Old 08-15-2013, 12:43 PM   #41 (permalink)
Thanks for the reply.
The gears are good, I have now had to change many times due to crashes mainly caused by this tail blow out issue.
I've purchased many tail upgrades today, normal servo, lynx tail housing, lynx pitch slider ect.
However, I suspect receiver issues because sometimes its not there and fly's great. It sometimes appears during a flight, but never disappears during flight unless I re initialise the receiver. I think I need to clarify this before I fit some expensive upgrades.
Thanks again
Kev
CPX450, HobbyWing 35A ESC, Scorpion 2221-8, HS65MG's, HK401B, InoLabs D401HB
Trex450 Sport Combo - All Stock
Trex600ESP Combo, converted to belt drive.
HK600 Stock Build Project
bionicbone is offline        Reply With Quote Quick reply to this message
Old 08-15-2013, 04:36 PM   #42 (permalink)
More easy stuff to check if you haven't already -
Look over the tail servo. Do the two white gears line up OK? Is the motor secure in the motor mount (the black bands around the motor aren't cracked and the motor can't slide in the mount)? Is the servo slider mechanics secured to the circuit board (the screws tend to get loose with time)? Do the wires connecting the 3-in-1 to the servo and from the board to the motor seem soldered ok (some intermittent problems have been caused by poor solder connections)?
Does the heading hold function work in a bench test? Unplug motor, apply power and provide some throttle to activate the gyros. Rotate the 130x back and forth a bit. Do you see the pitch slider move as the 3-in-1 tries to return the 130x to the original heading?
Kevin B.
"Fun, Learning, Friendship and Mutual Respect" - good words to live by
RC: 300x, 130x, DX6i, iCharger 106b+, Phoenix Sim
Other: Atmel AVR microcontrollers, electronics, 3D printing
helibus is offline        Reply With Quote Quick reply to this message
Old 08-16-2013, 12:23 AM   #43 (permalink)
Hi, I checked your suggestions, the servo circuit was a little loose so thats now tight. There does seem to be a slight bit more play in the tail servo than the cyclic servos, about double, not sure how this would effect things.
Your test with the motor disconnected gave some interesting results.
For example, disconnect motor, turn tx on, power up heli, check motor is disconnected, apply half throttle, servos activate and are working normally, either just wait or roll the heli around, or use the tx controls, after around 1 1/2 minutes the servos starts to shut down randomly, some go first. Reduce throttle back to low and servos reset.
Can someone confirm this is normal?
Batteries are good and when working servos are working as expected for FBL operation and tail is acting like HH mode.
Cheers
Kev
Old 08-16-2013, 12:40 AM   #44 (permalink)
Update, I notice that with the servos active the if you push cyclic right and hold for 5 seconds you need to push cyclic left for 5 seconds before the servo moves left. I guess this does not happen in the air as FBL works differently on the bench but it is worth noting. It does not answer my question above though of servos shutting down.
Kev
Old 03-08-2014, 07:38 AM   #45 (permalink)
Default Blade 130x Tail Issue - Spinning Tail, Tail Blowout, Issue / Resolution
Suddenlt tail does not anymore hold on some maneuvers. I have metal C and D gears and carbon TT. Are there other reasons than round gears or tt? Tail servo is new and cleaned.
vmmattil is offline        Reply With Quote Quick reply to this message
Old 03-08-2014, 01:54 PM   #46 (permalink)
D gear was a bit round
Old 03-28-2014, 08:09 AM   #47 (permalink)
By this you mean the D hole was worn out and to much twist / rotational play?
150DFC - 180CFX - 300CFX - DX6
JSP816 is offline        Reply With Quote Quick reply to this message
Old 04-02-2014, 07:47 PM   #48 (permalink)
My tail also doesn't hold very well when inverted and doing mild 3D
Any suggestions?
Old 10-01-2014, 06:29 AM   #49 (permalink)
After wearing out my metal C & D gears I went back to plastic, the are cheap and quick to replace.
What I have found is that some Loctite 680 on the D gear pretty much prevents it rounding out. If I have a crash it is more likely to strip a tooth on the D gear. I also have done the same with the C gear but I don't go through them very much so I suppose it is working.
Blade nano, 130X, 450X, mCPX BL, 180CFX, DX18
sosman is offline        Reply With Quote Quick reply to this message
Old 10-05-2014, 11:09 PM   #50 (permalink)
A small grain of sand seized my tail servo today causing it to over heat and melt the motor holder a little. The tail definatly is the weak point in this model. Anyone have suggestions to protect the servos?
mattbeau is offline        Reply With Quote Quick reply to this message
Old 11-15-2015, 08:53 PM   #51 (permalink)
Thansk for this great post. I was finally able to find the problem with my spinning tail: D gear round inside.
One more tip from me: a backwards installed tail shaft collar will cause vibrations. Check that the square side is outwards. Then, the bearing can do its work.
had a problem today with my 130x doing a hard tailwag, read this thread and sure enough i put that collar on backwards. thanks alot!
newblnc is offline        Reply With Quote Quick reply to this message
Old 11-17-2015, 02:14 AM   #52 (permalink)
On a stock tail case I put a bearing on collar side and put the collar on backwards,works great for me.
CrashandBurn is offline        Reply With Quote Quick reply to this message
