Old 09-22-2012, 06:36 PM   #1 (permalink)
Registered User
Default Ron Lund's BeastX V3 Setup Videos
Check out Ron's BeastX setup video channel on Youtube!! Thanks for sharing Ron!!!
http://www.youtube.com/playlist?list=PL5D2B4E24B5FF891A
William James
Old 07-18-2013, 10:33 AM   #2 (permalink)
Default Microbeast V3 - Setup Videos
All videos are available in HD
Microbeast V3 - 12Z Transmitter Setup
[ame]http://youtu.be/YgGQqBqcxx4[/ame]
Microbeast V3 - 8FG Transmitter Setup
[ame]http://youtu.be/3UKCYBFPRzk[/ame]
Microbeast V3 - DX6i Setup
[ame]http://youtu.be/F96WAF1tOhA[/ame]
Microbeast V3 Step One Setting Receiver Type to Sbus or Spektrum
[ame]http://youtu.be/njPFjbx17yE[/ame]
Microbeast V3 Spektrum Satellite Binding and Fail Safe
[ame]http://youtu.be/bkRwlOYWl44[/ame]
Microbeast V3 - Steps A - D. Complete BEFORE Connecting the Servos
[ame]http://youtu.be/qjtMFUmBVuk[/ame]
Microbeast V3- Standard Spektrum or JR Receiver Connection
[ame]http://youtu.be/u-jJYdnaYGA[/ame]
Microbeast V3 - Futaba Standard Receiver Connections
[ame]http://youtu.be/GG37sAiGJc4[/ame]
Microbeast V3 - Steps E and F
[ame]http://youtu.be/p7k5RV0Rbmc[/ame]
Microbeast V3 Step G. Setting the Servos to Center and Leveling the Swashplate
[ame]http://youtu.be/A6WITRPRFJ4[/ame]
Microbeast V3 Steps H and I
[ame]http://youtu.be/Rz0PdbChI58[/ame]
Microbeast V3 Step J - Teaching the Microbeast Your Cyclic Geometry
[ame]http://youtu.be/Voa6QRyoH5A[/ame]
Microbeast V3 Step K - Setting the Pitch Range
[ame]http://youtu.be/gLGez1gYY-M[/ame]
Microbeast V3 Step L - Setting the Swashplate Limits
[ame]http://youtu.be/B9Or0bk_j6M[/ame]
Microbeast V3 Steps M and N
[ame]http://youtu.be/mQb1HpMYfpQ[/ame]
Microbeast V3 - Before you Fly
[ame]http://youtu.be/ypG1FZ7C9uU[/ame]
Microbeast V3 - Parameter A
[ame]http://youtu.be/JHWZcwJ-TxA[/ame]
More to come
www.ronlund.com
800-321-9909
ronlund is offline        Reply With Quote Quick reply to this message
Old 10-20-2013, 10:51 AM   #3 (permalink)
very easy to understand video thank you so much
notsobad is offline        Reply With Quote Quick reply to this message
Old 03-03-2014, 12:26 PM   #4 (permalink)
Step E on my microbeast is not working correctly. I move my rudder stick to one side, wait for the light to blink which indicates that side (lift or right) is done. However, when I move the rudder to the opposite side and wait for the light to blink, it doesn't.
airborne2.4 is offline        Reply With Quote Quick reply to this message
Old 03-03-2014, 01:47 PM   #5 (permalink)
See the other thread that you posted in for a likely answer.
Regards, Sutty
BeltEXI, mCX, mSR, 4G3, FBL Trex250SE ÁB, FBL Trex450Pro ÁB,
sutty is offline        Reply With Quote Quick reply to this message
Old 03-16-2014, 07:14 AM   #6 (permalink)
Im converting my old 450 pro to FBL with an Align's DFC head + BeastX. Do I need to level the swash before installing the dfc head or doing it later with the BeastX?....please guide..thanks
All begins (Jun 2011).......
Next project:
MSH Mini Protos, 450 Scale Airwolf, BAH Mini Quad
cpmboy is offline        Reply With Quote Quick reply to this message
Old 08-04-2014, 06:42 AM   #7 (permalink)
You level the swash during the beastx setup.
Whiplash Gasser l Goblin Gasser
in2deep is offline        Reply With Quote Quick reply to this message
Old 08-04-2014, 07:31 AM   #8 (permalink)
Flew mine a couples of months ago ....very happy with it.....now my 450 dfc bx pro is going scalin.....
Next project:
Old 11-28-2014, 09:19 PM   #9 (permalink)
Wow! The step G vid was pretty amazing with the Lazer. One thing I love about the BeastX, when you make an adjustment you can see it working in very fine, precise increments. Without a lazer, I use a perfectly square stiff paper card, eyeballing parallel with the main shaft to the bottom of an Align Pitch gauge to get pitch nailed down, same for levelling the swash.
One of the first things I really liked about BeastX when I setup my Trex 550 was the max pitch +/- setup. You just move the stick until the pitch gauge reads the desired degrees with no bumping points around.
I also like the servo sub trim. That's such a time saver if you already have servos mounted and they are off a bit after switching FBL brands. And so simple by moving the stick, BeastX remembers where you put it without bumping points around.
Also I like the way the rudder limit works automatically remembering where you set it within a second. Again no bumping up end points and checking over and over until you get it nailed. Love it!
If its fixed don't break it!
