Old 09-01-2009, 05:20 AM   #41 (permalink)
don't bother i found out by myself :
10X19X5 Bearings
neohp is offline        Reply With Quote Quick reply to this message
Old 09-01-2009, 04:42 PM   #42 (permalink)
10X19X5
helicraze is offline        Reply With Quote Quick reply to this message
Old 09-02-2009, 06:32 AM   #43 (permalink)
thanks helicraze. I found a boca replacement on their website, as ready heli ran out. It's 28 dollars for 4 bearing...not cheap !
Old 09-02-2009, 07:39 AM   #44 (permalink)
Next time, go to rc-bearings.com. Four bearings will only cost you $12.76 plus shipping. Plus, Paul (the proprietor, nickname: RC-Bearings) is a frequent poster here and responds promptly to PMs, so you know you'll get great service.
HeliFreak Support
Graupner MZ-32
Old 09-02-2009, 11:16 AM   #45 (permalink)
thanks for the advice.
Old 09-02-2009, 01:02 PM   #46 (permalink)
They show as in stock at RH now.
Mikado Model Helicopters
Edge Blades
Big Fil is offline        Reply With Quote Quick reply to this message
Old 10-27-2009, 10:02 AM   #47 (permalink)
Quick question: Can you confirm that the Logo 600 can run up to 650mm blades?
Long Nguyen
Long Nguyen is offline        Reply With Quote Quick reply to this message
Old 10-27-2009, 03:09 PM   #48 (permalink)
I haven't tried 650mm blades on my 600, but the Mikado (Europa) website and the specs on ReadyHeli say that you can run 600/620/650mm main blades:
Specifications:
Rotor diameter: 1250mm to 1450mm
Rotor blades: 600/620/650mm
Main gear ratio: 8,1:1 to 12,9:1, Mod. 0.7
Weight: 3,2 kg and up
Battery: 6S to 10S LiPoly
However, I have yet to see any 650mm blades for sale anywhere in the US (that doesn't mean they don't exist)... The longest blades I've seen that fit on the 600 are 620mm, like the Gohbee 620. I was running 610mm RotorTechs until I got the 603mm Edge FBL mains.
BTW, congrats on getting that 600! You're gonna love it... (Also let me know if/when you're heading to OCMA again.)
/ES
ElectricSheep is offline        Reply With Quote Quick reply to this message
Old 10-27-2009, 08:57 PM   #49 (permalink)
Specifications:
/ES
I'm asking because I plan on running 630mm main blades and 95mm tail blades for my Logo 600. I think it's gonna be fine.
Thanks!
Long Nguyen
Old 01-19-2010, 01:06 PM   #50 (permalink)
Originally Posted by helicraze View Post
Please do not run over 2100RPM like i did for a while, it threw blade! I now run 2050RPM and its great with VBAR V4! Very fast.
This surely is an isolated event?
rotaryguy is offline        Reply With Quote Quick reply to this message
Old 01-19-2010, 01:27 PM   #51 (permalink)
I've run mine with 2400rpm++ and it was sick and only a flight test... my Logo stood in the air in whatever orientation I've put it
I would not recommend it to anyone and it's way beyond every limit blade builders specify. 2000rpm is more than enough in my opinion, and some blades like Maniacs don't need that much.
BBTs Insane 603 should be build for higher head-speed, maybe worth a look for every RPM-freak.
-Klaus
SuziLAOS-DNHP-CenturioMax-Protos500-Logo400-500-600SE
worldofmaya is offline        Reply With Quote Quick reply to this message
Old 01-19-2010, 02:56 PM   #52 (permalink)
That comment was in reference to those running 690MM rotors on the plastic grips.
NOT for 600MM rotors.
Old 02-06-2010, 02:51 PM   #53 (permalink)
Maniac blade is good ? I dont know nothing this blade.
thx.
Pilot Peter Martin My Galery: www.rcpilot.hu
martn1sw is offline        Reply With Quote Quick reply to this message
Old 03-27-2010, 07:31 PM   #54 (permalink)
I have been looking around for info on 5mm blade bolts, thought i saw it somewhere but now i can't find it. Has anyone drilled their blade grips so they can use 5mm blade bolts?
Sig Dawg is offline        Reply With Quote Quick reply to this message
Old 03-27-2010, 08:24 PM   #55 (permalink)
NTM
I drilled mine for 5mm a few years ago, it worked. There's no problem with hardened, full shank, 4mm bolts though.
Hey, I was down in Weyburn for a good chunk of last summer.
The wind is a pretty constant thing down there, always seems to be a blowing.
NTM is offline        Reply With Quote Quick reply to this message
Old 03-28-2010, 03:27 PM   #56 (permalink)
I am planning on stretching for AP, so with the lower headspeeds i'm sure the 4mm bolts wouldn't be an issue, just wanted to see if anyone has drilled their grips with success.
Yeah i had to get used to the wind when i moved here it can definitely be a pain in the a$$ some days.
Old 03-28-2010, 04:18 PM   #57 (permalink)
If you drill them then the nuts and head do not sit in so it would look kinda odd and maybe not the best idea.
Old 07-11-2010, 07:01 PM   #58 (permalink)
Just a quick question - is it possible to get a 2S 1300mAh ~ RX LiPo which will fit in my L500 any longer? The smallest size I can find is 2100mAh... Or should I just as well get a normal LiPo and solder a RX connector onto it?
Mathias
Lynx Oxy 3 | JR XG14
Mathias is offline        Reply With Quote Quick reply to this message
Old 07-12-2010, 12:32 AM   #59 (permalink)
I have a 2S 2100 30C hacker as an RX pack. It's strapped under the frame dead under the main shaft, so changing packs (different size RX pack that is) will not effect CG. You just need to make a small plastic "plate" and screw it to the 4 tabs on the base of the frame.
Logo 500SE, Logo 400SE, Mini Protos - Graupner/SJ MZ-24
Hati is offline        Reply With Quote Quick reply to this message
Old 07-12-2010, 12:39 AM   #60 (permalink)
Things you should know about your Logo: ITS AWESOME!!!
When you don't feel like soaring through the wind with a plane,, BEAT IT INTO SUBMISSION WITH A HELI!!!
XL 520 Stock motor, OMG cyclic servos, KST tail, HW 100amp ESC, Ikon 2 FBL.
Blades345 is offline        Reply With Quote Quick reply to this message
