Like Tree3Likes
Old 05-20-2012, 10:01 PM   #121 (permalink)
Originally Posted by jason4636 View Post
Mine might not be an 450x from the factory. But none the less, mine is a Blade 450 3d. Converted to a 450x and then some!!!! I've kinda went crazy on my mods!!!
jason4636. That's got to be the coolest (and most expensive) rendition of the Blade 450X. Awesome job! What next?
14S Tron 7/Protos 700X Evo/Kraken; 7S Kraken 580/Logo 550SX V2; 6S Buddy 380 KSE
VBC Touch & Neo Vlinks, YGE "T" ESCs; AGM Deep Cycle Batteries
Sims on Mac: Heli-X, neXt, AccuRC, RF9, Phoenix, AeroFly RC7 Ultimate
Amain Field Representative
jhamel is online now        Reply With Quote Quick reply to this message
Old 05-20-2012, 10:46 PM   #122 (permalink)
I hope you guys like it, an not laugh at it.
Heck no, that's very nice!
Rodney Kirstine is offline        Reply With Quote Quick reply to this message
Old 05-20-2012, 11:01 PM   #123 (permalink)
Practice, practice and alot more practice. Then hopefully when the Protos 700 comes out. I'll get one of them.
But on my heli, my next mods will be to put the motor an esc in. But after that, there's really nothing left to do. Maybe change out my tail fin and tail blades, to a bright color. Kinda hard to see orientation at any real distance.
Blade 450 Tarot DFC FBL head, SK720, 5056mg's, 5084mg
Mcpx with alittle of this and that
Rappy 90
jason4636 is offline        Reply With Quote Quick reply to this message
Old 05-20-2012, 11:07 PM   #124 (permalink)
I see in your signature that your building a whiplash. I've watched some vids on it. To me they look sweet. I would really like to know how it flys. And yea it's a very expensive heli. I'm kinda thinking about getting my a 450x an keeping it all stock. So I would have another bird, an one that's not so expensive to repair
Rappy 90
Old 05-21-2012, 03:42 PM   #125 (permalink)
Can somebody post a pic of the head at half stick-zero pitch. I just want to see if anyone is running the follower arms a little off from horiontal position. I really want to get rid of that red light on step L of the BeastX
Andreas M.
Compass 7HVU
Logo 600SX V2
Blade 450X
Heli.Maniac is offline        Reply With Quote Quick reply to this message
Old 05-28-2012, 10:29 AM   #126 (permalink)
Foreground: B450 3D converted to 450X, Fusuno Canopy, aluminum blade grips, Edge blades. Debating getting the aluminum swash.
Background: Bone stock hot rod 450X. 30g lighter than the convert, and a decent bit faster.
Napoleon_Tanerite is offline        Reply With Quote Quick reply to this message
Old 05-29-2012, 07:46 AM   #127 (permalink)
Man you need to get some KBDD tail blades on those birds. They work awesome and are by far the best bang for your buck upgrade.
Tarot 450 Pro V2 FBL - Blade mCP X - Blade 450 3D FBL
FuntanaS is offline        Reply With Quote Quick reply to this message
Old 05-31-2012, 07:07 PM   #128 (permalink)
When I have 0 pitch at mid stick, my follower arms are horizontal.
But I used a T450 tripod leveler to double check the Blade leveler and I use the tripod leveler to assure that my swash is level at full positive and negative collective.
I think you might have your swash a tad too high or too low at mid stick, depending. This would make your follower arms just a bit off......My Blade leveler teeters a bit because the surface the leveler sits on is not perfectly level. I just use the Blade leveler to set the swash height, while checking that the follower arms are horizontal at mid stick.....then use the tripod leveler to get the swash exactly level......all being done while in setup menu G WITH any servo selected and exit setup menu G with any servo selected.
Hope this helps!
gl
EEngineer is offline        Reply With Quote Quick reply to this message
Old 06-02-2012, 01:34 PM   #129 (permalink)
Thumbs up Blade 450X with Telemetry
Hi All
Just thought I'd post a few pics of my 450X with telemetry.
I have installed:
1) RPM sensor
2) Voltage sensor
3) Temp sensor - I have this around the base of the motor, similar to a previous post by another user in this thread. It's a close as I can get it and 2 drops of glue hold this in place. The glue wasn't really necessary as it was pretty tight in there, but just to be 100% safe.
4) Altimeter - on the left of the frame. Works really well, just a pity it occasionally
initialises at negative altitude (about minus 1 meter). That does correct slightly, but still end up negative when landing. I can understand it going negative because of change in weather etc, but starting at negative seems wrong. Oh well.
5) G-Force sensor - not that useful on a helicopter, but still fun to look at the graphs etc, so I put it on. At the moment my flying limit is fast forward flight with stall turns and the occasional stationery rolls and flips. But I imagine the g-forces will be interesting for all you guys who are doing more serious 3D flying.
I use the TM1000 and the STi iphone/ipad adaptor.
In all this adds approx 70 grams to the weight. It still flys perfectly well and is very stable. I fortunately haven't had any issues like I've read about on this forum.
All other items (except the canopy) are standard. I prefer to keep it this way to avoid all the technical issues I've read about with changing parts or upgrading. I'd rather spend the time flying. Having said that my motor will probably fail on my next flight!
