Old 07-12-2010, 05:18 AM   #61 (permalink)
Originally Posted by Hati View Post
I have a 2S 2100 30C hacker as an RX pack. It's strapped under the frame dead under the main shaft, so changing packs (different size RX pack that is) will not effect CG. You just need to make a small plastic "plate" and screw it to the 4 tabs on the base of the frame.
I'm currently running a FlightPower RX 2S 1300mAh besides the ESC in front, but that pack is starting to get a little old, so I plan on changing it.
I will have a look at it - certainly don't want to re-do "all" my wiring...
Mathias
Lynx Oxy 3 | JR XG14
Mathias is offline        Reply With Quote Quick reply to this message
Old 07-12-2010, 05:19 AM   #62 (permalink)
Fair enough. I came up with that solution when I first built my SE, so everything was tailored to suit.
Logo 500SE, Logo 400SE, Mini Protos - Graupner/SJ MZ-24
Hati is offline        Reply With Quote Quick reply to this message
Old 07-13-2010, 07:10 PM   #63 (permalink)
I will probably just go ahead order this pack, and solder on a Deans female connector. Then I will make a conversion, which consists of one Deans male connector, a piece of RX-wire, and a RX male connector, which plugs into the RX-lead that goes into the RX itself...
Also, I'm running Deans connectors on my 6S Logo 500. I've never had a issue with that, but I see a lot of people nowadays that are running bullet connectors. Should I change?
Mathias
Old 07-14-2010, 03:05 AM   #64 (permalink)
I would change to EC5. They are very cheap at Hobbyking. Very good quality and won't come apart in flight, garanteed. You need force to seperate them.
My friends Logo crashed twice because Deans disconnected in flight.
Regards perfeet
perfeet is offline        Reply With Quote Quick reply to this message
Old 07-14-2010, 03:06 AM   #65 (permalink)
+1 EC5s are the shiznit for HV setups period, they lock in, awesome power throughput and overall the very best choice on 6S and up applications, for 6S and under the XT80s rock.
Mikado Heli
Scorpion Motors
Western Robotics RC,
Youth Generation Electronics
Old 07-14-2010, 03:09 AM   #66 (permalink)
+2 for EC5's! They are awesome
Old 07-14-2010, 04:27 PM   #67 (permalink)
I have a lot of soldering coming... Changing them on my Logo, I might just swap them on my 6S 450 Pro as well, don't you think?
Mathias
Old 07-14-2010, 10:41 PM   #68 (permalink)
EC5's on a 450? Hell no, haha. Plus on 6S you'll be pulling only around 25-30A peak.
What plugs are you running right now?
Old 07-14-2010, 10:47 PM   #69 (permalink)
I've started the transition from Deans to EC5s by starting out with EC5s on the batteries I have for my upcoming Atom 6HV. My Atom 500 will be next so that I can easily share the 6HV packs with the 500. Then I'll probably convert my Logo 500.
HeliFreak Support
Graupner MZ-32
TheBum is online now        Reply With Quote Quick reply to this message
Old 07-15-2010, 02:37 AM   #70 (permalink)
I would run EC3 on the 450.
Regards perfeet
Old 07-15-2010, 03:38 PM   #71 (permalink)
Currently running Deans on the 450. Reason asking is because then I will have the same connectors on all my equipment, making charging easy etc.
Mathias
Old 07-16-2010, 12:54 AM   #72 (permalink)
Deans are fine, especially for a 6S 450. IMO EC5's on a 450 would be ridiculously big and unnecessary!
Old 07-16-2010, 01:36 AM   #73 (permalink)
XT80s on 450s are awesome!
Mikado Heli
Scorpion Motors
Old 07-16-2010, 01:52 AM   #74 (permalink)
I think you mean XT60
Old 07-16-2010, 02:03 AM   #75 (permalink)
yea those, goto sleep young man!
Mikado Heli
Scorpion Motors
Old 07-16-2010, 02:05 AM   #76 (permalink)
It's later where you are, old man!!
Old 07-20-2010, 04:16 AM   #77 (permalink)
Ordered a set of e-Flite EC5s for my L500 last night.
As far as the 450, haven't ordered any XT60s yet, as the only place I can find them is at Hobbycity. Deans should work just as fine in this size, right?
Also, I asked this question in the Static discharge thread... Is it necessary to ground my L500 V-Stabi, and what is the best and easiest way to do so?
Currently servicing my equipment, so I have a few Qs...
Mathias
Old 07-20-2010, 04:25 AM   #78 (permalink)
The easiest way is to buy the antistatic kit from Mikado or Readyheli.
http://www.readyheli.com/MIK4358-Mik...t_p_37134.html
Regards perfeet
Old 07-20-2010, 08:07 AM   #79 (permalink)
They're plenty good enough for a 450.
HeliFreak Support
Graupner MZ-32
Old 08-04-2010, 10:01 PM   #80 (permalink)
Hobby City has EC3's for cheap. Awesome on a 450, they aren't the same as the larger birds but look identical if looks are a concern.
Conway V
Scene From Above Photography
www.scenefromabove.ca
Gaui X7 Cameraship
SFACV is offline        Reply With Quote Quick reply to this message
