Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 700X
Blade 700X Blade 700X Helicopters Information and Help
Old 05-14-2014, 02:18 AM   #41 (permalink)
Originally Posted by arefim View Post
It is the front set.My gain was fine .I had few hard stops as I was testing the tail. this was only my second flight and I'm afraid the the tail gears are made of cheap plastic.
I set up my TT heli's with fairly soft stops to help prolong gear life. All systems have this ability. If you are especially hard on the tail consider changing them proactively at regular intervals. Depending on the model I'll replace gears between 50-150 flights. Dry fluid lubricant can extend life as well.
Old 05-14-2014, 11:41 AM   #42 (permalink)
This happened to me also today and it was my second flight.my damage is very similar to yours + cracked both frames + main blades. I'm lucky that there was no injury to myself or other people.I have shimmed the tail gear and there was no play.It is very annoying to have stripped gear as the cause for the crash?I do feel that horizon should do some thing about it if it happens to other people.
Have you tried a shorter servo arm? I had the exact same strip on my second flight. After a shorter tail servo arm and a bit less gain, I haven't had a problem since. This heli has an unusually high amount of mechanical gain, and I know several others have had the same experience.. they strip out the first set of gears on the first or second flight, then make those adjustments and don't have any more problems. I'm working on reversing piroflips and I have not reduced my stop gains as OnTheSnap suggests, and even though I can hear the tail gears taking punishment, they don't strip.
aclysma is offline        Reply With Quote Quick reply to this message
Old 05-15-2014, 05:06 AM   #43 (permalink)
That's why i don't like tt. I shake the tail a lot when flying, 180 degrees reversals on tail slides and aileron loops, stall turns with piros stoping at each 90 degrees+litlle tail shake.
I just keep reading so many reports like this, i lose every bit of confidence i still had on tt.
Specially on these big birds issues like this are always expensive. The E700 also has similar issues.
I would always sacrifice a bit of auto hangtime (the only real benefit from tt) for a reliable belt that i can use and abuse at my will.
Manufacturers should get real, and see that tt and modern hard flying with the powerfull motors available is a huge task, and many simply fail at this.
How can tt compete with a belt meshing around half a pulley?
A tt gear mesh is very weak, to weak for today motors.
That plus a bit of higher gains or to heavy collective brings all kinds of problems.
XL Power 520(soon to become a 480), Warp 360 , Tarot 360Sport, Logo480 LowRpm , Logo 500
T500 AP
Luigi_tuga is offline        Reply With Quote Quick reply to this message
Old 05-15-2014, 08:46 AM   #44 (permalink)
That's a pretty bleak view of TT. It is possible to make a robust over designed TT system. Logo 700 and Synergy E7 both have extremely robust TT implementations. And after years of evolution, the Align 700e gears hold up amazingly well. But it wasn't that way for some years until the black gears came out.
My guess is the math dictates most of the gear designs, but the reality is they probably need to double the safety factor to account for variations in plastic and mesh.
Old 05-15-2014, 01:50 PM   #45 (permalink)
That's my opinion reading hf. So many posts about tt failures, in several brands.
On the other hand, catastrophic tail failures are not that common, and by a huge difference.
T500 AP
Old 05-15-2014, 07:23 PM   #46 (permalink)
Ah well forums are not good statistical sources of information. It's where people come to complain, (-:
Old 05-17-2014, 10:25 AM   #47 (permalink)
Sure!
And i see way more complaints with TT gears breaking then Belts snapping.
Of course everything heli related is very dependant on setup, that's why some fliers have absolutely no issues with stuff that is a nightmare to others.
T500 AP
Old 05-18-2014, 06:30 PM   #48 (permalink)
Ill comment here then leave it alone.
Any Tareq Alsaadi style flights on youtube with a blade 700x ? I cant find one !
Kap'n Krunch is offline        Reply With Quote Quick reply to this message
Old 05-25-2014, 01:10 AM   #49 (permalink)
the 700x is blades first 700, i think they did a real good job. Is it perfect? No. The main deciding factor of the success is will they take the time to strive towards perfection. I give align alot of crap just cause align guys freak out when you talk about there helis, but align looks at what is going on with there helis and fixes them, now i dont think they should be sold as "upgrades" and should be just updated parts but atleast they are constantly evolving the heli. It would be nice if blade could tell us if they are working on new gears or a new tail block or tail box for tigher fit, align takes about 3 months after a new heli releaes to have there upgrades, and they keep comoing, so blade I hope your working on fixing this issue cause id hate to have to sell this heli off becaue of gear issues like i did my raptor e700. After 2-3 tail gear strips in flight you really loose all confidence in the model and then because you have wasted 1000+ dollars from an inferior design you dont give a damn even if they fix it, you just want to wash your hand cleans, that said ive had 0 issues, and ive been fairly hard on my tail, over speeding the heli, getting some gyro bounching, hard stops, so i am happy so far but it does bother me i am seeing more and more gear issues as these helis get older. Also as far a your comment justwired ,this guy flys pretty damn hard,
Blade 700x little Boomstrike with Spinblades (3 min 36 sec)
TEAM IKON
TEAM KDE DIRECT
HeliDoc25 is offline        Reply With Quote Quick reply to this message
Old 06-01-2014, 03:16 PM   #50 (permalink)
Default TT gears stripped
Mine done the same thing after 5 flights. I sent boom to Horizon and they are sending me a new kit. Said needed to shim tail shaft.
