Like Tree3Likes
Old 05-08-2013, 03:27 PM   #701 (permalink)
The Airetic
Originally Posted by night wolf d View Post
A hot ESC can be caused by to low a head speed if you run your heli in IU and its getting to hot to touch check your gear mesh isn't to tight and keep a close eye your Esc just In case it failing.
If your ESC is alright an external BEC is another option you could try instead of replacing your stock ESC , then your ESC is supplying power for the motor only.
Either a Yep or CC ESC would work ,I believe most use the CC Ice lite 50a with good results and now its superseded you may be able to pick one up cheeper!
The 12t will give you better flight time for sure and if your interested in a Bec I'll let you know how mine goes when I get it , install it and try it out.
KX is using stock Esc (I believe),H450, mg servos with an external Bec you could ask him how's its going?
NWD.
Close. I run the stock ESC, stock 440 motor, MKS DS92A+ cyclics, MKS DS95i tail, and a Polaris Gryphon BEC.
I have not noticed any temp issues at all with this set up. I also fly in high temps here in Cent Am.
I do intend to go to the H450 if and when my 440 poops out on me. Likely I'll also add a Castle Ice or Phoenix when that happens as well, just to get the governor.
Free Agent....With standalone opinions.
KiloXray is offline        Reply With Quote Quick reply to this message
Old 05-08-2013, 04:53 PM   #702 (permalink)
Off on one, close! Thanks KX.
I've read the H450 works really well governed and I've been told it enjoys low timing setting as well and if my stock ESC fries I'll have no option but to upgrade and have these options available for use!
On a side note I recived my Gryphon polaris and I was sent a tiny booster instead .
OXY3+ Qube. OXY4+.Lynx Ultra 450X-L 360.Compass 6HV Ultimate. COMPASS CHRONOS
Lynx Heli Innovations Team Pilot
night wolf d is offline        Reply With Quote Quick reply to this message
Old 05-10-2013, 04:20 AM   #703 (permalink)
I have a left over 450MX from my T-Rex (it's on 6S now). Anyone know how that one compares to the 440H?
The 450MX has 3400KV and the 440H has 4200KV, so I guess the MX has a lot more torque. Which again should allow it to be geared taller?
Guess it's a bit heavier with it's 83 grams? How much is the 440H?
Cheers
Micro: XK K110, Mini: Gaui X2 Formula
Medium: 330X 6S, G380
Big: G500, Align 700E
DX8, Phoenix
SHYguy is offline        Reply With Quote Quick reply to this message
Old 05-10-2013, 05:28 AM   #704 (permalink)
Cheers
Your 450mx is closer in specification to th EfliteHeli H450 brushless outrunner motor ,3600Kv 6 pole 82grms 3.5A @10v 40A continuous 55A max burst ,Input Watts ;610.
This motor works really well on the B450x geared on a 12t or 13t pinion.
The Eflte 1360H 440 weights 68grms.
NWD.
Old 05-10-2013, 05:38 AM   #705 (permalink)
NWD.
Thx a lot! When using 12 or 13T pinon, do you run governor then or just 100% flat?
Part no for those pinions?
With Lynx helical gear, where could I get pinions for that? I see Lynx have 12-13-14 for 3.17mm shaft - is that what the MX has? (sorry, at work, and couldn't find info online)
DX8, Phoenix
Old 05-10-2013, 06:00 AM   #706 (permalink)
I use the Eflite H450 with a 13t pinion at 80% . Run approximately same head speed as stock just with alot more torque! Stock Esc no governor.
The 450Mx has a 3.5mm shaft I I don't know what pinions are avaliable to use on a B450x 0.5mod.
Sorry can't help you there SHYguy.
NWD.
Old 05-10-2013, 06:17 AM   #707 (permalink)
NWD.
Thx! A bit tricky there... Lots of pinions for Align, but those are 0.6 mod vs 0.5 mod for the Lynx stuff Probably Lynx will supply more options in the future...
Can't see me going back to the stock gears, the Lynx slant ones are soooooo much better!
DX8, Phoenix
Old 05-10-2013, 07:35 AM   #708 (permalink)
Originally Posted by Ed Olson View Post
Newest Fusuno on it's way, with a slight customization. Hope it turns out well. Pic as soon as it arrives.
RichKnapp is offline        Reply With Quote Quick reply to this message
Old 05-10-2013, 09:23 AM   #709 (permalink)
Decided to grab a new canopy, the stock one was blacking out on me at distance.
Blade Nano CPx BL, Blade 130x, Blade 450x
Maxx27 is offline        Reply With Quote Quick reply to this message
Old 05-10-2013, 09:33 AM   #710 (permalink)
Default Re: Post pics of your Blade 450X
nice
Sent from my SGH-T959V using Tapatalk 2
~~~Lynx Heli Team~~~
Ed Olson is offline        Reply With Quote Quick reply to this message
Old 05-10-2013, 09:35 AM   #711 (permalink)
Looking pretty good there.
Old 05-10-2013, 12:59 PM   #712 (permalink)
Looks great!
Got my new lid in the mail today too! It fits a lot better than the stock one, and looks beautiful
ID:	419309   Click image for larger version
ID:	419310   Click image for larger version
ID:	419311   Click image for larger version
ID:	419312   Click image for larger version
dragnse7en is offline        Reply With Quote Quick reply to this message
Old 05-10-2013, 01:58 PM   #713 (permalink)
Old 05-10-2013, 04:10 PM   #714 (permalink)
Originally Posted by dragnse7en View Post
Looks great!
Yours is looking good too
Old 05-10-2013, 04:49 PM   #715 (permalink)
A million thanks right back at yah! Too bad we live far apart - we'd be a sweet tandem flying team together.
I love that white on yours! It pops!
Old 05-10-2013, 05:11 PM   #716 (permalink)
dragnse7en I like that canopy it looks good.
Allen_H is offline        Reply With Quote Quick reply to this message
Old 05-10-2013, 05:22 PM   #717 (permalink)
Thanks hoss. I've seen your works, and coming from you - I'm much obliged.
Old 05-10-2013, 08:40 PM   #718 (permalink)
Compass Chronos | 7HVU | 550U | Atom 500 | Oxy 5 HF 560 | 5 HF 625 | Gaui X3 #1 | X3 #2
cyclo is offline        Reply With Quote Quick reply to this message
Old 05-10-2013, 08:43 PM   #719 (permalink)
Sweet photo!
Please don't hurt me, but the main blades don't look like they're tracking. They look bad.
Beautiful pic though!
Old 05-10-2013, 09:00 PM   #720 (permalink)
Sweet photo!
You're right the poor tracking is actually causing some vibes... I just need to spend time on it.
