Old 08-16-2013, 04:12 AM   #1 (permalink)
Cool STRETCHING the Blade 450 X
Originally Posted by KiloXray View Post
I have questions about this! Please do start a thread! You mention "stretching parts". How exactly are you doing this? I suppose All you need is a longer boom and belt. Where do you get those? How long is the stretch?
Ok I try to do my best for you guys to write my knowledge down.
Well I first started without stretching. I just mounted the Radix 350 on it. I started with slow test flights afraid of tail rotor strikes. I got none. Even with very hard flying. There were three reasons for it I think. One, I have the LYNX dampeners that are solid POM rings so very hard. Secondly, The Radix are very stiff so the overall flexibility is low. THird, I synchronized main and tail rotor to not hit each other, sounds wired but works.
I have to say this is an easy way to fly 350 blades on a "stock" 450x but maybe not the best. I havent realized aerodynmic tail weakness or interference but the efficency could propably better.
Due to a light accident I damaged the Radix...So I tried the Spinblades Red Tips 350mm.
They are verly flexibel, light, and very fast. Here it happend to get tail strikes.
So I finally decided to stretch for real.
Tarot hast some stretching parts for the Trex. So I tried the Tarot 453T Long Tail Belt.
For the boom I bought a cheap alluminium tube 14 x 12 x 1000mm. 1mm section thickness is more than stock so it is kind of heavy. Youn can use carbon fiber as well, I did not yet.
Cut it to 420mm, cut one guide slot for the frame mount and the two holes for the tail case. It it not that hard if you are able to do some handcraft.
Thats how it looked.
You see I havent stretched the tail pushrod yet. which I later did..
All I can say is it flys awesome! You never want back to shorter blades, that is what all say
Well I even damaged those blades not even knew how..
So I tried the tarot 360mm Blades, that actually are also 350mm ones an like the compass warp ones.
And guess what I damaged them too. Seemed like a fatigue breake of the main grip push rods....
Liked the Radix best so far but not their price..so the original compass warp blades are on its way to me now.
Ok now it is time for questions from you.
Sup?
ID:	443906   Click image for larger version
ID:	443907   Click image for larger version
full 2s/3s mcpx , 450x 4s BLHeli, Rex500/550 stretch BLHeli TARANIS
Diablol is offline        Reply With Quote Quick reply to this message
Old 08-16-2013, 04:31 AM   #2 (permalink)
Firstly, congrats, nice job.
How are you damaging your blades? They hit the tailblades even with the longer boom? Boom slipping?
How is the CG?
spykez is online now        Reply With Quote Quick reply to this message
Old 08-16-2013, 06:02 AM   #3 (permalink)
Thank you!
Differently.
Radix crashed in high grass, not hitting my landing area..suddelny kids were around
Spinblades..dunno, either at "lawn mowing" or it collied with a fly..no clue..lol
Tarot due to a fall out of 30 meters because of the linkage breake.
Had an unlucky series...
No.
How is the CG?
Well the CG is actually perfect at the moment. But I fly 3s 2400mah or 4s 1800. they are heavy enough. It just depends on your setting.
Old 08-16-2013, 07:29 AM   #4 (permalink)
Yes, great job. What is the rest of your setup, esc, servos etc.
wab223 is offline        Reply With Quote Quick reply to this message
Old 08-16-2013, 07:54 AM   #5 (permalink)
you see a part in the video description but here detailed
I run an Align 450 MX 3400kv with a Turnigy Plush 40A ESC flashed with BLHeli !
Gryphon Polaris BEC
4x TGY 306 Servos
EDGE tail blades
Alu tail grips
3s 2400mah for up to 13min cruise
4s 1800mah for smackdown
Lynx dampers
Old 08-16-2013, 10:12 AM   #6 (permalink)
The Airetic
Awesome! This is super cool. I think making a boom from CF would be very easy. I may try this, later this year.
I appreciate the write up. Thank you very much.
Free Agent....With standalone opinions.
