
my problem is that, when I use my left stick (engine) to go up or down, my right stick moves from right bottom corner to left upper corner. I have a t-rex 500 and fly with that radio, and it works just fine.
what could I do t solve it?
thanks
pierfe is offline        Reply With Quote Quick reply to this message
Old 04-21-2010, 02:03 PM   #52 (permalink)
It sounds like CCPM mixing is turned on in the DX7, which would cause the aileron and elevator channels to change whenever applying collective. You need to make sure the swash type is defined as "1 SERVO" in the model setup menus in the DX7 for the model you're using with Phoenix. Don't touch model in the DX7 for your real-life T500.
HeliFreak Support
Graupner MZ-32
Old 04-22-2010, 01:06 AM   #53 (permalink)
Guess not!!!
Old 04-25-2010, 10:52 AM   #54 (permalink)
Cool Futaba T7C
Hi,
I am a complete newbie and could really do with a guide on how to set up a Futaba T7C Tx to work properly with Phoenix
I need some simple step by step instructions about how to program T7C to get the best out of it or should I have bout a Spektrum DX7?
Kryten1967 is offline        Reply With Quote Quick reply to this message
Old 04-25-2010, 11:53 AM   #55 (permalink)
go into EDIT CONTROLS for your Tx ... detailed set up .. scroll down... you'll see "flaps" asign a button for them on the keyboard or a switch on the Tx
Old 05-01-2010, 05:48 AM   #56 (permalink)
Default TAIL DRFTS COUNTER CLOCKWISE IN HEADING HOLD
when i have full throttle and im in fff the tail drifts counter clockwise slowly while in heading hold (gyro)...it seems the tail rotor is not fighting the torque of the motor...likewise when i throttle down it slowly spins clockwise...is there a setting that im missing...i thought heading hold meant that it "holds"...
LL-Cool-T is offline        Reply With Quote Quick reply to this message
Old 05-01-2010, 08:59 AM   #57 (permalink)
sounds like a "mixing" problem NOT a HH prob. check the settings on each heli you're using and make sure your Tx is set up and calibrated correctly
Old 05-01-2010, 04:59 PM   #58 (permalink)
thanx kevin...exactly where should i be looking for these settings?
Old 05-01-2010, 11:01 PM   #59 (permalink)
it depends on your Tx but try re~calibrating the Tx in the Phoenix set up.. go to "system" " your transmiter" each channel should move just one sliding bar. if ch 1 and ch 2 or 4 move when you throttle up and down then your "mixing" is on in your Tx set up. the rest depends on what Tx you're using
Old 05-02-2010, 02:40 PM   #60 (permalink)
If you're haven't disable revo mixing, with a Futaba tx, do so. It won't drift any more.
WessCo is offline        Reply With Quote Quick reply to this message
