Vibration on spool up and down - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600 PRO Class Electric Helicopters
600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 04-23-2012, 06:21 PM   #1 (permalink)
Default Vibration on spool up and down
Hey guys,
My 600e pro has an odd vibration at a certain low headspead when throttling up, and when throttling down. What could be causing this? Out of ballance blades, a bad bearing, etc?
-Trex 600efl pro-
-Trex 450 pro V2
Heli man01 is offline        Reply With Quote Quick reply to this message
Old 04-23-2012, 07:50 PM   #2 (permalink)
yea mine does to
and you can almost bet its that align motor
4 x Rush 750/stretched V-bar KDE 700XF-495 HV servos Greys reactor CC 160-HV
Trex 600EFL V2 V-Bar ds610 ds650 CC bec/pro Scorpion 130a HV KDE 600XF-530
450L KDE 1750 cc50 4xDS215MG k-bar
X-8 FPV Wing, TBS Discovery FPV, TBS Caipirinha FPV
satgod is offline        Reply With Quote Quick reply to this message
Old 04-23-2012, 08:10 PM   #3 (permalink)
I don't think its my motor. I wanna say its a bearing or the torque tube. Any other ideas?
-Trex 600efl pro-
-Trex 450 pro V2
Old 04-23-2012, 10:35 PM   #4 (permalink)
Frequency of the vibe at which headpseeds is very important. Location is needed too.
First thing to do is minimize variables. Take the head off and run it up (you can bench run at 3 to 6s for slower testing speeds). If the vibe is not present, suspect the head/blades. If it's still there but is slower in pulse than tail rpms, suspect main gear, owb, auto gear wobbles, etc. If you find the vibes are high in speed even at lower head rpms, check the tail, then the TT for being straight(I've had ones out of true from the factory).
The motor being out of balance can cause highfreq vibes, but are normally pretty low in strength since the motor has a low diameter of mass compared to the tail. It would have to be bad enough that you would likely see the offset on the motor.
"You need more rockets. Everything is better with rawkets"
E5-S KDE 600XF / N7 Tweaked 1.05
X3 / BRAIN'd MXS-C
Mike Dipalo--Synergy RC, MKS Electronics
Commodore8888 is offline        Reply With Quote Quick reply to this message
Old 04-24-2012, 06:39 PM   #5 (permalink)
all righty then. I will start testing it and see what it is.
-Trex 600efl pro-
-Trex 450 pro V2
Old 04-25-2012, 03:22 PM   #6 (permalink)
Does it run ok when the headspeed is higher? I would start by balancing the blades, and while they're off for balancing, spool it up without the blades to check for vibrations. Out of balance blades can cause vibrations or wobbles at certain (usually slower) headspeeds. There will be some vibration at high headspeeds, too, but certain resonant frequencies can show up while spooling up or down. I'd bet balanced blades would make a big difference.
If that doesn't help, hopefully something will show up when you spool it up without the blades. From there, you just need to run through the things that commodore listed in order to troubleshoot it.
// T-Rex 600EFL Pro 3GX // T-Rex 450 Pro V2 3GX // T-Rex 250 Pro DFC 3GX //
// Walkera V120D02-S (x2) // Walkera V120D02 // Walkera Genius CP (x3) //
// EFlite Blade MCPX (x2) // EFlite Blade 120SR // E-Sky Belt CPX //
// WK2801 // Spektrum DX4e //
jonbailie is offline        Reply With Quote Quick reply to this message
Old 04-27-2012, 11:06 PM   #7 (permalink)
I will try balancing the blades. From everything you all said, it sounds like they are the problem. Will give it a try.
-Trex 600efl pro-
-Trex 450 pro V2
