Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite)
Blade Helicopters (eFlite) Blade Helicopters (eFlite) CP, CX, mCX CX II, CX III. and others
Old 05-12-2007, 10:08 PM   #21 (permalink)
WhirlingBladesOfDeath,
I am using the DX7 and the AR6100 also. I use throttle hold to arm the gws t.motor esc. When I put throttle hold on, the rudder goes full left. It's also a safe way to plug in the lipo. I give it a few seconds to arm, flip the switch, and fly. Yes the t. motor does spin once I turn it on. I haven't found a solution to that, yet.
orlbuzz
Never Grow Old
AMA 582235
BCPP, T-Rex SA, HBKII , HBKIII RTF , mSR, Blade McpxV2, McpxBL, and Nano cpx
All under control of DX7
orlbuzz is offline        Reply With Quote Quick reply to this message
Old 06-09-2007, 04:39 PM   #22 (permalink)
i got the esc50 as it said it was for lipos and not the isc50, will that be a problem?
robl is offline        Reply With Quote Quick reply to this message
Old 06-16-2007, 04:37 PM   #23 (permalink)
any overheating with the 4530 prop? I think thats part of my problem, the 3020 prop isn't holding for crap.
Old 06-20-2007, 12:54 PM   #24 (permalink)
It didn't hold for us either. We run the heat sink on the motor. No overheating problems.
rstacy is offline        Reply With Quote Quick reply to this message
Old 07-24-2007, 10:42 PM   #25 (permalink)
could u please tell what adapter was used?
sukhoi is offline        Reply With Quote Quick reply to this message
Old 07-24-2007, 11:13 PM   #26 (permalink)
bphobbies.com
i think thats where i got mine.. neways there is a kit that comes with the 4530 and the adapter.. if i can find mine, i can drop it in the mail to you..i dont have the prop tho..
txflyer is offline        Reply With Quote Quick reply to this message
Old 07-25-2007, 06:50 AM   #27 (permalink)
i've been trying to get the heatsink and adapter, supposed they are backordered for about 22 years or so. Thats not a typo, thats what the local hobby store told me when they talked to their distributor.
Old 08-28-2007, 01:27 AM   #28 (permalink)
I have tried running a GWS DD tail with the 4530 twice now with the proper adapter and blown both motors within 5 minutes of hovering. I had to go back to the 3020 push on prop which seems to lose hold randomly. I am not sure what the deal is but I do have the heatsink attached. I am almost ready to go back to the original tail setup. I am running separates with a GY240 and DX7 transmitter/AR6100. "shrug"
Smiley is offline        Reply With Quote Quick reply to this message
Old 09-05-2007, 09:26 PM   #29 (permalink)
Default Hey Ray
I'm Back
I just got a Blade CP.
At least this will keep me semi active.
The bike season is coming to an end.
3D TIME!!!!!!!!!!!
Chris
Chris Reibert is offline        Reply With Quote Quick reply to this message
Old 09-20-2007, 02:06 PM   #30 (permalink)
Default GWS tail motor
Hello there I like to know where in the web you can buy a GWS tail motor for the blade cp pro thanks for all tyour help
RC heli all the way
alucard is offline        Reply With Quote Quick reply to this message
Old 09-23-2007, 08:54 PM   #31 (permalink)
i get mine at bphobbies.com. this is the one i use here http://www.bphobbies.com/view.asp?id...098&pid=gws100
ed garcia
knight 3d Carbon | dragonus | blade mcx, mcpx
eddo22 is offline        Reply With Quote Quick reply to this message
Old 02-13-2008, 11:40 AM   #32 (permalink)
WHAT! WHITE BLADES??? Surely you have offended the Carbon Gods! ;-)
Good post, I'm trying the bearing trick tonight. Thanks!
***yb3ard
"eat a live squirrel every morning, and nothing worse will happen to you all day!"
Gr4yb3ard is offline        Reply With Quote Quick reply to this message
Old 03-12-2008, 09:25 PM   #33 (permalink)
How do you keep the heli from shaking on rotor decell?
I installed the bearings and it shakes so bad it falls over on spool down.
It was glass smooth with the orings.
edit: It seems the problem is caused by the blades moving forward in their grips on decell.
I run an Arc 110 motor and the freestyle blades. The cogging on the motor, which is severe, and the loose fit of the blades (they are thinner at the root than stock) come in to play when I replace the damper with a non damper (bearing). They simply slip forward in the grips, one more than the other of course. I'm sure a 1 way clutch would solve this as wood a non coggy motor, but it is a micro after all.
I guess its back to o rings... sigh
michael503 is offline        Reply With Quote Quick reply to this message
Old 04-05-2008, 10:08 PM   #34 (permalink)
Default hi
ok i am brand new to the board and to helis but im hooked i have 3 helis now a blade cp a cp pro and the blade 400 i just got a AR6100 rec in the bcpp and i need to know some good settings for the dx6i and what should i upgrade first now i am not doing any 3d or anything i have been flying for a week or 2 lol
blade4oo is offline        Reply With Quote Quick reply to this message
Old 05-27-2008, 12:17 AM   #35 (permalink)
orlbuzz
I'm planning to use a DX 7 with my CP Pro. What kind of servos did you use?. Do I have to change anything else in addition to the receiver? I'm running brussless and lipo battery
The Oiler is offline        Reply With Quote Quick reply to this message
Old 06-05-2008, 08:27 AM   #36 (permalink)
Red face
Originally Posted by crmodels View Post
I'm Back
3D TIME!!!!!!!!!!!
Chris
Has anybody tried 3D with a stock HB CP2? I've tried some for the first time but it seems that the stock motor hasen't enough power.
Honey bee CP2 Crash and recovery! (3 min 23 sec)
Could I except more from this little bird?
T-REX 450SE LGT 2100 for FPV
T-REX 450SE V2 GY401
TREX 450 PRO
Futaba FF7 / SPEKTRUM DX7
najib is offline        Reply With Quote Quick reply to this message
Old 07-28-2008, 01:47 AM   #37 (permalink)
Default G90 HH Gyro in digital versus standard mode?
I noticed you are using the G90 in digital mode along with the stock servos. Since no servo is connected to the gyro, what does the digital mode do over the standard mode? Will using the digital mode harm anything? I am using a DX6 radio along with a AR6000 receiver. Thanks.
cold duck is offline        Reply With Quote Quick reply to this message
Old 08-13-2008, 02:15 PM   #38 (permalink)
I am also using seperate electronics with a GY240 instead of the G90. I went inverted for the first time on the CP Pro today. It was pretty stable.
evdreamer is offline        Reply With Quote Quick reply to this message
Old 11-23-2008, 07:51 PM   #39 (permalink)
I'm getting the GWS ICS50 ESC tomorrow. I already have the IX50C DD motor and 4530 prop with adapter. My Feigao DD tail motor draws too much current for my 800mah 11.1v batts and the tail cuts loose after about five mins of flight with no warning at all. Yikes! My setup will then be very close to the one described at the beginning of this thread. I can hardly wait! I'll report back with the results within the next few days.
~CD
Old 11-28-2008, 03:42 PM   #40 (permalink)
Swapped out the Feigao for the GWS brushed motor and ESC along with the 4530 prop. The heli flies just fine except it has a tendency to turn left. Trying to get the gyro gain dialed in. Other than that, it all works as advertised.
