Servo saver mod - Page 4 - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > 150 Class Electric Helicopters
150 Class Electric Helicopters 150 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 02-26-2014, 06:47 AM   #61 (permalink)
Originally Posted by Go for it View Post
Well I finally received my Oringsandmore 70 durometer silicone orings today. As stated earlier, they are:
# 08 = 3/16'' or 1/32'' smaller then the horn foot
# 07 = 5/32'' or 1/16" smaller
# 06 = 1/8" or 3/32" smaller
At first sight,
#006 is very hard to slip on and will put so much tension that it may deny the very purpose of the mod. Maybe good for very hardcore 3D if the others slip too easy.
#007 seem to add the right amount of tension and feels to be the best.
#008 don't seem to add much tension. I have the intention of carving a small groove to keep them in place, so this one will probably be on the loose side.
If I can find the time, I'll try to do the mod this week. I'll give "Dipweed" stop hole a try while I'm at it and come back with more info after I have tested them.
P.S. To "jimmy77611" How can a 9/32 nitrite o ring fit if my #007 (5/32) fit just right. Is this the outside diameter?
You know what, they were 5/32, not 9/32. My Bad. I'll edit my post to reflect that. Good call!
Synergy 766 | XL Power Specter 700 | Synergy 516 | V Control Host of Full Pitch RC Heli Podcast My Youtube Channel
jimmy77611 is online now        Reply With Quote Quick reply to this message
Old 02-26-2014, 07:39 AM   #62 (permalink)
Good to know. If local auto parts has them it's easier then ordering from Oringsandmore.com.
T-Rex 150 || Blade 180 CFX with ÁBrain || T-rex 250 pro DFC with Vortex Vx1p || T-Rex 450 PRO DFC || Mcpx BL || Mcpx v2 || Futaba 14SG (KDH-Modul) || DX8
Go for it is offline        Reply With Quote Quick reply to this message
Old 02-26-2014, 10:21 AM   #63 (permalink)
Pic's please
At first sight,
Martin - DX8
180cfx-uBrain-HP20s | Trex150 DFC-HP08-BLHeli | Trex 250 DFC-306g-Belt-DS95i-iKon | Trex450 Sport V2 DFC-DS95i-iKon-Hyperion HS 2221 Kv 4400
mdecker79 is offline        Reply With Quote Quick reply to this message
Old 02-27-2014, 02:04 PM   #64 (permalink)
Originally Posted by mdecker79 View Post
Pic's please
I finally found the time to do the mod. Excuse the pics but I have not used my camera for a while and it doesn't work too well. Anyway the pics should be self explanatory.
As you can see, I made a little groove so the O ring will stay in place at the end where it's the most useful. With that groove, #007 seem to give the best tension. The outside diameter is pretty big though, so I had to file the center post of the frame to make room. I tried Dipweed idea of drilling a hole to stop the crack but didn't succeed too well. After ruining two horns, I gave up on that one.
With the mrs bound to the radio I can force the horn to slip with an audible click and the gears inside stay intact. So it seem to work.
Name:	2014-02-27 13.21.32.jpg
ID:	490848   Click image for larger version
Name:	2014-02-27 13.51.26.jpg
ID:	490849   Click image for larger version
Name:	2014-02-27 14.40.38.jpg
ID:	490850   Click image for larger version
Name:	2014-02-27 13.47.10.jpg
ID:	490851   Click image for larger version
Name:	2014-02-27 13.56.40.jpg
Name:	2014-02-27 14.33.06.jpg
Old 02-27-2014, 03:12 PM   #65 (permalink)
Very nice. It looks like it is time for Lynx to innovate a set of servo savers.
Hydros27 is online now        Reply With Quote Quick reply to this message
Old 02-27-2014, 03:43 PM   #66 (permalink)
@Go For It: I tried it last night too and I concur that the #7 red silicone o-rings are the best bet. I did like you and applied force under power to make them slip. I'd say the amount of force needed was about the same between the #7 o-rings and the blue 450X dampeners so at least we know they're roughly equivalent to a known good tension. I like what you did to give them some room to move against the frame. I noticed they could potentially rub there. So I think I'll tackle that tonight. Thanks for following up and for the detailed pics.
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
Old 02-28-2014, 12:42 AM   #67 (permalink)
Those of you that bought 100 packs, consider selling a dozen to me? Can paypal you a fair price and postage. If not, maybe I will look to see how my 001 collection is going and place a multi order.
