Old 09-29-2010, 10:48 PM   #41 (permalink)
I was curious if anybody has the logo 500/600 tail gear above the main gear - part number mik4059. That would be greatly appreciated, readyheli is out.
I also have available a used set of blade grips/spindal/thrust bearings assembly for a logo 500 if anybody is interested. I just upgrade the grips to the logo 600 14mm size. Let me know!
Jason Chow is offline        Reply With Quote Quick reply to this message
Old 09-30-2010, 03:44 PM   #42 (permalink)
I don't know if Jason found one of these parts, but I'm also needing a MIK4059 to finish up a Logo 600.
I've got a bunch of new and used Logo 400 parts and a few 500 parts. Let me know what you need and I'll see if I have it.
flymustangs is offline        Reply With Quote Quick reply to this message
Old 10-17-2010, 03:49 AM   #43 (permalink)
Anyone local that have MIK4183 (Main Gear 106T)? I have couple of parts i can trade, I have the full head that includes shaft, grip assembly, swash driver and swash. I also have 600 belt (Non SE). All parts I have are used BTW...
sil40sx is offline        Reply With Quote Quick reply to this message
Old 10-17-2010, 09:06 AM   #44 (permalink)
Originally Posted by BennyTRD View Post
Got some stuff left over from my 500 to 600SE conversion. The grips come with complete bearings that are smooth, and shafts are straight. 2 NIP 86mm spindles, 2 NIP CHP Landing gear braces, CHP horizontal and vertical fins, 500 boom case, 1 used set of 500 landing skids, and 1 NIP. Also not pictured are a couple of spare 500 belts that are in good shape for re-use.
Also I have 2 500 Canomod canopies that I no longer need. The Phantom has only been flown a few times and is in like new condition. The Cadmium was involved in a crash but is still very servicable. I had Canomod put my name on them, but that can easily be covered up by a new sticker or paint.
See anything you need, let me know. Might be interested in 600SE parts in they are in like new condition.
I know this is a swap thread, but I dont have anything you need...but you could use the money Im willing to pay for a canopy to buy some 600SE parts
TRCHK
BorgeBorge is offline        Reply With Quote Quick reply to this message
Old 10-17-2010, 11:10 AM   #45 (permalink)
Sil40sx....I have one, but am down in SD......Let me know if you want to try to work something out....
jakeg1999 is offline        Reply With Quote Quick reply to this message
Old 10-17-2010, 11:36 AM   #46 (permalink)
I've already placed my order from RH,.. do you need sumtin I have though?
Old 10-19-2010, 04:04 PM   #47 (permalink)
I'm converting to mod 1 gearing, so I've got some mod 0.5 maingears and pinions that are free to a good home:
https://www.helifreak.com/showthread.php?t=250419
trex 450: 350mm, 4s 2200, 450m 12T, hs5065mg, beastx+s9257, ice 50, 3000rpm, R6203SBE
logo 500se: 623mm, 12s 3000, xera 4025 560 15T, ds20-fmd, beastx+s9254, ice 80hv, 2000rpm, R6203SB
member ACM, AMA, AOPA
xatled99 is offline        Reply With Quote Quick reply to this message
Old 10-19-2010, 04:57 PM   #48 (permalink)
I have a 600 boom and belt, has 9 flights before I installed a 600SE boom and belt.
steffgiguere is offline        Reply With Quote Quick reply to this message
Old 10-30-2010, 06:50 PM   #49 (permalink)
anyone want to swap a pyro 700-52 for my pryo 700-45?
Dan
dhoff002 is offline        Reply With Quote Quick reply to this message
Old 11-03-2010, 07:25 PM   #50 (permalink)
I have a full size back sensor vBar with 5.0 Pro to swap for a Blueline miniV!!!!! Preferably NIB.
1 - Diabolo 1 stuffed with, well, see below
2 - Diabolo 2 stuffed with testosterone, jittery sweat, and rippling flanks
OverTemp is offline        Reply With Quote Quick reply to this message
Old 11-04-2010, 04:25 PM   #51 (permalink)
i have some maniac 553mm blades i would like to swap for some edg fbl 553mm blades.
there as good as new but have to much pop for me,
0utrage fusion 50,
hk-4025 630kv scorpion.12s, v-bar, kontronik,
Sponsored by hobbymaniac
Proud to be a Maniac!
hawkins221 is offline        Reply With Quote Quick reply to this message
Old 11-07-2010, 01:33 PM   #52 (permalink)
NVM
brian94066 is offline        Reply With Quote Quick reply to this message
Old 11-07-2010, 03:01 PM   #53 (permalink)
I got a Blueline Mini on my Trex 700 E conversion. Got under 20 flights on it.
I might want to swap....
TRCHK
Old 11-12-2010, 06:06 PM   #54 (permalink)
I just upgraded to a SE, so I've got a stock 500 boom, belt, struts, and pushrod that need a home.
Old 11-15-2010, 11:21 PM   #55 (permalink)
Im looking for the quick uk tail or rjx tail and can't seem to find them in stock anywhere. does anybody have one of these
Old 11-16-2010, 05:02 AM   #56 (permalink)
I just bought a Quik UK Trex 600 tail and put some balls on it
TRCHK
Old 11-16-2010, 10:54 AM   #57 (permalink)
Konrad, how does that compare to the original one for the logo. Im not too sure how the design differs and what I need to change. Please let me know! thanks.
Old 11-16-2010, 10:57 AM   #58 (permalink)
Jason, I just bought one from rjxhobby.com. Complete tail blade assembly, slider and arm cost me US$ 88 delivered to my door by DHL.
Perfect fit - all I had to do was cut off the untreaded part of the brass slider - a 2 minute job. They have a choice of CNC or plastic blade grips I went for the plastic because they would have a little more give. It is also beefier than stock Mikado.
okteister1 is offline        Reply With Quote Quick reply to this message
Old 11-16-2010, 03:26 PM   #59 (permalink)
what was the part number for the tail assembly?? I checked their site and i can't find much of anything i want...
Logo 600sx, 8717s, 8900g, VBar, Pyro 700-45, Jive
T-Rex 450 SE V2 HS-65 MG's, Quark/9257
T-Rex 450L Dominator - All stock except mini VBar
Blade Nano CP-S
Dirtmagnet400 is offline        Reply With Quote Quick reply to this message
Old 11-16-2010, 05:40 PM   #60 (permalink)
Ok go to rjxhobby.com. go to Extreme 50 Nitro spare parts,
X800-60528 is plastic tail blade holder assembly or X800-60528M if you want metal one.
X800-60050 is Tail pitch slider assembly.
XT60054 is tail pitch control lever.
Like I already said its a perrfect fit - all you have to do is cut off the untreaded part of the brass slider and round off edge wyth a little bit of sandpaper - a 2 minute job and you are set to go. Doing this adds more throw on that side. Hope this helps
