X7 Discussion and support of the Gaui X7 |
02-19-2012, 05:55 PM | #1 (permalink) |
[CRASH] X7 goes in at over 100mph...
I'm currently attributing this crash to either the plastic servo arms, or a link that broke. It happened after a speed run, rolled 90 and pushed the nose to come around into an inverted hurricane, something snapped and it flopped around before hitting the ground at 100 mph.
Thankfully, Gaui has built an amazing machine. The entire core is intact, packs are fine, the main gear is fine. Even the whole head is fine: grips, spindle, grip arms, and swash. The tail slider rod is fine for those who were wondering if it would hold up. lmao! So far at quick glance: Boom/TT, front TT gear, tail hub, landing gear, and main shaft. No worse than a normal crash, actually less, but you wouldn't have thought that if you saw it hit the way it did! Finally, that new car smell is gone, now I can relax next time flying it...lol.
Stuff |
02-19-2012, 06:06 PM | #2 (permalink) |
wow, sheared main shaft. i send my condolences. . will you keep us posted on the parts total? any forced mechanical interaction with frame or anything? did you lose the motor heat sink plates? or were they removed during assessment?
"just let it happen" |
02-19-2012, 06:13 PM | #3 (permalink) |
Not that I can tell yet. I couldn't find the other main linkage so I can't confirm that it's intact. Here's the boom so I know it wasn't a boom strike of any kind.
Oh, I wasn't running the heat sinks, the 4035 doesn't get all that hot. What you see is what I picked up from the field. lol.
Stuff |
02-19-2012, 06:38 PM | #4 (permalink) |
Geez Rob sorry to see this man!
GAUI NX7 - GAUI X7 - GAUI X5 - GAUI NX4 - GAUI GX4 - GAUI X4 II - GAUI X3 - GAUI X2 - All on VBar 5.3 Pro Team GAUI USA / Empire Hobby / Scorpion Power Systems / Optipower Batteries / Cyclone Blades / Savox / YS Engines / VP PowerMaster / JR |
02-19-2012, 06:40 PM | #5 (permalink) |
linkages
I thought this may happen some. mine broke when i was installing them so I replaced with quick UK links
02-19-2012, 06:42 PM | #6 (permalink) |
This was inevitable if it was a hardware failure. Time to get metal arms and QuickUK links?
"It's not just a hobby... it's a lifestyle" - Pete ϟ MINNESOTA! Goblin 500 + 700 / SK540 / Jives / DX8 / Quantum / RJX servos / 306b / Deep cycles |
02-19-2012, 06:46 PM | #7 (permalink) |
Yep! Already looking at them. Can't say for sure what happened, I can only guess. I'm going back out there tomorrow, I need to find the other main link. If its broke, we can't use that to determine cause, but if it's still intact, then I know it wasn't a factor.
Stuff |
02-19-2012, 06:47 PM | #8 (permalink) |
sorry to hear
by the way sorry to hear about your issue. Were you able to hit throttle hold before it hit?
02-19-2012, 06:52 PM | #9 (permalink) | |
02-19-2012, 07:15 PM | #10 (permalink) |
Well, it looks like it was a spectacular crash at least! I don't suppose Sly was taping?
Synergy Factory Specialist / Rail Blades / Team Scorpion |
02-19-2012, 07:17 PM | #11 (permalink) |
We were at different fields at the time. I saw enough carnage yesterday
02-19-2012, 07:47 PM | #12 (permalink) |
Which Quick UK links do you have to use?
02-19-2012, 07:58 PM | #13 (permalink) |
quick links
You'll want to use the short links the others are too long and would have to be cut down
02-19-2012, 07:58 PM | #14 (permalink) |
I wouldn't jump to conclusions, by what I can tell from what I have in hand, the linkages seem plenty strong. I have 3 of 5, I need to go out and locate the other main and one of the servo linkages. The 3 I have look extremely stressed from the crash, yet perfectly intact. Both tail linkages are also intact, and yet the tail servo arm snapped, as well as all 3 servo arms.
I'd be more concerned with the plastic arms supplied in the kit, they need to be shaved down so much to fit. Metal arms are next for sure. Easily a $320 crash, but FAR from a rekit. Not including blades, it's a $200 crash, and that includes a couple parts that come in pairs, and a near $100 canopy. lol.
Stuff |
02-19-2012, 08:05 PM | #15 (permalink) | |
Here is what the end of yesterday looked like...
Stuff |
02-19-2012, 08:05 PM | #16 (permalink) |
I was thinking of getting the Align Servos... Would the Metal arms work for this heli?
02-19-2012, 08:07 PM | #17 (permalink) |
Yep, perfectly. They have 18mm holes, which worked out to be perfect geometry on my X7 with vbar.
Stuff |
02-19-2012, 08:26 PM | #18 (permalink) |
I'm running the Align metal arms and they work perfect on the inside hole.
