Old 07-14-2012, 12:22 PM   #1 (permalink)
Blade Forum Support
Default Things to check when buying the 130x new before 1st flight and go to forums
OK there have been a lot of people having good luck with this lil guy right out of the box and some having trouble right out of the box. So it looks like those who are having good luck out of this lil it was made on Tuesday thru Thursday and for those that is having issues theirs was made on a Friday and Monday (just a lil humor). Treat it like if you would a bigger heli mostly pre assembly heli (trex 450) or RTF ( blade 450) . So here is the list
1. Check feathering shaft for tightness and lock tight also check tail grips
2. Check blades for tightness they are to loose out of the box ( mains and tail)
3. Check gear mesh on A &B gear meaning making sure its not tight against round part of B gear and also pressed against the gear ( boom could be to close in or TT could be install backwards)
4. Make sure the A gear is not touching servo (mosfit) use a piece of paper to check this. if A gear is touching lightly sand A gear.
5. Check TT at C gear make sure the TT is not touching the tail shaft shelve that can cause vibes also if so just cut extra off .
6. Then test fly if you have a wag or bounce change gyro settings here is the forum for this and it is a sticky. https://www.helifreak.com/showthread.php?t=429592
Here are a few forums you could go by and a few mods you can do to make this lil guy your best friend
(If I forgot anything please add to it)
Hope this help everybody out
PS this is not a beginner heli you can't jump from a coaxial or jump on this heli for a beginner heli. start with maybe the msrx so you can at least get the feel of fbl and movement and orientations then move your way up.
Be blessed
Isaac
https://www.helifreak.com/showthread.php?t=434396
https://www.helifreak.com/showthread.php?t=434332
https://www.helifreak.com/showthread.php?t=434482
https://www.helifreak.com/showthread.php?t=433279
https://www.helifreak.com/showthread.php?t=434528
https://www.helifreak.com/showthread.php?t=434139
https://www.helifreak.com/showthread.php?t=433662
https://www.helifreak.com/showthread.php?t=430910
https://www.helifreak.com/showthread.php?t=435991
Sent from my A100 using Tapatalk 2
Jesus Rep Its all Good,Its all GOD
FPV Everything Now
GOD BLESS
tntburnett is offline        Reply With Quote Quick reply to this message
Old 07-14-2012, 12:28 PM   #2 (permalink)
Sticky this, please!
lespaulrob is offline        Reply With Quote Quick reply to this message
Old 07-14-2012, 12:33 PM   #3 (permalink)
Added descriptions to the links:
To show clearance between metal gear and servo using paper (pics)
For everyone with gear mesh issues I may have a solution- VIDEO
Problem solved: Many
[VIDEO] Is this the cause of the umbrella "A" gear issues?
Well got Bocas in my helo last night and tail res 100% gone.
Small DIY tail push rod mod pics and video
Tri-Flow is your friend, and other notes of interest.
Old 07-14-2012, 12:45 PM   #4 (permalink)
Blade Forum Support
Thank you for adding the description above each forum
Be blessed
Isaac
FPV Everything Now
GOD BLESS
Old 07-14-2012, 12:58 PM   #5 (permalink)
I just ordered a 130 x last night and this will be very helpful .
Thanks Tntburnett.
12/07/41 is offline        Reply With Quote Quick reply to this message
Old 07-14-2012, 01:01 PM   #6 (permalink)
Blade Forum Support
Thanks Tntburnett.
Your welcome just doing my heli duty.
Be blessed
Isaac
Sent from my DROIDX using Tapatalk 2
FPV Everything Now
GOD BLESS
Old 07-14-2012, 06:10 PM   #7 (permalink)
What about violent head shake? I maidened mine earlier today, and apart from intermittent head shakes it flew great. Everything on the head seems tight.
NRPY is offline        Reply With Quote Quick reply to this message
Old 07-14-2012, 06:32 PM   #8 (permalink)
Install better o-rings or use grommets in the head assembly.
Drivinfast247 is offline        Reply With Quote Quick reply to this message
Old 07-14-2012, 07:12 PM   #9 (permalink)
As above poster said, add the canopy grommets (extras included) to the swash because the o-rings are too small. I had VIOLENT head shakes on my heli, they went away with this mod!
https://www.helifreak.com/showthread.php?t=434366
Thread starter should add this to the list...