Smorehead is offline        Reply With Quote Quick reply to this message
Old 06-14-2014, 02:50 PM   #51 (permalink)
my flyingstyle with the 700X is rather abusive and i have never stripped gears on mine.
I just messed up an autorotation where the tail hit the dirt and bent the tailfin into the tailblades. Broke tailfin and tailblades and my gears are still good.
Its a tough heli if you ask me
btw the video above is a friend of mine he has never stripped TT gears either and hes not babying it at all
and this guy put a Align 850MX dominator motor in it and tried to stripp the gears he couldnt stripp them:
BLADE 700X Geartest Bodykalle (3 min 16 sec)
Horizon Hobby / Blade / Spektrum / Lynx / Dryfluid
https://www.youtube.com/stefanfinster92
think positive, fly negative
4DPILOT is offline        Reply With Quote Quick reply to this message
Old 06-16-2014, 07:43 PM   #52 (permalink)
BLADE 700X Geartest Bodykalle - YouTube
This guy would be fun to fly with. I feel bad for his batteries..
mickeyjohnston is offline        Reply With Quote Quick reply to this message
Old 07-20-2014, 10:31 PM   #53 (permalink)
The gears got me. Stripped out the front umbrellas today...pyro reversals. Autoed in and broke the landing gear is all. Gotta have 200 flts easy on her. Ware and tare is what im telling myself.
GOBBY 700, GOBBY 570, TREX 450L, DX18 eh!
Last edited by 2easy; 07-20-2014 at 10:33 PM.. Reason: /////////////////////////////////////
2easy is offline        Reply With Quote Quick reply to this message
Old 07-21-2014, 07:34 PM   #54 (permalink)
I will have one of these very soon. Is it a possibility that both front and rear tt gears could need shimmed? I though Edsel's build videos just showed the rear getting shimmed?
-Proto x, nQX, nano cp s, mCPX BL, 130x, 180cfx, 230s, 200qx, Trex 450 DFC, 450L 6s, 450 Quad, 700x, DX9
-5 year IRCHA vet
-Give a man a helicopter and he flies for a day. Teach a man to fly helicopters and he flies for a lifetime!
BadVad is offline        Reply With Quote Quick reply to this message
Old 07-21-2014, 07:58 PM   #55 (permalink)
Order yourself a variety of different size shims. Then shim the gears to get proper alignment and to have the gears just tight enough so that you can feel the high spot on the gear start to drag a little when spinning the gears by hand. Then keep them lubed. Also adjust your tail stop so that it will still stop fast but not so fast that it sounds like it is going to tear itself apart. I was able to rip a tail belt out of my N5 with the default setting on the iKON.
This is what I did on my 700X and it is holding up just fine after many flights.
Synergy N5
Compass 6HV
Blade 700X
iKON DX9
Greg B is offline        Reply With Quote Quick reply to this message
Old 07-21-2014, 11:09 PM   #56 (permalink)
My rear is shimmed but not the fronts. Im going to shim both on the rebuild. Greg, I have lubed the rear but not the front..no logic to it I know, but going to do both from now on. The gear wo the lube went, so lubing does work to reduce friction. My tail stops aren't hard enough to fart, but still ridged, I guess too rigid. Will soften some more. Thanks Gents
Old 09-13-2014, 10:53 PM   #57 (permalink)
stripped another set of tail gears today. i got the shims so here we go with the rebuild.
jmrcracer is offline        Reply With Quote Quick reply to this message
Old 10-29-2014, 11:09 AM   #58 (permalink)
Same thing happened to me after five flights. Horizon sent me new kit butt afraid to do anything with until know for sure what happened.
Old 10-29-2014, 03:05 PM   #59 (permalink)
I've helped a lot of people with the gears, and almost invariably either:
1) there is slop somewhere in the gears... Check play for all gears in the tail box in all 3 axes. If there is play, describe where it is and I can help you fix it
2) the user is using something other than beastx - in this case the tail stop gains or tail dynamic or whatever that unit calls it needs to be reduced.
Oh also if you EVER see the SLIGHTEST overgain/wag of death due to too high tail gain, replace the gears. If you recently built the Heli this is likely. I expect to have to replace a set of gears or two due to this any time I set up a new torque tube model.
This advice is applicable to any torque tube Heli.
Old 10-31-2014, 03:04 PM   #60 (permalink)
If the heli is designed right, you don't have to manually check tail gear mesh and try to make it perfect.
Just sayin -
