Old 07-07-2010, 04:59 AM   #1 (permalink)
Default VBar 4.0/5.0/Mini/regular/Blueline features
Here is an extensive list of the different versions.
http://www.vstabi.info/en/featurematrix
http://heli.dacsa.net
Old 07-07-2010, 05:25 AM   #2 (permalink)
Thanks for that, Cleared up many things about the new software and hardware.
2 x TDRII, 3 x TDR's, 2 X Logo's
OptiPower www.optipower.ch
Team pilot: Optipower, Bavarian Demon, Kontronik , Xblades, DryFluid
Paulice is offline        Reply With Quote Quick reply to this message
Old 07-07-2010, 10:34 AM   #3 (permalink)
That's interesting. 5.0 Express is crippled. I wonder how much the upgrade to full 5.0 will cost? Hopefully not $100. We'll soon find out I guess. It's almost mid July.
MSH Protos * 2, SAB 630, Logo 550SX
alexf1852 is offline        Reply With Quote Quick reply to this message
Old 07-07-2010, 04:15 PM   #4 (permalink)
Short summary of new functions for the people who don't go in detail through the featurematrix.
New in V.5.0
  • Setup wizard
  • Direct setup tabs
  • Cyclic adjustment (Precision adjustment during setup)
  • Collective adjustment (Precision adjustment during setup)
  • Voltage monitoring
  • Vibration monitoring
  • Extended vibration display (Spektrum analyzer)
  • Flight style settings
  • Event logfileGoverner
  • Event Logfile
Looks good
Note: No PDA software for the v.5.0.
Regards perfeet
perfeet is offline        Reply With Quote Quick reply to this message
Old 07-22-2010, 02:17 PM   #5 (permalink)
Can somebody tell me what these two features or improvements mean? Can this solve binding issues on non-Logo heli's? For example. The VBar 4.0 is actually based on a certain cheometry. Not all heli's have that same cheometry. I most cases I have seen you can get into trouble with binding and such. I hope this will add something new to it...
T-Rex 500E - JIVE 80+ LV + MINIPYRO 20-08 / BLS153 / CGY750 / BLS251
T-Rex 550E DFC - JIVE 100+ LV + PYRO 600-12 / DS610 / V-Bar / BLS251
T-Rex 700E DFC - ICE2 HV 120 + 750MX / BL700H / CGY750 / BL750H
wbplomp is offline        Reply With Quote Quick reply to this message
Old 07-22-2010, 02:20 PM   #6 (permalink)
Binding issues has always been able to be fixable, im v5 its easier, plus binding at min/max pitch is less on the bench (never happen in flight even in v4)
Old 07-22-2010, 02:31 PM   #7 (permalink)
Hi MrMel. Your quick in answering I won't argue with you because you know all about it. But I must say I do not fully agree. A few pilots at the field I have spoken ran into the same issue. With binding, I mean binding with servo arms hitting the frame or servo case. Most of them therefore use longer servo arms or set the cyclic ring so low that the flight charactiristics are not that good anymore. Like you fly with a totally wrong cheometry. So, I agree you can fix it, but it messes up your cheometry or control loop. Am I wrong? Or are there other options?
You can calculate your cheometry to find the best match. But it would be nice if you could program your own cheometry into the VBar.
Another thing I'm strugling with is the cheometric correction. As you know, when you have it enabled on a non-Logo heli you can get asymetrical collective and cyclic pitch. You can fix that by changing your endpoints and such. When you disable it you get binding even quicker because the then the pitch is way to high. Any suggestions?
When I see a Logo flying with a VBar it flies awesome. But other models with a VBar just don't seem to fly that way. That is my personal opinion though. Hope you can share your thoughts about it.
Old 07-22-2010, 02:46 PM   #8 (permalink)
Binding in servo cases etc really only matters if the total throw on the blades are less than 17-18 degree total (collective + cyclic) after that the blades will stall anyway, simply put it NEVER happens inflight unless your digging the heli out of s hole in the ground.
Geometry correction should be ON for all non mechanical mixing helis, period.
Else you get interaction.
V5 is better thow, cyclic ring is cone shaped, meaning less binding on bench.
Old 07-24-2010, 08:12 AM   #9 (permalink)
good comparison. In 4.0 , I can't seem to be able to adjust the tail servo center ( 90 degrees to pushrod) in same manner as the expert level swash ccpm buttons. Is 5.0 have the center centering button ?, or do I have to look for a servo arm that is closest to 90 degrees. I've tried subtrims on Futaba 10CHG, but it doesn't do anything to servo center.
4cyclic is offline        Reply With Quote Quick reply to this message
Old 08-03-2010, 09:36 AM   #10 (permalink)
Default mini vbar sensors
I can't seem to find what type of sensors are used in the mini vbar are they mems?
frito169 is offline        Reply With Quote Quick reply to this message
Old 08-03-2010, 09:41 AM   #11 (permalink)
Old Mini: Analog Devices
New Mini: InvenSense ( I think)
Both are MEMS, different manufacturer, different spec, different price
Old 08-04-2010, 12:25 PM   #12 (permalink)
I'm a beginner, and am about to set up my Trex 700 gasser with the V-bar. I am wondering if it is best for me to get v5.0 installed and use that when I do the initial setup?
Is it in anyway easier or simpler to setup and use then 4.0?
Anything that can simplify or make easier to understand for a beginner is very valuable to me.
Blade 400 FBL - CNCHeli frame, SK720, CC ICE 50 ESC, Sonix tail, RJX head, JR DS285MG cyclic servos, Hitec HS5084mg tail servo --- XAircraft Hexa, DJI WKM- XAircraft 650-V4 MCPX, 130x
dma251 is offline        Reply With Quote Quick reply to this message
Old 08-04-2010, 12:53 PM   #13 (permalink)
mbo
The gui is much more intuitive with images explaining what you should do in each step.
So I would definitly upgrade first.
mbo is offline        Reply With Quote Quick reply to this message
Old 10-17-2010, 11:53 AM   #14 (permalink)
Are there any downsides to the older black mini Vbar? I am planning on upgrading to the 5.0 pro software and using it on my new trex 550e. Please advise if the new bluline one is actually better and worth any difference in price. The black one I am contemplating is also spektrum satellite ready too.
jpinn is offline        Reply With Quote Quick reply to this message
Old 10-17-2010, 12:33 PM   #15 (permalink)
Nope.
Old 11-24-2010, 06:50 AM   #16 (permalink)
Didn't see an answer to this... I'm having the same problem. How do you center the tail servo???
~Cliffman~ is offline        Reply With Quote Quick reply to this message
Old 11-24-2010, 06:51 AM   #17 (permalink)
You cant, mechanicially only, select correct horn and adjust pushrod for adjusting tail
Old 11-24-2010, 07:33 AM   #18 (permalink)
It doesn't have to be perfect with a heading hold gyro anyway. I never center my tail servo, either with a VBar or a regular tail gyro, and have never had a problem as long as I get it as close as I can mechanically.
HeliFreak Support
Graupner MZ-32
Old 04-22-2011, 07:28 AM   #19 (permalink)
1) Is there difference in flight between "VBar Regular (black)" and "VBar Regular (BLUEline)" ?
2) Is possible that old sensor in BlackLine is better than sensor BlueLine ?
nono is offline        Reply With Quote Quick reply to this message
Old 04-22-2011, 07:42 AM   #20 (permalink)
Assuming you have vibrations sufficiently damped, no.
It depends on how you define "better". The black sensor is a little higher resolution, but the blue sensor is more vibration-resistant. It's not enough of a difference to be significant.
HeliFreak Support
Graupner MZ-32
