Protos 500 + BeastX - HeliFreak
Old 09-27-2011, 05:26 PM   #1 (permalink)
Default Protos 500 + BeastX
Hello all Protos pilotes!
Just wonder if annyone have a good vid of setting upp the Protos with the beastX?
Jörn
JOHA is offline        Reply With Quote Quick reply to this message
Old 09-27-2011, 10:38 PM   #2 (permalink)
I don't have a video but I do have Protos/BeastX experience. The manual is a little overwhelming but it will make sense once you get into it. Don't worry about how long you take on each step, mine never timed out on me. The only confusing part for me was the decision for type or rx., the standard setting is for any rx. not listed including a standard Spectrum rx.. The Spectrum setting is for satellite only. When I used the standard rx. setting, I couldn't get to the fail safe setting to come up. Matt
byHISgrace is offline        Reply With Quote Quick reply to this message
Old 09-27-2011, 10:49 PM   #3 (permalink)
When you use a standard Rx with BeastX, there is no Failsafe mode as your Rx has the failsafe in it. I havn;t converted my Protos yet, but soon!. My Blade 400 now flys awesome with BX. And it really isnt hard to set up. If you read the instructions first before install, I find it is confusing. Install it with instructions, step by stem an when you are finished, it should all be clear what does what and such
Oh and upgrade to V3 if you get V2 one!
Dan Pesonen
mCX2, nCPX, mCP X, Blade 400, MSH PRÔTOS, T-700N
"Tri-Flow"
banditpowdercoat is offline        Reply With Quote Quick reply to this message
Old 09-27-2011, 11:29 PM   #4 (permalink)
just got mine setup, barely got blue on max cyclic but got it on the 6 degrees. no binding with 11.5 and 12 pitch. did a test hover and it was awesome. nice and stable and i flipped it a couple of times. was to dark to do any more, ill have a vid of mine tomorrow. will post some pics of the finished one in the pic section.
It is very easy to set up. New v3 makes v2 look like a 3g system
tacomaster is offline        Reply With Quote Quick reply to this message
Old 09-28-2011, 12:31 AM   #5 (permalink)
Taco and others can you post naked pictures of your wiring of the beast looking for ideas for when mine gets here.
Synergy E7
Synergy E5
Prôtos mini 450
Sharkbait is offline        Reply With Quote Quick reply to this message
Old 09-28-2011, 01:53 AM   #6 (permalink)
here ya go also i have a reg for the servo, bec pro and im using an external receiver so it has 3 more wires.
ID:	256678   Click image for larger version
Old 09-30-2011, 10:34 AM   #7 (permalink)
Default Headspeed + batterys
Hello!
Got about 2500 in head speed too day, it feels real nice.
I use 2600 mah desire powers 6S lipos, ang get about 6 minutes of flight time.
I allso have som 6S 4000 mah Turnigy batterys fore one of my "planks" - what do you guys think - are they too big - weight/mah?
I am using stock motor and stock yga 60a esc.
Thanks!
jörn
Old 10-02-2011, 11:09 AM   #8 (permalink)
Default wiring pics
here is some wiring pics, the only part that screwed me up on the beastx was the piro compensation but just watch the vid
ID:	257498   Click image for larger version
ID:	257499   Click image for larger version
ID:	257500   Click image for larger version
keither1984 is offline        Reply With Quote Quick reply to this message
Old 10-02-2011, 04:12 PM   #9 (permalink)
Here are some more wiring pics.
ID:	257571   Click image for larger version
ID:	257572   Click image for larger version
chopman is offline        Reply With Quote Quick reply to this message
Old 10-03-2011, 09:24 AM   #10 (permalink)
Great wiring guys.. Everyone I've talked to says beast was made for Protos, are you guys running v2 ? Should I try v2 then if not happy upgrade to v3? Thanks in advance
Synergy E7
Synergy E5
Prôtos mini 450
Old 10-03-2011, 10:55 AM   #11 (permalink)
skip v2, go v3
seriously, v2 sucks bad compared to v3.
Old 10-04-2011, 12:58 AM   #12 (permalink)
this is how i mounted mine
click for zoom
my Prôtos twins & Acrobat Shark
urgno is offline        Reply With Quote Quick reply to this message
Old 10-08-2011, 10:28 PM   #13 (permalink)
Thanks for all the great examples this is how mine ended up
ID:	258881   Click image for larger version
ID:	258882   Click image for larger version
Synergy E7
Synergy E5
Prôtos mini 450
Old 10-09-2011, 11:45 PM   #14 (permalink)
all looks good , i have a protos coming my way , I will probably use a MB , very curious to see how it compares with my Logo 400 ...
1 good trick with the MB is to put a strip of hot glue on all the plugs as they like to get loose , had that happen , and you know what happened next
DIABOLO - Spirit
goblin 500 Sport-- Spirit
TDR 1 2011-- Spirit
Kasama Faifa 700 -- Spirit
joliecoeur13 is online now        Reply With Quote Quick reply to this message
