Like Tree2Likes
Old 12-07-2012, 09:39 PM   #1 (permalink)
Default Post your "HOW DO YOU DO THAT" Questions Here
If you have questions, please post hem here and I will try to get you answer as soon as possible.
Lou
Vector 550 Quad/Octo Multirotors
DJI WooKong Multirotor Controllers
Twin Bergen 44 Magnum Turbines - KERO Start FBL
www.circlecityhelis.com
lperagallo is offline        Reply With Quote Quick reply to this message
Old 03-01-2013, 08:50 PM   #2 (permalink)
Default timer on multiple flight modes
how do i tie a timer to multiple flight modes? or motor run time?
currently you can activate it by switch and for a certain flight mode...
i want the timer to be counting down once throttle stick is raised or flight mode changed from normal
any thoughts??
larryfl is offline        Reply With Quote Quick reply to this message
Old 03-02-2013, 10:39 AM   #3 (permalink)
Hi,
You can set the timer to be started and stopped through the throttle by the following method:
9.3.2 Sticks / Switches Setup
This menu contains System Stick/Switch settings and configuration.
Various functions can be activated by any Switch, Stick or Knob
position. Switch setting enables you to set the points when your
desired function/timer/telemetry can be turned ON or OFF.
1. Switch & Stick Type
The first menu line item lists the control’s number and the second
item lists the type of control element. Using the “F2” and “F3”
function buttons you can scroll through channels, with the “F5 (Ok)”
button you can exit the menu screen.
2. Switch ON/OFF Points
Any proportional function can be set as a system switch. This menu
item enables you to assign the travel percentage at which a desired
function can be turn ON or OFF.
“Switch-ON” – The point when the control element positon will
switch a function ON.
“Switch-OFF” – The point when the control element positon will
switch a function OFF.
By default, the system setting for all proportional channels and for all
inputs is set to function the same as a 3-position switch.
a) A function above this point is considered to be “Switch ON”
b) A function in this range (middle) can be considered to be either
“Switch ON”or “Switch OFF”
c) A Function below this point is considered to be“Switch OFF”
If the switch setting is set at same level for “Switch ON” and “Switch
OFF”the proportional channel/function output will be the same as a
2-position switch.
3. Required Preflight Position
For any functions assigned to the Switch, Knob or Stick; any preflight
initial position can be programmed. If the pre-programed Switches,
Knobs or Sticks are not in required preflight position while model is
being activated, system will refuse to switch to this model. The
transmitter screen will display the function that is not in preprogrammed, correct preflight position.
In section 9.4 under timers it explains how to set up timers and control which flight mode you want the timer active. Here are some of he steps:
1. Editing a New Timer
a). Timer Name
When you add or change the timer name, the name is automatically
displayed in that timer’s box on the main desktop.
b). Initial Timer Value
This is where you can set the starting value for the timer. You can set
a negative or positve value for this starting point.
c). Target Timer Value
Here is where you can set the target value for the timer. This can be
set as a positive value or a negative value. The initial value and target
value will determine the timer‘s direction. If the target value is
smaller than the initial value the timer will count down. If the target
value is larger than the initial value the timer will count up.
d). Timer type
There are three possible timer types:
• Standard – The timer starts or resumes when the chosen switch
is triggered and the timer pauses when the switch is turned off. The
timer’s value is not reset when the timer is paused. Use the
„F4(Stop)“ button to stop the timer.
• Laps - The timer starts when the chosen switch is triggered.
Once the timer is started, each time the switch is triggered, the
elapsed time is stored in memory and the timer resets to your chosen
initial value. The lap number changes and the current lap time is
displayed each time the switch is triggered. Use the „F4(Stop)“
button to stop the timer. Then, you can use the „3D button“ to scroll
through the stored lap times.
• Free-Running – The timer starts counting when the chosen
switch is triggered. Once started, this type of timer can only be
stopped using the „F4(Stop)“ button.
Use the „F5(Clr)“ button from the desktop to reset the timers.
e). Report type
You can use this item to select the type of audio alarm for the timer.
Some of the choices will create an audible warning which sounds
just before the target value is reached.
f). Switch
This item is used to assign the switch or button to start the timer.
See chapter 9.7: „Select input control“.
g). Reset type
The „F5(Clr)“ button is used to reset the timers.
If you select „Short reset“ the timer is reset by a short press of the
„F5(Clr)“ button.
If you select „Long reset“ the timer is reset by a long press of the
„F5(Clr)“ button.
h). Flight modes active
This item allows you to select which flight mode(s) for which the
timer is active.
Hope this helps. The radio lets you do just about anything you want to do. It takes some configuration and testing, but with a little practice you can get it. I now have a base model set up that does nothing but have all my base parameters set up that I then copy to each new model I set up. The I just go back and change my default stick position set up for start up and set up my throttle curves and pitch curves. I've got three helis and two quads set up and once I got through the first heli it is a breeze to set up new ones.
Lou
Old 03-02-2013, 01:05 PM   #4 (permalink)
Lou,
thanks for the detailed response.
