mCP X Blade Micro CPx Helicopters Information and Help |
08-21-2011, 11:04 PM | #21 (permalink) |
Perhaps solve tail wash issue
If your not running an extended tail boom try first but also u can pull tail boom and motor from 120sr stronger tail motor drill out tail boom mounting hole on chassis and slide 120 SR tail right in
08-22-2011, 05:51 AM | #22 (permalink) |
Might try halving the width of the blades.
Would be a real PITA to get them all the same and balanced, but would look more scale and probably help with the tail. |
08-22-2011, 10:45 AM | #23 (permalink) |
What are you using for the fuselage? Is it a model kit of something? What's the helicopter, I don't recognize it? Thanks and love these type of projects!
Blade 500x, 450x, 300x, 200srx, MCPX BL, DX7 Courtesy Clerk at Safeway, Lonetree! |
08-22-2011, 03:31 PM | #24 (permalink) |
I will be intreasted to know how you overcome the phasing issues.
Since the mcpx FBL system is set to 90' phasing, you will have to find a way to keep the grips and links at 90' to each other, which is an issue since there is a grip at every 90' point My guess if you will likely have to raise the head, and put a vertical "drop arm" on each grip to meet the swash links under each blade grip?
550e FBL SK720 450Pro FBL SK720 250SE FBL SK720 +250SE FB 4G6, mCPX, mCPXBL, nCPX, mSR, mCX |
08-22-2011, 05:00 PM | #25 (permalink) | |
Compass 6HV - FBL SK-720 |
08-26-2011, 01:28 AM | #26 (permalink) | |
As for the tail, you could do the double tail motor mod, which is simple and effective. Keep going, you'll get there in the end! That's the fun bit of it, with the frustration in between! |
08-26-2011, 04:47 AM | #27 (permalink) | |
02-09-2012, 06:45 PM | #29 (permalink) |
so-fly...
Any news on this project? I am working on something similar. Would love to see your progress and compare notes. Fly Safe! Erwin |
02-10-2012, 12:33 AM | #30 (permalink) |
How many featuring spindles does it need?
02-10-2012, 01:30 AM | #31 (permalink) |
Pretty impressive, even if it dosent fly all that well YET.
Good-Bye Buggies...Hello Helis! McpX v2, Mcx2, Dx8, Phoenix v4 (plus all my surface stuff) Cars are soooo two-dimensional.... |
02-27-2012, 05:02 PM | #32 (permalink) | |
my main issues were: parts count in case of crash procrastination and too complex to do a mass production of a few things i did change was i had cut down versions of stock blades, did a CNC plastic rotor head instead of aluminum, made direct links to the rotor grips instead of a swash lock.
ALIGN TREX 250SE 450SE V2 500ESP 550E 600ESP 700E NOVUS CP BLADE MSR BLADE SR 120 BLADE SR |
03-16-2012, 05:32 PM | #33 (permalink) |
4 Blade head...
Hi so-fly...
Bummer to hear that you moved on from the project... but then again it's good to know when to move on... not one of my virtues. Everybody keep on telling me that there is no point to the multi blade story... I am sticking with the Micros as there is no space or funds for the bigger birds and I am sure I would end up with a twin turbine 1/4 scale Black Hawk... eventually... Here a pix from the testing rig, it will end up eventually in a OH-6 body with Brushless motor and if I keep trashing my tails (I am on number 6 right now) it will end up with a torque tail... Fly Safe! Erwin |
03-16-2012, 05:47 PM | #34 (permalink) | |
For some reason I really like this project, I guess it's just the coolness factor (which is through the roof in my opinion). Keep us informed, I really want to see a successful quad-McpX.
03-16-2012, 06:28 PM | #35 (permalink) |
3 Blade Head
Thanks man...