KiloXray is offline        Reply With Quote Quick reply to this message
Old 08-16-2013, 10:14 AM   #7 (permalink)
That won't work. They don't spin at the same RPM so they will get out of time almost instantly on spool up. The only reason blade syncromesh works with the CH-46, CH-47, Kaman V-Max, etc is because the transmission systems are geared to spin the heads at exactly the same RPM.
Barshinderson is offline        Reply With Quote Quick reply to this message
Old 08-16-2013, 10:30 AM   #8 (permalink)
I am not able to say for sure if it really works.
BUT you dont need the same headspeed. All you need is a transmission with an even value. E.g. if the main head does 1 round the tail does 3 full rounds and NOT 3 and a half.
I can tell because my setting hasnt changed during flight and I tested many rounds on the table.
Much more unknown are the (aero)dynmaic positions of the blades. So you can only fit it under static conditions.
Old 08-16-2013, 10:34 AM   #9 (permalink)
You don't have an even ratio if you're using the stock gearing. If you aren't, then I missed that. The stock 450X has a fractional gearing ratio. It is not exactly even.
Old 08-16-2013, 10:41 AM   #10 (permalink)
Ok!
I havent checked the mathematical gearing yet so I trust you. If thats true it is an important information. Thanks.
Fortunately I fly stretched now
EDIT: wait what is the stock gearing again?
I run a 12T
EDIT: ^^forget about it that is not important because the tail gear is always the same..
EDIT: Do you know the exact tail ratio? Isnt it exactly 5:1 ?
Old 08-16-2013, 11:26 AM   #11 (permalink)
The Airetic
Tail ratio should =# of teeth on main tail gear / # of teeth on the belt gear in the frame.
I don't know what those numbers are though.
Old 08-16-2013, 12:00 PM   #12 (permalink)
It IS exactly 5:1
This supports my experience as well.
Old 08-16-2013, 12:25 PM   #13 (permalink)
The Airetic
So did you decide on 420mm boom length because that is what you needed for that particular belt? The tail looks like it is a little too long. Do you know of any other belts that at a tad shorter?
Also. I take it the belt meshes perfectly with the stock 450x gears?
Old 08-16-2013, 12:38 PM   #14 (permalink)
I run a 12T
If you change motor pinion sizes, it is important because the main gear is locked to the tail gear below it in powered flight via the OWB, so they spin at the same RPM. Head speed goes up or down, so does tail speed in a corresponding manner in coupled flight.
Old 08-16-2013, 03:38 PM   #15 (permalink)
yes, my wish would also be a little shorter.
that is typical for stretch kits, you could also use 360mm blades although there were rarely none and larger tail blades.
I actually tried another belt before. It was an industrial one that fit about the same measures and was shorter.
But it was too stif and couldnt run the small diameter at high speed well. And it was very expensive.
I am sure there are a enough companys that would have the right one. But I got the Tarot one fast, easy and cheap and it runs well. Those 10mm are not so bad it looks good in the air I find.
On that picture where it looks so long is no tail boom support that makes it look even longer! You will see.
It is desinged for the Trex 450. Those belts are useable for the blade too.
Old 08-17-2013, 06:40 PM   #16 (permalink)
The Airetic
Does anyone know the dimensions of the stock belt? Specifically, the length and tooth count? I am out of town for a couple of weeks and don't have one on hand to count or look at.
Old 08-18-2013, 07:00 AM   #17 (permalink)
2M-810-3
Profile typ is 2M
810 mm long (open ring)
405 teeth or 405mm long closed
Old 08-18-2013, 03:17 PM   #18 (permalink)
The Airetic
Thanks! I am on the hunt for a belt that is in the 425-440mm range.
Old 09-17-2013, 04:06 PM   #19 (permalink)
Default STRETCHING the Blade 450 X
Kilo Xray, that is an awesome canopy, where did you get it?
ST1S is offline        Reply With Quote Quick reply to this message
Old 09-17-2013, 06:44 PM   #20 (permalink)
Gryphon Polaris BEC
4x TGY 306 Servos
EDGE tail blades
Alu tail grips
Lynx dampers
Have you had any problems with slop with the lynx dampers? I'm running them but don't like the slop they have.
Temptation is offline        Reply With Quote Quick reply to this message
Tags
450x, radix, stretch
