Old 09-19-2011, 12:44 AM   #121 (permalink)
Im also wondering! I have 2 normal spektrum satelite receivers, should i set them up as digital center option or normal 1 and 2?
Gaui X7
Hirobo Eagle 3 EP
Hirobo Turbulence D3
Hirobo SDX-CGY750
GootyS is offline        Reply With Quote Quick reply to this message
Old 09-19-2011, 02:22 AM   #122 (permalink)
Digital Center
http://heli.dacsa.net
Old 09-30-2011, 10:41 AM   #123 (permalink)
Originally Posted by MrMel View Post
With the DSMX satellites you can go HiRes mode.
That said, there is no real benefit unless you run a radio with higher framerate (11ms)
So not to beat a dead horse but just want to make sure I have it all set up right and didn't miss anything. with a dx8 run 1-2 sat hires and 11ms in the radio?
shein95 is offline        Reply With Quote Quick reply to this message
Old 09-30-2011, 10:48 AM   #124 (permalink)
DX8 Runs DSMX, in VBar DSMX and yes, its 11ms
Old 09-30-2011, 04:47 PM   #125 (permalink)
i cant seem to get my satellites to power up. using cc bec pro going into the spare servo ports (ele & ail) they are dsmx sats is there a step im missing? they wont do anything
McCollister911 is offline        Reply With Quote Quick reply to this message
Old 09-30-2011, 05:06 PM   #126 (permalink)
running 5.0 on both i cant get the lights on the sats to come on at all
Old 09-30-2011, 07:15 PM   #127 (permalink)
Have you tried binding? You probably won't see any lights on them until they're bound and an RF link is active.
HeliFreak Support
Graupner MZ-32
Old 10-12-2011, 10:49 PM   #128 (permalink)
okay i have a dx7 no dsmx upgrade,2 dsmx sats and 5.2 fullsize,what mode should i run guys?
600 DFC HV
Pilot Brandon J.
bj660raptor is offline        Reply With Quote Quick reply to this message
Old 10-12-2011, 11:25 PM   #129 (permalink)
Spektrum Satellites (1 or 2) digital center
HeliFreak Support
Graupner MZ-32
Old 01-03-2012, 05:44 AM   #130 (permalink)
I have one dsmx sat and one dsm2 sat but have a dx7 which is a dsm2 radio, which should I be using?
Trex 700L NEO / Mikado Logo 600SX Vbar 6.0/ Trex 470LM NEO, Oxy 2 CC Talon 25 NEO, 450 pro vbar 6.0pro/ Trex 700n DFC OS105HZR, Velocity50 Vbar 6.0pro -Oxy 5 NEO-/Trex 600efl PRO (Night Flyer) vbar/CC HV80 ......ALL VBAR CONTROL
Stevin is offline        Reply With Quote Quick reply to this message
Old 01-03-2012, 06:27 AM   #131 (permalink)
HeliFreak Support
Graupner MZ-32
Old 01-07-2012, 11:21 PM   #132 (permalink)
I don't think that is correct.
Here is a quote from RR about the same subject.
"DSM2 with DSM2
DSMX with DSMX
AR8000 remotes are DSMX remotes.
Matt McCarty
Spektrum Product Developer"
MXRACERX43 is offline        Reply With Quote Quick reply to this message
Old 01-08-2012, 12:03 AM   #133 (permalink)
The bum is correct.
Old 01-08-2012, 12:21 AM   #134 (permalink)
Why is a Spektrum Developer stating NOT to mix Sats then?
Old 01-08-2012, 12:34 AM   #135 (permalink)
I think its more important with RX as you then cant choose.
When you select option above in vbar it will never use dsmx
But when using a RX its another story as then it tries dsmx first then fall back to dsm2
Old 01-08-2012, 12:37 AM   #136 (permalink)
The quote I took was from a user asking about mixing sats on a mini V-bar
http://rc.runryder.com/helicopter/t653195p1/
Old 01-11-2012, 12:20 AM   #137 (permalink)
Due to a faulty Satellite I am just about to put a DSMX with a DSM2 on my full size Vbar (5.2 pro) using my DSM2 DSX9.
I did bench testing with disconnecting the individual satellites, power brownouts, etc and the DSMX worked exactly as the older DSM2 Satellite. I used the "Spektrum Satellites (1 or 2) digital centre" setting.
//Dennis.
Thunder Fighter is offline        Reply With Quote Quick reply to this message
Old 02-22-2012, 07:35 PM   #138 (permalink)
Just picked up a JR9503 DSMX. I have an Atom 500 with 2-dsm2 sats and a 6hv with 2-dsmx sats. I just wanted to confirm that with the Atom I will use 22ms/1024, and with the 6hv 11ms/2048.
Also I am not sure I completly understand the idea of resolution. Would I benefit putting dsmx sats on the Atom?
shoeler is offline        Reply With Quote Quick reply to this message
Old 02-22-2012, 08:49 PM   #139 (permalink)
I don't believe the X9503 supports 11ms. I know the X9303 doesn't. Both support 2048 resolution.
HeliFreak Support
Graupner MZ-32
Old 02-25-2012, 11:18 AM   #140 (permalink)
Interesting, anyone know for sure? I checked the HH website and couldn't find anything. Didn't see anything the manual. Now I am not sure what to do.