The only issue I have is with the RPM gauge on the telemetry app. The RPM sensor occasionally jumps to the extreme right on the gauge and the readout changes to "infinity". It stays like that for about 5 seconds and them goes back to the correct reading. It's the latest app version and iOS version. Happens on both iphone 4s and ipad2. I've read about another person on Helifreak also experiencing this - no solution yet. The RPM graphs are fine, which shows the data is getting to the app fine. It's just the gauge. Luckily I only use the graphs, so not really an issue, but if I have someone with me watching the app they can't monitor the RPM at times. The read out on DX8 screen is always correct. Strange??
I am really impressed with the 450X. It's my first collective pitch and I have about 30 flight on it (5 - 6 min each). I'd recommend it highly.
Thank you to everyone who has posted on the 450X thread - really useful to read.
Please let me know if you have any recommendations on my telemetry setup. Or a solution to the telemetry app RPM issue.
ID:	321403   Click image for larger version
ID:	321404   Click image for larger version
ID:	321405   Click image for larger version
ID:	321406   Click image for larger version
ID:	321408   Click image for larger version
ID:	321409   Click image for larger version
ID:	321410   Click image for larger version
ID:	321411   Click image for larger version
ID:	321413   Click image for larger version
Delll is offline        Reply With Quote Quick reply to this message
Old 06-06-2012, 08:30 PM   #130 (permalink)
So here's all my mods to date
Sookum SK720 FBL controller
Tarot FBL head with the DFC links
Jason4636 - great looking heli! Awesome job, and nice use of electronics/mods. I know many people purchase the Tarot head from CNC heli, but where did you purchase the DFC links from?
Thx
180CFX, Trex 550E (night), Goblin 570, Goblin 630C, DX8
Skidpad is offline        Reply With Quote Quick reply to this message
Old 06-07-2012, 09:56 PM   #131 (permalink)
Hitec 5056's for cyclic
Hitec 5084 for tail
The whole tail, fins, and both sets of blades are CF and aluminum
T-rex 500 skids
T-rex 450 canopy
Scorpion 2221-6 (not installed yet)
Hobbywing esc (not installed yet)
Hyperion phase sensor (not installed yet)
All I can say about the SK720 is? I love it!!!! It has self-level, that I have as a bail-out switch. But now it is helping me learn inverted flight. Cause the SK has SL for upright and inverted flight. I know it has boosted my confidence level a bunch.
I got the scorpion motor, esc, an phase sensor to be able to run the governor ot the SK. It's gov. is pro-active instead of re-active. Since the gov is controlled by the SK, when you input pitch or cyclic. It will ramp up the motor, befor hand. So there is no motor bog. Plus once I get my DX8. I can program in 3 gov. rpm's to a switch.
Looks great! That's my favorite canomod canopy and your mcpx looks almost exactly like mine. But I was wondering, what mods are required for the tarot DFC head? Did you have to do anything to the shaft?
Edit: found it: https://www.helifreak.com/showthread...ght=Align+head
nqx, mcpx, mcpx BL, 130X, trex 250 pro DFC iKon, 450X, TBS Discovery, Trex 500 DFC iKon, dx9
TheHeliDude is offline        Reply With Quote Quick reply to this message
Old 06-07-2012, 10:10 PM   #132 (permalink)
Does anyone know if you can use the TM1000 module with a DX6i or do you need more channels?
Helis: Goblin 630c \ Velocity 50 \ 450X
Radio: DX-9
Sim: Phoenix
RCHN Citizen 48
lrs5 is offline        Reply With Quote Quick reply to this message
Old 06-07-2012, 10:15 PM   #133 (permalink)
NO, because the radio does not have telemetry, nor does it have a LCD screen.
Its all about having fun
ShaneJourdan is offline        Reply With Quote Quick reply to this message
Old 06-07-2012, 10:18 PM   #134 (permalink)
To view the telemetry data from the TM1000/1100 on the transmitter screen, you would need either the DX8 or new telemetry capable DX7 transmitter. However, it may be possible to use the DX6 and view the telemetry data using the Spektrum STi using either the iPad, iPod Touch, or iPhone.
Old 06-07-2012, 10:18 PM   #135 (permalink)
What I mean is can it be used with the Iphone interface \ do you need more than 6 channels to control the TM1000?
Radio: DX-9
Sim: Phoenix
RCHN Citizen 48
Old 06-07-2012, 10:19 PM   #136 (permalink)
Haha nevermind he beat me to it...
Radio: DX-9
Sim: Phoenix
RCHN Citizen 48
Old 06-07-2012, 10:21 PM   #137 (permalink)
Good point, didn't think of that.. lol
Old 06-08-2012, 07:36 AM   #138 (permalink)
Thx
I also got the links from cnc heli
Rappy 90
Old 06-08-2012, 07:41 AM   #139 (permalink)
There wasn't no mods done to the heli to run the dfc links. The only thing I had to do was, lower my swash plate about 2mm. And go back thru my setup, I had 16 degrees + an - on my blades. I haven't had alot of stick time with work and vacation and all. So far I really like it. It seem more responsive
Rappy 90
Old 06-09-2012, 06:40 PM   #140 (permalink)
With it's big brother. I'm going to get the CF fins and aluminum tail case for the 450. My goal is to make them look as close to eachother as possible.