Pete
lovespicyfood is offline        Reply With Quote Quick reply to this message
Old 07-14-2012, 09:50 PM   #10 (permalink)
Great thread!
I stickied it.
Rick
Helifreak, the place to be!
rdlohr is offline        Reply With Quote Quick reply to this message
Old 07-14-2012, 09:54 PM   #11 (permalink)
Nice job tntburnett and (gibson) lespaulrob, clear and concise
Diviner is offline        Reply With Quote Quick reply to this message
Old 07-14-2012, 10:38 PM   #12 (permalink)
Sorry about sounding like such a newb here, but where are you finding a listing of what is A,B,C gears? Also, what is TT?
bigdessert is offline        Reply With Quote Quick reply to this message
Old 07-14-2012, 10:52 PM   #13 (permalink)
Blade Forum Support
A gear is the blk gear B gear is the lil metal gear being drove by the blk gear C gear is at the end of TT shaft near the tail case and D gear is the gear on the tail shaft.
Be blessed
Isaac
FPV Everything Now
GOD BLESS
Old 07-15-2012, 12:29 AM   #14 (permalink)
Starting at the closest gear that is powered from the main motor, just trace it back. Big crown gear on the main shaft is the "A" gear, little metal gear is "B" and so on. TT stands for torque tube, which is the rod that runs through the boom to supply power to the tail rotor.
Beaver Rat is offline        Reply With Quote Quick reply to this message
Old 07-15-2012, 04:34 AM   #15 (permalink)
TNT it might help a few people if you add this to your list.
Someone on this forum mentioned the screws for the main shaft were very short and only held one side of the main shaft, I found this to be true on my 130x.
The hardware kit [blh3122] for a 120 sr has longer screws of the same pitch, they are long enough to engage both sides of the shaft but not so long that the would stick out.
Just thought I would put it out there in case anyone wanted longer screws for their main shaft
P.S the longer screws also work good for stripped frame holes, they will grab further into the hole than the shorter OEM screws.
T-Rex 250 450x 300x 180CFX MCPX-BL B400 130X MCPX 230S NANO-CPX NANO-CPS MSRX 120 SR MSR MCX
IF IT CAN'T BE FIXED WITH DENTAL FLOSS, THEN IT CAN'T BE FIXED..LOL
Liduno is offline        Reply With Quote Quick reply to this message
Old 07-15-2012, 07:38 AM   #16 (permalink)
Originally Posted by Liduno View Post
TNT
Hmmm, thanks for the tip. Since I have a 120 SR and the hardware kit, I am going to do it. Also, Isaac, I am going to give your idea a shot also. I feel that all the mods I have tried so far from suggestions of different folks have really contributed to my heli being so smooth and stable in flight. When I first checked my helis out of the box and rotated the main blades, I new something was wrong because it did not feel smooth. One thing was the A gear was slightly rubbing on the FET and by using a suggestion from someone on HF, I sanded it down with 320 wet&dry sandpaper and that help a lot plus other mods.
Keep up all the good work guys. Love this forum and hopefully everyone will eventually get there's flying well.
Bob
Willyboy is offline        Reply With Quote Quick reply to this message
Old 07-15-2012, 12:17 PM   #17 (permalink)
Also check the soldering:
Well 2nd flight and first problem....
https://www.helifreak.com/showthread.php?t=434852
JookSing is offline        Reply With Quote Quick reply to this message
Old 07-15-2012, 12:29 PM   #18 (permalink)
Wow, there's some great info here, can't wait for mine to arrive this week hopefully
T-Rex 550 DFC, T-Rex700e v2, SAB Goblin 700
Sponsored By: Optipower, Elite Models, MKS-UK, RcBearings
Jamiem is offline        Reply With Quote Quick reply to this message
Old 07-16-2012, 09:47 AM   #19 (permalink)
Blade Forum Support
I forgot one more thing
Be blessed
Isaac
FPV Everything Now
GOD BLESS
Old 07-16-2012, 07:19 PM   #20 (permalink)
Pete
Yep, this worked perfectly! Thanks for the tip!
Now I just need to work on collective management. It's easy to bog this thing, and bogs can be deadly (the 130x falls right out of the sky).