What do you think of that one then... While I was waiting for parts for the OH-6... I saw a Schweizer 300C scale fuse for the mCP X and just had to... Fly Safe! Erwin |
03-16-2012, 08:16 PM | #36 (permalink) | |
Thats pretty clean looking as well. If you had to give a quick estimate, about how much time do you think you have into each of these? Im just curious. They are both impressive. Make sure you post up some videos when they are finally in the air, I'm dying to see these fly.
03-17-2012, 07:38 AM | #37 (permalink) | |
Muli blade heads...
Hmm, that's a toughy... way to much if you ask my wife! I was pursuing the scale path for a while now, but I only got the mCP X back in December and didn't open the box until I got sick and tired of the mSR X in mid January. Since them I was sourcing parts, mainly the Gaui head parts are far and between these days. The feathering shaft was another story (and an expensive one) It took a months for the second version and I just got them yesterday... so mainly it was waiting around for most of it. The main plan was the 4 Blade... the 3 Blade just happened while I was waiting for parts... The 5 Blade is just sitting as I have not enough feathering shafts for it and the Swash plate is another headache... I will buy my own machines and do it my self next time around... I am getting my carbon plates next week and will cut my own frame sides for the Microheli frames as they should have been in the first place... It's frustrating sometimes... but if all would go smooth all the time... where would be the fun in that...? Okay I admit, more time in the air for sure... but that's fun for the days it's to bad to fly... Fly Safe! Erwin |
03-17-2012, 09:04 AM | #38 (permalink) | |
Is the swash your biggest obstacle currently? Or do you need lighter hub/spindle shaft deals? Got a sketch, or better yet 3d model of what it is that you need? |
03-17-2012, 02:12 PM | #39 (permalink) | |
Hi Koko76, In a previous life I wanted to become an engineer and I spend four years making blueprints first with ink by hand and later with Autocad for other people and I hated it. At the company I used to work you had from time to time go down and work side by side with the mechanics to make you a better engineer while trying to actually build the crap that you designed... that was actually fun... I always stayed late and used the machines to make stuff for my private use... Later when I started working in the Camera department I found my self constantly designing stuff to make life easier on set... I had a great machinist in LA who would make me prototypes for free and then keep the idea and make money with it... I didn't care to make money on it and it worked great for both of us as he made any crazy idea I had into a prototype. Drawing Programs... It was always hard to find something decent for the Mac Platform (under $10 grand), I used to play around with TurboCad and a little with Solid Works but both didn't run well on Snow Leopard and with Lion basically 80% of my overpriced Software is now junk. But anyhow... These days I make quick hand drawings with all important dimensions and surface finishing and end up over paying for the parts... the feathering shafts ended up costing me $40.- a piece... as instead of just setting it up on the small CNC machine, he let the apprentice try it and spend 4 hours at the lathe on it... At that rate I could have done it myself... way cheaper... I looked at Proxxon, they have some nice 2 and 3 axis machines staring at $500.- for milling machines to about $1500.- for a lathe or combination of it... There are tabletop 3 axis CNC machines that are about in that range... just the proprietary software is the killer on the deal... What would be your take on it? Fly Safe! Erwin |
03-17-2012, 03:45 PM | #40 (permalink) | |
I run Solidworks on my MacPro in Parallels, Snow Leopard. I have my own seat of 2006, and I have a seat for work that's current. Runs really well, I run Mastercam under parallels as well. It won't crunch quite as fast as dedicated machine, but for making a part or two at home I can't complain. I built my own machine 3/4 axis machine, I couldn't give you a cost number (fear and not knowing) several k, that's for sure though, but I used linear guides, ballscrews, and a brushless drive/cartridge spindle. All it lacks at this point is a tool changer which will be coming soon enough. Good cam is expensive, but for 2.5D or even simple surfacing you can get stuff for a couple hundred or so, even free in some cases. If you have things you want cut I can take a look at it. If it's something I'm interested in making for myself I'm generally happy to make two at the same time, send you one for your trouble of designing it. |