Looks like that will cover it, ill give it a try later today
Regards
Old 03-15-2013, 11:05 AM   #5 (permalink)
Default how to setup failsafe on a 2.4EX R10
Hi my setup is
radio= JR9X + 2.4 Duplex TG2 module
rx= 2.4EX R10
I need to set channel 7 to a preset value so that DJI AceOne can trigger return to home and other channels just hold.
I have Jetibox old and new.
Are there step by step instructions available any where? I have sent an email to Jeti for help but there has not been a reply.
Thanks,
Ahmet
helicek is offline        Reply With Quote Quick reply to this message
Old 03-15-2013, 02:23 PM   #6 (permalink)
Lou
Do you mean that you can actually copy and paste some specific setting from one model to an other and if yes could you tell me how?
Or do you copy the complete setting and then modify it for the other model?
c
I know you can duplicate a model but can it be more specific?
TDSF, TDR-II, Triabolo, 2 X TDR, Logo 700,Protos evoluzione, T-Rex 700Dominator, Drake & Raw, SpiritRS, Jeti DC-24,HW,Kosmik,Jive Pro
Puttputt maru is online now        Reply With Quote Quick reply to this message
Old 03-15-2013, 03:28 PM   #7 (permalink)
c
For me, it is easier for me to copy the entire model and modify what I need to change. I am not aware of any way to just copy certain parameters.
Lou
Old 03-15-2013, 06:15 PM   #8 (permalink)
Lou
Ok thanks, I see how it can save time that way
Old 03-15-2013, 07:16 PM   #9 (permalink)
Lou
+1
Team - "Self Interests" -
Flying what I want to, simply because I enjoy it!
Seasick78 is offline        Reply With Quote Quick reply to this message
Old 03-17-2013, 05:35 PM   #10 (permalink)
How do I set up an alarm when the signal is becoming weak? It seems like the alarm goes off only when the signal is lost... but that's a bit too late ;-)
This would be useful when flying FPV.
Jotto is offline        Reply With Quote Quick reply to this message
Old 03-17-2013, 06:23 PM   #11 (permalink)
Go to System - System Sound - Low Signal
You will see at the end of the line a number. It determine the strength of your signal where the alarm will sound from 0 to 3. It is at 1 by default.
I have assign the voice saying: " warning weak signal " to it (Weak_Sig.wav)
Old 03-18-2013, 03:16 AM   #12 (permalink)
Ok, thanks! Is this done on the transmitter? I thought it was done on the receiver, like with the capacity and voltage alarms. I'm using a ProfiBox -- I'll see if I can find this setting there.
Old 03-18-2013, 07:57 AM   #13 (permalink)
Yes It is done on the transmitter, I have the DC-16
Guess if you can't find it you will have to get one too
One more reason
Old 03-18-2013, 08:23 AM   #14 (permalink)
Reading the DS-16/DC-16 manual I have noticed there are quite a bit more capabilities with the radio alarm trigger points than with just the Profi. Late March can't come fast enough....LOL
BustedRaptor77 is offline        Reply With Quote Quick reply to this message
Old 03-18-2013, 11:24 AM   #15 (permalink)
Default Re: Post your "HOW DO YOU DO THAT" Questions Here
One more reason
Actually I have preordered the DS-16 =)
Sent from my cell phone - I apologize for any spelling errors
Old 03-18-2013, 02:13 PM   #16 (permalink)
Great The more we are the more help we get when we are stuck.
Guess you can't wait.
For once I am glad I am a pinch flyer, I got a lot of " funny " comment at the field when I was flying with my tray with my JR transmitter.
Now I guess it will be more the " I want one " looks.
One thing for sure you will be glad you waited for this great radio
Old 03-26-2013, 05:39 PM   #17 (permalink)
I'm setting up the governor on a Mezon 90. One thing is a bit confusing: MinRpm vs MaxRpm.
Is this determined by the input throttle signal so that 100% throttle yields the MaxRpm and 1% throttle yields the MinRpm?
Old 03-26-2013, 05:48 PM   #18 (permalink)
My Mezon 90 is set to fixed endpoints 1.10 and 1.90. I also use constant rpm gov mode.
In my radio I simply set my throttle curve to zero. Armed my motor on the bench with no blades installed. I then set my throttle to mid stick and slowly increased that point on my curve until the motor engaged. It then governed at my "low rpm" setting, so I locked in that value on my throttle curve as a flat curve (in my case 20%). Whatever you have programmed in the Mezon for "max rpm" will be achieved with a 100% curve.
Less than 100% will give you a value between your min and max (just run it and watch your Profi and you'll know what it is).
I have my min/max set to 2500/2700 and my throttle curve is 20% on idle 1 and 70% on idle 2 which gives me 2500 and 2650 respectively.
Old 03-26-2013, 05:54 PM   #19 (permalink)
if you are flying with values for example of 1700 and 2100 you want to set your values just above and below:
Min = 1690
Max = 2110
This is what I saw they advice on the European forum. I have not tried it yet in real life though.
Castle has good video on how to set their product but it works just as good for Mezon
Old 03-26-2013, 06:12 PM   #20 (permalink)
Ok, thanks guys!
