Sport mode/Transmiter mode - HeliFreak
Old 05-03-2012, 05:45 AM   #1 (permalink)
Default Sport mode/Transmiter mode
The 450 X comes set up in TX mode on the 7200BX If I change this to sport mode, do I have to go thru a complete re-setup of the 7200BX?
Or can I just change to sport mode and leave everything else alone?
browndog is offline        Reply With Quote Quick reply to this message
Old 05-03-2012, 05:52 AM   #2 (permalink)
No, you can switch to Sport mode in the Settings menu without going through Setup again. The Settings menu is designed for use at the flight field. Setup is meant to be done at home any time a mechanical change has occurred.
It's just a stored set of DR/Expo/Travel Adjust/Gain settings though. Normal mode is even gentler than Sport mode, if you're looking to make it ultra-stable for first flights.
Blade: mCX2, mSR, mSRX, Nano-CPX, 2x mCPX (v1), mCPX-BL, 120SR, 450 X
Spektrum DX8, DX6i
Talesin is offline        Reply With Quote Quick reply to this message
Old 05-03-2012, 06:24 AM   #3 (permalink)
No, you can switch between whichever flight mode suits your style. I was Tx at first, then Normal (found it too sluggish) then Sport which reminded me of my MCPX on steriods
But at the moment after another strange incident the other night, the heli's on it's way back to Horizon Hobby
MCPX V2
Tarot 450 pro V2 FBL Zyx gyro
Blade 450X FBL
retired to the black bin bag!!
Flying_Amp is offline        Reply With Quote Quick reply to this message
Old 05-03-2012, 08:36 AM   #4 (permalink)
So After I switch, I should set my TX back to zero on everything DR/Expo trims etc
Old 05-03-2012, 09:14 AM   #5 (permalink)
That is correct..If you are going to run using the BeastX presets then you want to zero out the Expo and set your D/R to 100%.
mtuccio is offline        Reply With Quote Quick reply to this message
Old 05-03-2012, 02:56 PM   #6 (permalink)
Also you should *never* use trims on a flybarless heli for longer than it takes to 'rough in' the trim (get a general idea of how many trim steps are needed). Then re-set the TX trims to zero, and set the trim in the BeastX trim settings menu. A little bit of drift is normal.
Spektrum DX8, DX6i
Old 05-03-2012, 03:02 PM   #7 (permalink)
Good Info...
Another trick that I use on the DX8 is once all your trims are centered you can shut the controller down, power up holding the roller button, enter the trim step menu and set all the values to 0. By doing this you can never change the trim on the controller by an accidental hit from your fingers. The buttons are effectively dead under normal operations...
Just a little tip....
Old 05-04-2012, 08:27 AM   #8 (permalink)
Good tip m8.
MCPX V2
Blade 450X FBL
Old 05-05-2012, 06:13 AM   #9 (permalink)
Awesome info guys
Thanks a million
