Old 10-17-2012, 01:22 AM   #1 (permalink)
Default First repair - [Video] What is this rattling sound?
This is my first time repairing my blade 450.
I replaced the main shaft and the main gear.
Spooling up with just the main shaft, main gear, main tail gear, and tail drive gear attached I hear a rattling sound. The motor spools up fine with nothing attached, so i've eliminated that possibility.
Any ideas? Is it the main tail gear or a bearing issue?
Thanks in advance
Buurin is offline        Reply With Quote Quick reply to this message
Old 10-17-2012, 12:42 PM   #2 (permalink)
check the main gear for teeth that are worn/broken. wouldn't hurt to check all the gears.
kuzican is offline        Reply With Quote Quick reply to this message
Old 10-17-2012, 06:47 PM   #3 (permalink)
Check that your owb is installed correctly. There is a shim.
Nologic is offline        Reply With Quote Quick reply to this message
Old 10-17-2012, 11:12 PM   #4 (permalink)
I just crashed the other day & have the same sound. Its the main gear. Its hard to see it but if you turn the main gear you'll be able to feel it when it makes contact with gear on motor
jonesb450 is offline        Reply With Quote Quick reply to this message
Old 10-18-2012, 02:48 AM   #5 (permalink)
Thanks for the suggestions.
I've replaced both the mail and tail gear, same issue.
I'm wondering if it is a bearing or I've heard of issues with the one way bearing hub not laying flat because the screws cause some imperfections in the plastic gear.
Thanks again
B
Old 10-18-2012, 10:23 PM   #6 (permalink)
Well mine did the same but never did see a prob so i kept flying .Untill the 4 x 8 plywood crash happened.I did replace the bearing after 2 years and all the gears.These things are so whiny sounding anyway...as long as parts ar`nt being chewed...i don`t wory about it. but...make sure the motor is not set too close in on the main gear..that will cause a lot of binding and undue noise.
Paper Money + Heli`s = Loose Change !!
Mr.D 4511 is offline        Reply With Quote Quick reply to this message
Old 10-20-2012, 12:57 PM   #7 (permalink)
emm..how do you adjust the motor position?....it seems static
All begins (Jun 2011).......
Next project:
MSH Mini Protos, 450 Scale Airwolf, BAH Mini Quad
cpmboy is offline        Reply With Quote Quick reply to this message
Old 10-20-2012, 02:01 PM   #8 (permalink)
Packers/washers installed ? in correct order ?, Motor-gear mesh ?. what does it sound like under load ? (main blades on or retarding main shaft by hand).
Trex :- 450SE V2 retired, 250SC retired, 450 PRO fbled Airwolfed, 500 ESP fbled Airwolfed, 250DFC, 450DFC, 500DFC, 800DFC. M690l, MR25P - Futaba/Align. Blade :- 4003D retired,CX2, MQX, 350QX v3 - spektrum. 4503D, 450X - spektrum/Savox.
jimmanyk is offline        Reply With Quote Quick reply to this message
Tags
blade 450, rattling, repair, sound, video
