Go Back   HeliFreak > R/C Helicopter Support > 150 Class Electric Helicopters
150 Class Electric Helicopters 150 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 02-13-2014, 11:40 AM   #1 (permalink)
Default Servo saver mod
Edit: This can apply to any micro that uses rotary servos, really. I've personally done it on several Walkeras as well as my 150.
Back when I first started flying, I was flying Walkera micros. They've been using rotary servos for a while, and I was constantly stripping servo gears. Once I found the servo saver mod, I never stripped another servo. I've since done the same mod on my 150 and as expected, have not stripped a servo since. Instead, the servo arm jumps, and you just have to put it back before you fly again.
Follow these instructions: http://benmlee.com/Genius_Servo_Saver.htm
Make sure you read every step. If the arm is too loose, put some kind of rubber ring around it to make it tight. Pic attached below of what I've done.
gabeoravitz is offline        Reply With Quote Quick reply to this message
Old 02-13-2014, 12:39 PM   #2 (permalink)
Is the rubber around the servo arm fuel tubing?
Thanks,
John
Team Synergy, Rail Blades, Lynx Heli
Citizen #396
jmiceli11 is offline        Reply With Quote Quick reply to this message
Old 02-13-2014, 01:31 PM   #3 (permalink)
No but that stuff works too. I don't even remember what these little rubber things were for. I had them in my box of random stuff. I think they might have been rubber skid grips things for my 450 or something. Or maybe 250 dampers of some kind? I sliced them in half to make them thinner.
Old 02-13-2014, 03:18 PM   #4 (permalink)
That's a pretty neat idea. I wonder if it makes sense to do something like this on larger helis (250/450) as well?
mba83 is online now        Reply With Quote Quick reply to this message
Old 02-13-2014, 03:34 PM   #5 (permalink)
I may have to give this a shot.
Worst case if it didn't work is I'd need a servo gear set that includes a new horn anyways, so it's definitely worth a try if it can save the gears.
I'll have a look at the hardware store to see if they have some small rubber o-rings that will work.
Thanks for the idea.
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
Old 02-14-2014, 04:00 AM   #6 (permalink)
I probably wouldn't do this on something larger because of the larger forces on bigger helis that could cause unwanted slippage.
Old 02-14-2014, 04:02 AM   #7 (permalink)
Funny you mention the horn coming with the gear set. I ordered a pair of gear sets and the picture on rcdepothobbies.com showed the horn. However, the package I got had no horns. I'm not sure what that's about.
Old 02-14-2014, 04:52 AM   #8 (permalink)
Great stuff I just stripped a servo on my first flight after adding in the metal swash, this mod should do the trick
Sent from my Nexus 10 using Tapatalk 4
NerpGuyLTD is offline        Reply With Quote Quick reply to this message
Old 02-14-2014, 06:04 AM   #9 (permalink)
I also received some servo gears with no screw or servo arms HSP15001T instead of these HSP15001 which shows a arm.
vronny is offline        Reply With Quote Quick reply to this message
Old 02-14-2014, 09:10 AM   #10 (permalink)
Hmmmm. Good to know. Thanks for the heads up.
Old 02-14-2014, 09:22 AM   #11 (permalink)
Does anyone have some digital calipers to measure the outer diameter of the round portion of the servo horns that fit over the servo splines? I'm trying to figure out which o-rings will fit snugly around them, but I don't have the heli yet. (should come today). If I get it sorted out I'll post back which size o-rings worked the best.
Old 02-14-2014, 09:51 AM   #12 (permalink)
DPW
PP Vernier Caliper set 80mm & 150mm $1.29
Measures down to 0.001 mm.
Just use plaster or a soft hot melt glue to get a profile of the location.
Align450L / 470/150 DFC/Blade stuff
DJI/AR Drone
DPW is offline        Reply With Quote Quick reply to this message
Old 02-14-2014, 10:21 AM   #13 (permalink)
OK I see how my question could have been misinterpreted that way. I know how to use calipers and I already own a set. What I don't have is the heli.
I was hoping someone with a set of calipers and the heli handy could measure the diameter of the horns. You wouldn't need to make a mold or anything, just clamp the calipers around the outside servo horn and get a rough reading...it doesn't have to be too exact. If not I will do it when the heli arrives, I was just hoping to swing by and pick up some o-rings beforehand. Thanks.
Old 02-14-2014, 10:39 AM   #14 (permalink)
We need a T-rex 150 dedicated section on HF. If we did, this should be stickied there, because it's saved me a TON of time and money.
What plugs are you using for your servos? Did they fall apart and you put on new connectors? The wires are different colors then the stock plugs.
Martin - DX8
180cfx-uBrain-HP20s | Trex150 DFC-HP08-BLHeli | Trex 250 DFC-306g-Belt-DS95i-iKon | Trex450 Sport V2 DFC-DS95i-iKon-Hyperion HS 2221 Kv 4400
mdecker79 is offline        Reply With Quote Quick reply to this message
Old 02-14-2014, 10:44 AM   #15 (permalink)
I've just measured the diameter of the servo horn collar on mine and it's appox 5.75mm
Nano CPX x 3, mCPX-BL x 3,130X, 180CFX, Lynx 450X-L, T-Rex 250 DFC, T-Rex 450L, T-Rex 500, KDS Chase 360, SAB G380, G500 Spt, BT650, BT700-T, BT700 Spt, XLP520
"More the Knowledge Lesser the Ego, Lesser the Knowledge More the Ego" Albert Einstein
Miracle Boy is offline        Reply With Quote Quick reply to this message
Old 02-14-2014, 11:03 AM   #16 (permalink)
Cool, thank you MB. So I didn't find any that small at Home Depot (at least not online). The smallest I found was 6.35mm (1/4 inch). So I'll probably swing by the LHS tonight and see what they have. Worst case I'll get some fuel tubing and try that.
Old 02-14-2014, 11:27 AM   #17 (permalink)
O.K. Cool, Let us know how you get on!!
Cheers!
Old 02-14-2014, 11:59 AM   #18 (permalink)
DPW
Talking 5.1mm OD
I was hoping someone with a set of calipers and the heli handy could measure the diameter of the horns. Thanks.
I got 5.1mm OD plastic is just not that dimensionaly stable. It maybe by design 5mm+ 0.5 mm?
Using plastic caliper 3 measures. Mic may give a better reading (don't have).
DJI/AR Drone
Old 02-14-2014, 12:08 PM   #19 (permalink)
Excellent. That's about what I was thinking. So we'll need to source some fairly pliable o-rings that have somewhere around 4mm inner diameter.
Old 02-14-2014, 12:57 PM   #20 (permalink)
NAPA 407004 have a 4.5mm ID.
Hydros27 is online now        Reply With Quote Quick reply to this message
