Old 04-28-2011, 12:24 PM   #1 (permalink)
Default Rethink on trottle/pitch curves on electric heli
I went out flying yesterday and crashed my 500 electric . The wind was blowing about 10knots but the 500 handled well in normal fig8 flights. The problem came in at landing time. Brought the heli nose into wind slow FF to heli pad. 2Meters form the ground on it's way to the helipad it flipped right and crashed hard. At that time I had to bring the throttle down to 1/4 stick. When the heli flipped it was if I had no aileron stick control. At first I thought one of the aileron servo's failed, at home confirmed it did not.
My throttle/pitch curves I was using are TH-0%,50%,70%,85%,100% PI-30%,40%,50%,75%,100% which relates to -4,-2,0,+5,+10 degrees.
I had to drop the throttle stick to 1/4 to get the heli down from 15m. The wind just kept it in the air. @ 1/4 stick the blades are @ about -3 but the head speed dropped to 50% of 2200rpm or less. @ that speed and below you lose cyclic and tail control. The reason why it went to the right was the advancing blade created more lift when a gust blown over it, tilted right and just dropped down.
On Nitos you normally have a governor that keeps the head speed constant and you can use the full pitch curve range. On a TH curve like I had, you an only use pitch range when head speed is above 1800rpm which was effectively 50% and upwards.
On clam days this would not apply as I land the heli just below 3/4 stick.
I am going to change my Idleup1 to be more flat, running from about 70% to 100%. Only then can I realy use the pitch range from 0 to -4. I think of stating in normal mode, then once in hover change to Idleup1, Idleup2 stuntmode only
Any other pilot with the same kind of experience?
ChrisGB is offline        Reply With Quote Quick reply to this message
Old 04-28-2011, 01:31 PM   #2 (permalink)
Idle up with soft start at start of flight
Hover 2' above ground in idle up when landing and hit throttle hold.
Never even need normal mode.
That is the best combo I have found on the T500.
The 500 loves HS and idle up is the best way to get it.
Idle up 1 is flat at 90%
Idle up 2 is flat at 100%
Or use a gov at somewhere between 2600-2800 RPM's
fastflyer20 is offline        Reply With Quote Quick reply to this message
Old 04-30-2011, 03:58 PM   #3 (permalink)
Anyway, if you're not slamming down throttle stick when in trouble, make TC at 1/4 70%. If supported by your TX you may also want to move the 2nd point anticipating it at 10% stick.
ziper_it is offline        Reply With Quote Quick reply to this message
Old 05-01-2011, 05:10 AM   #4 (permalink)
Thanks guys, it makes sense, I changed my Idleup 1 all 70% for a start, will go to 80% or more once my flying demand increase. I start the heli in N mode, in hover change to Idle1 to fly around. At landing and can hit the Th-Hold/or switch to N mode switch to stop the motor.
Great.
Old 05-01-2011, 08:11 AM   #5 (permalink)
Perfect, you got it.
Two more ideas
1) You can increase head speed even higher, try 90% too, the 500 loves HS.
If you can't tell the difference, just decrease it.
2) Make sure soft start is enabled on ESC, you can then flip to idle up 1 on the ground, motor will safely and slowly spool up. Now normal will be rarely used, and saves some switch flipping while in the air.
Old 05-03-2011, 05:25 AM   #6 (permalink)
My NORM mode is setup the same as IDLE1 and IDLE2, w/ slightly different head speeds. Works great.
Rush 750 w/ Xera 4530-500 (12T), YGE160HV, WR S.BEC, Torq 9180/9188, AR7200BX
Outrage 550 w/ Scorp 4020-1390 (13T), YGE120, CC BEC Pro, Quark, MKS BLS980, Futaba BLS451
wolfdown is offline        Reply With Quote Quick reply to this message
