Go Back   HeliFreak > R/C Electronics Support > Robird G31
Robird G31 RobirdUSA Factory Support Forum
Like Tree3Likes
Old 11-09-2012, 07:42 PM   #41 (permalink)
The instructions are shown in poor broken english in step 3....
''it's easier to fix a broken back than a broken spirit ''
ifheli is offline        Reply With Quote Quick reply to this message
Old 11-09-2012, 10:58 PM   #42 (permalink)
Ahh, I was wondering why the swash kept going to the extreme limits, that makes sense now
Gaui X5 FBL w BeastX! yesssssss!
"The Big T" TRex600N OS 50 +Flybar!
Synergy N5 O.S.55 Spartan Vortex
Himilou is offline        Reply With Quote Quick reply to this message
Old 11-10-2012, 12:30 AM   #43 (permalink)
Default cannot get satellites to light up
has any one else had this problem followed instructions plug ed the SRX into the srx 1 port tryed DSMX and DSM2 sats none of them will light up any ideas!!!
tunner777 is offline        Reply With Quote Quick reply to this message
Old 11-10-2012, 12:46 AM   #44 (permalink)
Have you already bound your satellites using a normal receiver?
gothicbunny is offline        Reply With Quote Quick reply to this message
Old 11-10-2012, 12:50 AM   #45 (permalink)
Default Not using a Receiver
I have tryed 3 differant sats none of them will light up
Old 11-10-2012, 02:41 AM   #46 (permalink)
Do you have the FBL only plugged into USB or do you have it powered separately?
Old 11-10-2012, 03:55 AM   #47 (permalink)
Default Powered Separately
I did what you said bound it with another receiver as it was new and never bound the strange thing is i tuned on the transmitter with the heli i bound it with and it lit up but i cannot bind it with this one very confusing do you hafto use a bind plug with this unit because it says nothing in the instructions at all
Old 11-10-2012, 05:26 AM   #48 (permalink)
From what I have read, the G31 is not capable of binding the satellites. They must be bound using a normal receiver first and then plugged into the SRX cable.
Even though the G31 itself can be powered through USB, you must also provide power to output bus for the satellite. The power through USB will not power it up. You can either use a standalone BEC or through one integrated into an ESC or you can use a NiMH battery pack. It must also be providing power to the correct power bus for either the SRX1 or SRX2 connection you are using.
Old 11-10-2012, 02:47 PM   #49 (permalink)
You basically are going to have to supply power to the g31 through 2 different ports for Sbus I power the servo side \ g31 through the Srx adapter with power originating at the rx unit. The tail is powered by connecting the other lead of my rx life battery to Srx 2 directly. Not sure if you can supply power through the DSM port on the SRX adapter though.
You might want to see if you can supply power by connecting the normal servo side plug of the adapter to your power source
Old 11-10-2012, 05:30 PM   #50 (permalink)
Hi Yea done all that I am using a separate NIMH battery to power the unit through the motor esc terminal , I am using the SRx1/All terminal for the remote with the SRX unit supplied I checked the power where the sat plugs in and i am getting 3.1v on the orange and grey wires so power isn't the problem I have 6 beastx units its not that i haven't done this befor i think i may have a faulty unit i have sen't them an email so i may hafto wait to hear from them Cheers!
Old 11-10-2012, 05:40 PM   #51 (permalink)
If anyone who has theirs fully functioning would be kind enough to do a diagram and post it? May help make more sense? A full Rx diagram, single and dual sat would be awesome.
I'd do mine but it hasn't shipped yet.
sent from my phone using circus midgets
Compass 7HV Gaui X5 Formula HD Cell 500
LawnDartHeli is offline        Reply With Quote Quick reply to this message
Old 11-10-2012, 06:01 PM   #52 (permalink)
Have you read the manual - there are pictures for all of these in the manual
Mikej is offline        Reply With Quote Quick reply to this message
Old 11-10-2012, 06:18 PM   #53 (permalink)
Looked through the downloaded manual, yes. Actual install pics are what Im going for.
Ill be using a Rx+sat, powering via bec. I assume I can just manage all that the same way I done with the zyx (ie: pulling the + lead from the esc plug and replacing it with the + from my bec), shouldnt run into any power issues with the Robird? I know it has 3 separate power buses, but I assume they will all just draw from the jumper wire from the Rx..and no need for a separate power source like with the sat only config?
Old 11-10-2012, 06:49 PM   #54 (permalink)
tunner777,
In setup guide in step0 Receiver what did you select under receiver, PWM, SBUS, DSM1024, or DSM2048?
If useing Spektrum Sat. Rx. you should select DSM1024 or DSM2048
Old 11-10-2012, 07:56 PM   #55 (permalink)
I thought I would upload the directions for the Black Widow version of the G31. The pictures in the instruction is of the older software.....
Old 11-10-2012, 09:10 PM   #56 (permalink)
Name:	G31 wiring.png
Heres a diagram for SBus \ G31 on my Nitro with non S Bus channel 3 running throttle
Old 11-10-2012, 10:43 PM   #57 (permalink)
Originally Posted by Himilou View Post
Attachment 365117
Instead of driving 3 cyclic servos thru the SRx adapter getting power from the rx, it is better to relocate the rx power to the G31 motor port. In this case G31 will power the rx and 1 throttle servo, putting less amp on the single cable of the adapter this way.
PhantomGT is offline        Reply With Quote Quick reply to this message
Old 11-10-2012, 11:44 PM   #58 (permalink)
Hi I selected DSM2048 I managed to get it working by copying the model i bound it to then changing all the functions back to what they should be set it all up now i can't get the ESC to fire up so i can test it when i connect power the esc gives the first part of the tone 3 chimes but it will not arm the motor get over one snag back to another tried going into set up mode but just 3 chimes will not even do that stumped again
Old 11-11-2012, 09:05 AM   #59 (permalink)
Keith, thank you so much for that file, i have now added it to my favorites list. Now i have a quick check link to go for any issues.
Atom500(FBL)., Gaui x4II (FBL) ;Trex450 sport (FBL). All with Ikon fbl gyro. AMA#1019423.
Tony .
tony521 is offline        Reply With Quote Quick reply to this message
Old 11-11-2012, 11:23 AM   #60 (permalink)
WE GOT STICKY'D!!
Thank you Bob O and thank you to all that's helped out!
Now lets keep the good info flowin', we got a real good start!!
