Like Tree1Likes
Old 03-01-2012, 12:27 PM   #1 (permalink)
Default BLHeli for SiLabs ESCs
The BLHeli code has now been converted to run on SiLabs ESCs.
This link describes the Atmel version of the code, which has the same functionality: https://www.helifreak.com/showthread.php?t=357151
The BLHeli code supports:
- Brushless tail. Get rid of that heavy SR120 tail motor.
- Governed main. Get consistent cyclic and collective response in hard maneouvers.
Other features are:
- Parameters programmable from TX
- Optional pitch to tail mix in governed mode.
- Allows build of ultralight main and tail ESCs (<0.4gram).
- Both v1 and v2 3in1 boards are supported.
There are probably also other applications, like for instance MQX brushless ESC?
So, over to the implementation facts. What do you need to do to set up a BLHeli ESC:
- Buy a "Toolstick base adapter that costs 18.63$ (a little more than a programming card for other ESCs).
- Buy one of the supported ESCs.
- Download free flashing SW from SiLabs.
- Connect three wires to the ESC and flash the code.
And the details:
The Toolstick base adapter looks like this:
Name:	Toolstick wires front.jpg
ID:	294850 Click image for larger version
Name:	Toolstick wires back.jpg
The pictures also show where to connect the three wires (I have used black, red and white).
And you have to short two pins on the connector (highlighted with a green circle in the pic).
You can buy it here: http://search.digikey.com/us/en/prod...345-ND/1207734
Or here: http://www.silabs.com/products/mcu/Pages/ToolStick.aspx ("TOOLSTICKBA" link)
And probably many other places too....
Then you have to choose your ESC. The ones below are currently supported:
DP 3A: Click image for larger version
Name:	DP 3A front.jpg
ID:	294852 Click image for larger version
Name:	DP 3A back.jpg
Supermicro 3.5A: Click image for larger version
Name:	Supermicro 3.5A front.jpg
ID:	294854 Click image for larger version
Name:	Supermicro 3.5A back.jpg
XP 3A: Click image for larger version
Name:	XP 3A front.jpg
ID:	294856 Click image for larger version
Name:	XP 3A back.jpg
XP 7A: Click image for larger version
Name:	XP 7A front.jpg
ID:	294858 Click image for larger version
Name:	XP 7A back.jpg
ID:	294859 (Remove the cap as shown)
XP 12A: Click image for larger version
Name:	XP 12A front.jpg
ID:	294860 Click image for larger version
Name:	XP 12A back.jpg
ID:	294861 (Remove the cap as shown)
Turnigy 6A: Click image for larger version
Name:	Turnigy 6A front.jpg
ID:	294862 Click image for larger version
Name:	Turnigy 6A back.jpg
The above pictures also have black, red and white circles showing where to connect to the toolstick.
All of them have PCB points that are fairly easily accessible with a soldering iron.
Then you need to download and install software for flashing:
Click the "Flash Programming Utility" link on this page: http://www.silabs.com/products/mcu/P...Utilities.aspx
With the Toolstick and the ESC at hand, follow the guidelines in this document: SiLabs code flashing.pdf
Hex files for downloading into the various ESCs, as well as source code and TX programming manual can be found here: https://github.com/bitdump/BLHeli
Alternatively use the excellent BLHeliSetup software (windows only), that lets you flash hex files, change parameter settings and more. You can download it from 4712's blog page: https://www.helifreak.com/blogs/4712/1859-blheli-setup-3-4-0-0.html
And that's it. Now just build the ESC into your heli and fly!
Happy modding and flying
Steffen
PS: Although shown many other places, below are pics of wire connection to the "resistor taps" on the back of the v1 and v2 3in1 boards:
v1 board:
v2 board:
Crow_a likes this.
sskaug is offline        Reply With Quote Quick reply to this message
Old 03-01-2012, 12:35 PM   #2 (permalink)
Just some additional information:
This spreadsheet shows the governor headspeed versus programmed throttle setting: Governor SiLabs.xls
The SiLabs version of the BLHeli code will support headspeeds in excess of 8000rpm (with 6pole motor and 8t pinion).
And this spreadsheet has a bit of information on the FETs that you will find in various ESCs: MOSFETs SiLabs.xls
Finally just the spreadsheet used for calculation of the low voltage limiter settings for the various ESCs: Voltage cutoff SiLabs.xls
Old 03-01-2012, 12:47 PM   #3 (permalink)
Default Ultra lightweight ESCs
If you would like to build ultra lightweight ESCs for your mCP X, you can do like this:
Start off with one of the small ESCs, the DP 3A, the XP 3A or the Supermicro 3.5A (the lightest one).
Then replace the FETs with good FETs, like for instance the DMN2041/DMP2035:
http://search.digikey.com/us/en/prod...ICT-ND/2182586
http://search.digikey.com/us/en/prod...ICT-ND/2181234
For the main you "piggyback" a second set of FETs on top of the first.
Such an ESC with double DMN2041/DMP2035 is better than an XP 7A and only weighs about 0.4g.
Some pics of my beli build:
XP 3A main with double FETs:
DP 3A tail:
Supermicro tail:
Old 03-01-2012, 12:48 PM   #4 (permalink)
Steffen,
Wow, that's amazing work!
Which of the above ESC's would you recommend using for a tail?
SuperBee364 is offline        Reply With Quote Quick reply to this message
Old 03-01-2012, 12:52 PM   #5 (permalink)
For a tail I would recommend one of the small ESCs. The Supermicro if you plan to replace the FETs, the XP 3A if you don't. The XP 3A has the best original FETs.
