Old 08-02-2010, 07:42 AM   #41 (permalink)
Originally Posted by pinguin View Post
If I max out the ATV on the gyro, the tail will bind. Can I use Dual Rate to limit the travel? Would that be different than ATV?
I use Turnigy gyro that has no delay. I try MKS DS470, D922, TP MG90s and Esky servo, but my tail bounces at piro stop. Any suggestion what should I do?
Remember that every gyro has its own instructions. Follow that first.
If you have a simple gyro(no delay, no limit setting) then you can try to use a hole on the servo arm that is closer to center. This effectively can make the servo throw the same as the limits so that you do not have binding. It also can help with bounce.
ATV's/Endpoints etc is never the way to set the limits when you have a gyro. It is for setting how fast the maximum piro rate is going to be.
Do the above UNLESS your gyro instructions say otherwise.
Trex 450 Pro 3xDS410M + MKS8910A+, Align FBL head w/Microbeast, CC 45 [email protected] 3400rpm(max timing, outrunner mode), Scorpion 2221-8 on 14t, Edge FBL main and tail, CF boom, CC BEC @ 6V
airjawed is offline        Reply With Quote Quick reply to this message
Old 08-02-2010, 04:09 PM   #42 (permalink)
The dual rates won't help stop binding, it'll just slow your max piro rate
For your Turnigy gyro, try using a different servo arm hole. Sometimes moving to a closer in hole (you may have to drill) will help reduce bounce.
bwoollia is offline        Reply With Quote Quick reply to this message
Old 08-03-2010, 08:56 PM   #43 (permalink)
I take your advice. I am able to make the ball only 3mm from centre. It does help, but still has a bit of bounce, but I'm able to increase my gain.
The piro is slow, I have end point and dual rate set to 140.
pinguin is offline        Reply With Quote Quick reply to this message
Old 08-03-2010, 09:08 PM   #44 (permalink)
What heli is this for? Many flying the T-Rex 250 have switched to shorter tail rotor blades as well to reduce bounce.
Old 08-03-2010, 11:30 PM   #45 (permalink)
It's a CX250
I have 37mm tail blade with chinese weight grip, CF rod, metal tail bellcrank.
Old 08-04-2010, 02:27 PM   #46 (permalink)
Read my advice on bounce over again. It may be from having a slow tail servo, low tailspeed or from something having play in the tail control. In your case it may not be due to the delay setting.
Old 08-04-2010, 08:25 PM   #47 (permalink)
I guess because I only have 3mm from centre, I don't have a lot of movement on the slider.
Old 08-04-2010, 09:15 PM   #48 (permalink)
I am not familiar with that heli but is it basically a stock setup? Is the headspeed low or relatively high?
You need to be able to use the entire slider range...full pitch at the tail.
Old 08-04-2010, 11:57 PM   #49 (permalink)
If I have 5mm, I will have a full range, but with lot of bouncing.
I will try with my GY240 or get another gyro with delay.
I don't like this Turnigy gyro anyway, I can't get rid of the creep.
Thanks for your help.
Old 09-08-2010, 12:54 PM   #50 (permalink)
subscribed
celm is offline        Reply With Quote Quick reply to this message
Old 09-08-2010, 04:45 PM   #51 (permalink)
Read the thread, most interesting. Anyway, I tried it and it worked good.
My servo, a S3155 wasn't fast enough. At the end of many settings, the servo responded well, better that I expected. Then some $$$ came along and I changed
for a 9257. Still, very good info, past the thread to a couple of guys, all were happy.
Would like to thank you.
sly the dogman is offline        Reply With Quote Quick reply to this message
Old 09-08-2010, 07:05 PM   #52 (permalink)
if the GY48V gyro is a knock off of the 101,in the GY instructions it says if your using a digital servo to set delay to zero
Old 09-08-2010, 09:18 PM   #53 (permalink)
I think your answer lies in the first post of this thread.
Old 09-08-2010, 09:21 PM   #54 (permalink)
Celm, Remember the instructions are being translated. The instructions for all of the knock off's read the same. Almost verbatim to each other. As airjawed said, the instructions should say 'closer to - 0'.
The art in flying RC Helicopters lies in learning how to throw it at the ground and miss.
Tarot 450 Pro - Chaos 500
grawyl is offline        Reply With Quote Quick reply to this message
Old 09-08-2010, 09:36 PM   #55 (permalink)
Great to see the info is helping people out! I appreciate the appreciation!
Old 10-14-2010, 09:05 PM   #56 (permalink)
I did not know this information on delay existed!! For the past week I have been messing with everything except for delay. I had not thought of it cause this isn't in the stickies or setup 101!
Every question involving tails and wags had already been asked, found them in search.. All the answers have to do with gain, mechanical setup, or curves and none helped.
I had tail wag only occuring on quick throttle down in hover and a bounce when stopping from hard piros. I had waaay too little delay.. Now i have my stock GP780 + DS420M working perfect. Thank you very much.
Can this please be stickied and added to the heli setup 101 for reference?
Align Trex 450 Sport - Align Metal control arm and Metal VSM
- Spektrum ar6110e Rx, Airtronics 94809s, Hyperion 3s 2200mah 35C
- Align 325mm Pro / 325D Carbon Blades, KBDD Flybar Paddles + Tail Blades
Spektrum DX7 - Phoenix R/C Flight Sim
Walkera 4G6S
Intact is offline        Reply With Quote Quick reply to this message
Old 10-14-2010, 09:38 PM   #57 (permalink)
Originally Posted by Intact View Post
INow i have my stock GP780 + DS420M working perfect.
how you get that combo to work??
Old 10-15-2010, 11:01 AM   #58 (permalink)
Great that it worked for you! I'll see if I can get it stickied and hopefully more people can get benefit from it that way.
Old 10-15-2010, 10:04 PM   #59 (permalink)
Worked great for me also...thanks for these great posts!
mjcelli is offline        Reply With Quote Quick reply to this message
Old 10-16-2010, 04:15 AM   #60 (permalink)
+1 on stickied
and thank you for this article. I hope there will be more articles about gyros, and heli info in the future from you. This has really been helpful for me.
pitchp is offline        Reply With Quote Quick reply to this message
