Mikado Logo Helicopters Mikado Logo Helicopters Discussion |
07-12-2010, 05:18 AM | #61 (permalink) | |
I will have a look at it - certainly don't want to re-do "all" my wiring...
Mathias Lynx Oxy 3 | JR XG14 |
07-12-2010, 05:19 AM | #62 (permalink) |
Fair enough. I came up with that solution when I first built my SE, so everything was tailored to suit.
Logo 500SE, Logo 400SE, Mini Protos - Graupner/SJ MZ-24
07-13-2010, 07:10 PM | #63 (permalink) |
I will probably just go ahead order this pack, and solder on a Deans female connector. Then I will make a conversion, which consists of one Deans male connector, a piece of RX-wire, and a RX male connector, which plugs into the RX-lead that goes into the RX itself...
Also, I'm running Deans connectors on my 6S Logo 500. I've never had a issue with that, but I see a lot of people nowadays that are running bullet connectors. Should I change?
07-14-2010, 03:05 AM | #64 (permalink) | |
My friends Logo crashed twice because Deans disconnected in flight.
Regards perfeet |
07-14-2010, 03:06 AM | #65 (permalink) | |
+1 EC5s are the shiznit for HV setups period, they lock in, awesome power throughput and overall the very best choice on 6S and up applications, for 6S and under the XT80s rock.
...Once upon a time there were Nitros, flybars & frequency pins...Shawn |
07-14-2010, 04:27 PM | #67 (permalink) |
I have a lot of soldering coming... Changing them on my Logo, I might just swap them on my 6S 450 Pro as well, don't you think?
07-14-2010, 10:41 PM | #68 (permalink) |
EC5's on a 450? Hell no, haha. Plus on 6S you'll be pulling only around 25-30A peak.
What plugs are you running right now? |
07-14-2010, 10:47 PM | #69 (permalink) |
I've started the transition from Deans to EC5s by starting out with EC5s on the batteries I have for my upcoming Atom 6HV. My Atom 500 will be next so that I can easily share the 6HV packs with the 500. Then I'll probably convert my Logo 500.
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Protos Max Evo 700 (Brain 2), Protos Max V2 770 (iKON 2), Synergy 516 (Brain 2), Oxy 2 (Falcon 12) Graupner MZ-32 Experience is something you gain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
07-15-2010, 02:37 AM | #70 (permalink) |
I would run EC3 on the 450.
Regards perfeet |
07-15-2010, 03:38 PM | #71 (permalink) |
Currently running Deans on the 450. Reason asking is because then I will have the same connectors on all my equipment, making charging easy etc.
07-16-2010, 12:54 AM | #72 (permalink) |
Deans are fine, especially for a 6S 450. IMO EC5's on a 450 would be ridiculously big and unnecessary!
07-16-2010, 01:36 AM | #73 (permalink) |
XT80s on 450s are awesome!
07-16-2010, 02:03 AM | #75 (permalink) |
yea those, goto sleep young man!
07-20-2010, 04:16 AM | #77 (permalink) |
Ordered a set of e-Flite EC5s for my L500 last night.
As far as the 450, haven't ordered any XT60s yet, as the only place I can find them is at Hobbycity. Deans should work just as fine in this size, right? Also, I asked this question in the Static discharge thread... Is it necessary to ground my L500 V-Stabi, and what is the best and easiest way to do so? Currently servicing my equipment, so I have a few Qs...
07-20-2010, 04:25 AM | #78 (permalink) | |
http://www.readyheli.com/MIK4358-Mik...t_p_37134.html
Regards perfeet |
07-20-2010, 08:07 AM | #79 (permalink) |
They're plenty good enough for a 450.
08-04-2010, 10:01 PM | #80 (permalink) |
Hobby City has EC3's for cheap. Awesome on a 450, they aren't the same as the larger birds but look identical if looks are a concern.
Conway V Scene From Above Photography www.scenefromabove.ca Gaui X7 Cameraship |