Old 03-01-2012, 12:59 PM   #6 (permalink)
Originally Posted by sskaug View Post
Excellent, thanks!
My HP03t tail motor is taking forever to get here from China. As soon as it does, I'll be pairing it with the ESC you got for me. If I can get the BL tail to play nice, I think I'll have a go at programming an ESC for my second heli, which is now an option, thanks to you.
Old 03-01-2012, 01:03 PM   #7 (permalink)
Awesome work as always mate!
How do the XP 12A compare to the Walkera I bought from you?
Any reason I should upgrade?!
Lynx Heli Innovations | HD Helicopters
ZyBeR is offline        Reply With Quote Quick reply to this message
Old 03-01-2012, 01:18 PM   #8 (permalink)
Thanks!
If you plan to run 1S and headspeeds below 5500-6000rpm, I recommend the Walkera.
The Walkera has FETs that are specified for 1S, the XP12A does not. You can see the details on FETs in the spreadsheet in post #2.
If you plan to run headspeeds above 5500rpm, I recommend the XP 12A, since the SiLabs MCU allows headspeeds above that.
Old 03-01-2012, 01:34 PM   #9 (permalink)
Awesome more stuff for me to do. Thanks.
Hello My Name Is Joe
Blade 130X - Lynx EOX / Blade 300x - AR7200BX, 2213-3585 / Trex 500ESP DFC - AR7200BX, 500MX / Trex 550e DFC - AR7200BX, 600MX / TSA 600e Pro - AR7200BX, 700MX / TBS Discovery FPV - APM, Sunnysky 980kv/ DX8
jabu32 is offline        Reply With Quote Quick reply to this message
Old 03-01-2012, 02:09 PM   #10 (permalink)
Thanks again Steffen!
Like a little kid, I've had to restrain myself from asking every day "Is it done yet?" lol.
Looking forward to plugging it in tonight.
Thanks,
Norm.
B450x, Chase360, Warp360, mini Protos stretched, Protos 500 stretched, NX4 gasser, Goblin 500 x 2, Century E640 stretched, MD7 and MD8.
distructor is offline        Reply With Quote Quick reply to this message
Old 03-01-2012, 02:38 PM   #11 (permalink)
Great work Steffen! Thanks for your tremendous effort!
I am currently running an XP-12A (with converter) and HP06v2 main motor.
I am using a 120SR tail with Plantraco 65mm prop.
Encouraged by your great documentation, I'd like to install a brushless tail
with the XP-3A. What motor and prop would you recommend? Would a
Oversky HP03T be a good choice?
Blade mCPX BLHeli HP06v2/HP03T, mCPX C05M, mSRX, mCX, mSR
Spektrum DX8, DX6i
Phoenix Sim
rfto is offline        Reply With Quote Quick reply to this message
Old 03-01-2012, 02:51 PM   #12 (permalink)
I have been using both the Oversky HP03T "regular" 2.9g, and the "new" HP03T 2.5g with Plantraco together with HP06v2, WOW07 and HP08. And I am happy with both. The 2.9g has 12 magnets, while the 2.5g has 6 magnets, and the 2.9G is more powerful and probably a safer bet.
Anybody else have other experiences on tail motors?
Old 03-01-2012, 02:53 PM   #13 (permalink)
Brilliant work Steffen. You have put a lot of dedicated hours into this project. I hope it has bought you the sense of achievement that it deserves, because it is certainly an achievement.
Roffey is offline        Reply With Quote Quick reply to this message
Old 03-01-2012, 02:55 PM   #14 (permalink)
Thanks a lot! Particularly appreciate that praise from you, knowing all the excellent work that you have presented and continue to present all the time
Old 03-01-2012, 03:29 PM   #15 (permalink)
I can have a governor on my XP-12A?
I think I love you...
Blade mCP X - Brushless, XP-7A, HP05S
Gaui X2, BeastX/Scorpion 3400kv/YGE-30A/GS-093/DS95i
Align AH-1 Cobra (T-Rex 500)
Align T-Rex 600 EFL Pro, SK720/600MX/YGE-90HV/BL9180/BL9188
zeeflyboy is offline        Reply With Quote Quick reply to this message
Old 03-01-2012, 03:34 PM   #16 (permalink)
Do you simply connect the signal wire to the ESC without the need of a converter like TheSteve? So would I be flashing both ESC for main and tail?
r/c helis lifestyle
HeliSmith is offline        Reply With Quote Quick reply to this message
Old 03-01-2012, 03:44 PM   #17 (permalink)
The XP 12A should run nicely with a governor!
Forgot to mention, but the code runs 1S to 3S, whatever the ESC hardware supports.
And there is NO need for a converter. Just the one wire from the 3in1 to the ESC. And main or tail is determined by the hex file that you choose when flashing.
Old 03-01-2012, 03:45 PM   #18 (permalink)
Yes and yes!
Might also be worth mentioning that in the pictures of the 3-1's, the main is the lower left resistor, and tail is the upper right.
Old 03-01-2012, 05:15 PM   #19 (permalink)
This is great! Nice work.
coredump is offline        Reply With Quote Quick reply to this message
Old 03-01-2012, 06:00 PM   #20 (permalink)
sskaug thank you for all your hard work, actually you too Roffey I follow both you guys. Since reading your threads I have on order a nice soldering station and the tools I will need. I did opt to wait for long shipping from Hong Kong and get a couple XP-12 so it will be a bit yet..
P.S. Hope I am good at this tiny soldering.. "Got my wine and pillow ready"
r/c helis lifestyle
