Old 10-02-2011, 10:36 AM   #1 (permalink)
Default trex 600efl pro vbar express file
here is my file.
carlocivicsi is offline        Reply With Quote Quick reply to this message
Old 10-02-2011, 10:40 AM   #2 (permalink)
E Pro, those are not very good geometry on, what distance are you using on the servo horn?
Are you getting 8 degree @ 72 in the Cyclic step?
http://heli.dacsa.net
Old 10-02-2011, 10:51 AM   #3 (permalink)
Im going by the manual im using the outer holes. Stock align servo arms. Yes I'm getting 8 degrees.
Old 10-02-2011, 10:53 AM   #4 (permalink)
You need to move them inwards.
Start with trying inner hole, what that might be.
Reset DR and see what you get at Cyclic step.
Old 10-02-2011, 12:44 PM   #5 (permalink)
Someone at our club did find the corrections to make to get good vbar values. I can check for you but what I remember is to swap the ballinks of the mainbladegrips with the one they are connected do on the swash, and change the outer swash ones (that go to the servos) with mikado logo ones.
-TT E700 V2-vbar-mks950-980-Kosmik 160HV-Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+Spirit Pro
velocity90 is offline        Reply With Quote Quick reply to this message
Old 10-02-2011, 03:24 PM   #6 (permalink)
look my problem is that i have to much cyclic and i don't know how to adjust it. (IM RUNNING ESPRESS) someone told me with the dr some tell me not to touch that. so how do i determine how to adjust the cyclic pitch. I've been searching and i can't find the solution.
IF i reduce the cyclic with dr the servers travel slow.
i just want a straight answer in what to do. thanks
Old 10-02-2011, 03:25 PM   #7 (permalink)
Straight answer already posted, you NEED to make changes mechanically to you helicopter, there is no setting in express or pro that can fix this.
Cyclic step should be above 80
IF you hen get binding, you can upgrade to pro to get yclic ring function.
But on the bench you should NOT look at how many degree total cyclic you have, 10, 12 or 15 does not matter really.
Old 10-02-2011, 04:03 PM   #8 (permalink)
here is the link to a video that i just made explaining whats my problem.
[ame]http://www.youtube.com/watch?v=a_Q-j4PzZX8[/ame]
i dont change it to the inner holes because if you read this thread on comment 23 and 25 they say that the links pop off and other people have concluded that its best to have it the way the manual says. i could be wrong, they could be wrong all i know is that it says that the links have pop off and it could happen in flight. I'm not about to crash my $$$ heli.
i don't know what to do. the link is below look at comments 23 and 25 specifically. and read more if you want.
https://www.helifreak.com/showthread...=318766&page=3
Old 10-02-2011, 08:12 PM   #9 (permalink)
I have a Trex550 which basically has a 600 head but you have tilted geometry corrected servos.
Do all pitch tests in the related setup mode only.
Thats how you could adjust a Flybar heli but NOT a Flybarless heli using Vbar. All of the great features of the DX8 are basically thrown away because that's moved into the vbar. I Moved the servo ball links to the inner most ones using metal align servo horns. If you didn't do that you would get 70 at best. I was flying my 550 at 70 & it worked ok but i would take the advice from MrMel & keep it above 80. I doubt you would ever pop a link off because the vbar most likely wont let it go that far. The reason being is that it will look at the sensor roll/flip rate vs your agility slider value vs your stick input & roll the heli at x rate. As a VERY rough guess less than 8 degrees max as a heli without a flybar is uncontrollably quick.
In setup they do bind at full collective then pushing full elevator etc but don't worry you will never reach that in flight. The guy who popped the link off is probably one person in the world who has done it & doing something very wild (a video of it happening would be nice). I guess see if you can get a link to pop off i bet your servos will screaming to do it. So to sum up its possible to reach binding with the gyro out of the control loop (e.g sitting on bench or in setup mode) but not realistically possible in flight.
heliwaz is offline        Reply With Quote Quick reply to this message
Old 10-04-2011, 11:26 AM   #10 (permalink)
here is the file tim after want i mentioned in the PM. thanks for the help.
