Old 02-09-2014, 08:30 PM   #1 (permalink)
Default Which spindle is right for FBL?
The kit has two spindles included, one 52.67mm, and one 51.63 mm. Which one is the correct one to use with the low profile flybarless head?
Thanks,
Rick
Helifreak, the place to be!
Old 02-09-2014, 08:37 PM   #2 (permalink)
The long one. Use the wide spacers between the grips and the rotor head with it.
Oxy 3 - MSH Mini Protos - MSH Protos Max 700 - Taranis
Thanks to Oxy Heli and MSH-Direct.com
Former Username: Code3Medic
Russell Harding is offline        Reply With Quote Quick reply to this message
Old 02-09-2014, 09:43 PM   #3 (permalink)
OK, thanks. Thanks. I took a chance and did exactly that. The strange part is that both grips seem a bit notchy unless I pull out on them when I turn them. Is that typical?
Rick
Old 02-09-2014, 09:56 PM   #4 (permalink)
Make double sure you have all the thrust bearing parts installed properly.
Personally I have flown often with somewhat notchy grips (easily move with one finger of pressure in the grip arm), but it should be pretty smooth when it is a fresh build.
The way I see it, it is a dynamic system with a lot of outward pressure. Also consider how hard the servos have to work to maintain AoA of the blades compared to some light notchyness in the grips.
Disclaimer: I am not a perfectionist.
Old 02-09-2014, 10:07 PM   #5 (permalink)
Thanks. When I built my Rush 750, the grips were quite tight until after I had spun it up once. I thought maybe these were similar. I managed to get the grips upside down while watching Paul and Ringo play so I get to pull them apart anyhow. I did the first side right but must have flipped it prior to installing the second one. I hate when I do that.
Rick
Old 02-10-2014, 02:22 AM   #6 (permalink)
Yeah, from memory that's normal - when you pull on the grips and turn them they smooth.
Mini Protos, Voodoo 400, Protos 380, Protos Leggero 700 & 700X, Diabolo 700
Chris Nifty is offline        Reply With Quote Quick reply to this message
Old 02-10-2014, 02:37 AM   #7 (permalink)
Rick
Well if when you pull out on them slightly they turn smoothly then it won't be a problem in flight with the amount of centrifugal force
My blade grips have always been somewhat notchy on the bench, never noticed anything wrong in flight though.
"Beater" Mini Prtos stretch 6S : Scorpion 2520-1360kv, Edge 353SE
"Princess" Goblin 570 stretch 12S : Xnova 4025-560kv, Cyclone 615
FrSky Taranis - Heli-X 5 - MKS, YGE, SK540 - Yamaha XJ6F
Aryemis is offline        Reply With Quote Quick reply to this message
Old 02-10-2014, 03:19 AM   #8 (permalink)
Yep, it's normal, grips get notchy once you tighten the spindle bolts. I was able to get them smooth by only snug tightening the spindle bolts and leaving blue loctite do its work. You have to precisely measure the length of spindle shaft on each end, then carefully tighten both sides so that you get equal length of thread in.
Packing thrust bearings with a lot of quality grease helps too. I use the Hudy red performance grease for this -> http://www.fast-lad.co.uk/store/prod...ducts_id=18374
It's a different story with the new version of Lynx dampers. Head is super tight when you assemble it and bearings are notchy whatever you do... It makes the Mini razor blade sharp once in the air so I don't care anymore
Tom
RCHN#233 | Lynx Heli Innovations Team
Goblin 700
Carbon |
Protos Max | Goblin 570
baui2000 is offline        Reply With Quote Quick reply to this message
Old 02-10-2014, 06:05 AM   #9 (permalink)
OK, thanks. I won't fight it then. I'll just flip my grips and call it a day. I'm pretty happy with the simplicity of the head/main shaft/main gear design. I'm glad I went with the low profile hub with the wash out arms connected directly to it.
Rick
Old 02-10-2014, 09:39 PM   #10 (permalink)
+ 1
Shtumpa is offline        Reply With Quote Quick reply to this message
Old 02-15-2014, 08:24 AM   #11 (permalink)
I think I have assembled and reassembled the head about 10 times. Only once was it not notchy. I always have one smooth and one notchy.
Mini Prtos 6S Stretch - DS95/DS95i, Mini V-Bar, YGE60 VBAR Ready
CrashAddict is offline        Reply With Quote Quick reply to this message