Sent from my SM-N900T using Tapatalk
__________________________________________________ _
Align TREX 150, Align TREX 250, MCPx BL, Nano CP, Nano Qx, Blade 180qx
Member: AMA
Compusmurf is offline        Reply With Quote Quick reply to this message
Old 02-28-2014, 08:00 AM   #68 (permalink)
I also have a 100 pack coming to me on Saturday or so USPS tracking says so. I have no issue sending you some next week if someone doesn't already.
Martin - DX8
Old 02-28-2014, 01:24 PM   #69 (permalink)
Hello guys,
I would like to recomend you another material than O rings or silicon tubing.
O rings are necesary to change every 2 or 3 months because they wear out quite rapidly.
Here is my longterm solution (and in addition you can fine tune it's tension with pliers):
https://www.helifreak.com/showthread.php?p=4877088
I haven't T-Rex 150, but I think that piano wire f 0.4mm would be good for 3D flying.
HeHenri is offline        Reply With Quote Quick reply to this message
Old 02-28-2014, 01:26 PM   #70 (permalink)
Why would the orings wear out? They're just sitting on the servo horn giving a little squeeze.
Old 02-28-2014, 02:05 PM   #71 (permalink)
Because they are uder permanent tension and that's why their diameter is bigger and bigger.
The same is for silicon tubing and especialy for heat shrink tubing.
And the springiness of piano wire is much much better.
(excause my bad english)
Old 02-28-2014, 02:09 PM   #72 (permalink)
Originally Posted by HeHenri View Post
Hello guys,
I dig the ingenuity, but these things come 100 to a pack and they're more than tight enough. Even if they do stretch out it's not like you can't pop another one on in 2 minutes and keep on rolling. I highly doubt I'll run through 100 of them before the next greatest thing is released and this one becomes yet another micro heli paper weight.
PM sent
Old 03-02-2014, 01:26 PM   #73 (permalink)
Were you guys getting the O-rings from? I need to order some and try this mod, wonder if the can manufacture a servo arm that breaks?
Angelo
esmoglo is offline        Reply With Quote Quick reply to this message
Old 03-02-2014, 01:36 PM   #74 (permalink)
Here. this link, but you're going to get 100! of them. Maybe get some 001's for your swash balls too.
with 100, it'll last you a VERY long time.
http://www.oringsandmore.com/silicon...e-for-100-pcs/
Member: AMA
Old 03-02-2014, 01:49 PM   #75 (permalink)
You may be able to pick some up at an auto parts store. The small sizes are used in air conditioning.
Old 03-02-2014, 02:13 PM   #76 (permalink)
I got mine from the auto parts store. They have a big red box full of nitrile orings (most auto parts stores have this). You just pick the quantity of whatever size you want out of it and they charge you for those. The 5/32" ID (#007 in the box) are the perfect size.
I wouldn't want a servo arm that breaks...then you'd have to replace them every crash. With this mod, there's nothing to replace. Just reposition the arm and go.
Old 03-28-2014, 06:23 PM   #77 (permalink)
Here is my first servo saver horn mod:
The o-rings I had lying around are ID 4.5mm / OD 6mm and they are quite thin compared to others who have posted, so I've gone for two o-rings on the horn with a tiny tiny drop CA glue to secure them.
EDIT:
Just a quick update to say that this mod has probably already saved my servos or swash. Had two hard crashes today on its head and both time the elevator servo slipped as it should do
Blade 180CFX | 300X
MSH Mini-Protos 3S, Spirit FBL
Parkmaster 3D, Funjet, Sbach 3D, FrSky Taranis, FPV260 Quad, Pheonix Sim
stevebaker is offline        Reply With Quote Quick reply to this message
Old 04-11-2014, 01:17 PM   #78 (permalink)
These orthodontic elastics work great saved the gears in two crashes so far.
Inventor is offline        Reply With Quote Quick reply to this message
Old 04-13-2014, 12:42 AM   #79 (permalink)
Lynx is working for a ready to use safe gears arms.. testing going very well.
Sent from my GT-I9500 using Tapatalk
Luca Invernizzi
Lynx Heli Innovations
OXY HELI
ininverno is offline        Reply With Quote Quick reply to this message
Old 04-13-2014, 11:14 AM   #80 (permalink)
I knew it was only a matter of time . I'll buy them when they are ready
Thunder Tiger X50 TT FBL (OS 50 SX Hyper | Align 3GX Gyro\Gov | Align DS610 x 4 | Align DS650 x 1 | 2 Spektrum Sats)
Align Trex 450Pro V2 (HS5065MG x3 | DS520 x 1| Castle ICE 50 | MiniV 5.3 Pro)
Align Trex 150 DFC (Lynx Metal Swash | Spektrum Sat)
Taxus812 is offline        Reply With Quote Quick reply to this message
