Go Back   HeliFreak > Multi Rotor Support > Blade Multirotor Support > 350QX
350QX Blade 350QX Multirotor Information and Help
Old 01-09-2014, 08:32 PM   #21 (permalink)
Default Noob's guide to fpv
Noobs guide to Fatshark Predator FPV Goggles 5.8ghz (4 min 19 sec)
DEMO7 is offline        Reply With Quote Quick reply to this message
Old 01-11-2014, 09:18 AM   #22 (permalink)
Default 350 QX arming issue
I have had the 350 qx for a few weeks and until last night haven't been able to get it to arm (start the props). I redid the settings in my DX8 a few times and read lots of comments about the throttle trim.
What I should have done was call HH and I'm sure they would have helped me. I do prefer to learn the hard way and this had much to do with the aforementioned reluctance to call for help!!
What fixed my arming issue was the rudder travel. I adjusted the rudder travel % from 100 to 120% and now
I have since gone back and tried to adjust it down but it consistently arms at the 120%
SUBDOC743 is offline        Reply With Quote Quick reply to this message
Old 01-15-2014, 01:55 AM   #23 (permalink)
Default Fatshark Mod for custo diopters
http://www.youtube.com/watch?v=m8OLg-4tTGA
Old 01-18-2014, 04:15 PM   #24 (permalink)
Default Go Pro or No Pro Return to Home Test
Originally Posted by Gixman View Post
This test shows the 350 QX with and without the GoPro attached.
350 QX: Return to Home accuracy test - YouTube
Hi, I enjoyed your test video, but, I'm wondering how many times you ran the test with the GoPro attached? Seems that you did one test with the camera attached and found the accuracy to be unacceptably far away, approximate 20 feet or so. The next two or three tests, without the camera, the Return to Home landing was within 2 feet or so. I just wonder if carrying the camera actually had anything to do with Return to Home accuracy or not or if you just got lucky without the camera attached. My understanding of non-military GPS units is that 20 feet accuracy is really good. I would expect that if this Quad landed anywhere from 2 to 20 feet away, even 30, from the home position, it did really well. I'm guessing that the results would typically be random and you may have two or three landings, in a row, that were very close to the home position, and then one or two or several that are 20 or even 30 feet away. Anyway, I'd be interested in knowing more about your testing methods and what your thoughts are on GPS accuracy. I leave near a lot of trees, when I get a 350QX it would be nice to know if the Return to Home feature will bring in down in my fairly small clearing. I did enjoy your video, very through and well done, thanks for sharing.
My Fleet: MCX, MCX2, MCXT, MSR, CX3, SR, MQX, NanoQX, 200SRX.
Gadget1500 is offline        Reply With Quote Quick reply to this message
Old 01-19-2014, 01:18 PM   #25 (permalink)
If you ever have to disconnect motors and or escs and have problems. Try the motor reassignment. You tube blade 350qx motor assignment procedure. Very easy.
Bduncan is offline        Reply With Quote Quick reply to this message
Old 01-28-2014, 10:16 AM   #26 (permalink)
Here's one;
350QX battery hatch restraint
Simple & easy.
Dubro ball link ends, (need 2);
http://shop.dubro.com/p/1-16-threade...ty-pkg-1?pp=12
a1pcfixer is offline        Reply With Quote Quick reply to this message
Old 01-28-2014, 10:58 PM   #27 (permalink)
Gee... that photo looks awful familiar... I think that's MY 350QX!
Blade 130X- My cul-del-sac flyer.
Blade 450X w/MSH Brain - My Ferrari
T-Rex 600 EFL Pro w/SK-720 BE, KDE600XF & SK-GPS - My BMW
T-Rex 700 HV DFC w/VBar, Kosmik 200 & KDE700XF - My muscle heli
HFMan is offline        Reply With Quote Quick reply to this message
Old 01-29-2014, 09:07 AM   #28 (permalink)
So THAT's where it came from!.....lol
Old 02-23-2014, 04:12 PM   #29 (permalink)
Default ebay gimbal tilt
Cheap eBay Manuel Gimbal Tilt (1 min 25 sec)
Old 02-23-2014, 04:23 PM   #30 (permalink)
Improving 'park flyer' limited RC range by extending aerial outside the body - doubles the range test distance, so hopefully will have similar improvement on full range.
Blade 350QX short RC range fix - external extended RC aerial - doubled range test distance (5 min 12 sec)
jamesb72 is offline        Reply With Quote Quick reply to this message
Old 02-25-2014, 11:00 AM   #31 (permalink)
[QUOTE=jamesb72;5667398]Improving 'park flyer' limited RC range by extending aerial outside the body - doubles the range test distance, so hopefully will have similar improvement on full range.
Excellent James!
Retired Fire Captain flying RC heli's since 1982, AMA member
"Don't let your rotors touch anything but the air".
firedude52 is offline        Reply With Quote Quick reply to this message
Old 04-11-2014, 03:40 PM   #32 (permalink)
Default Editing tips
Some neat tricks in this vid
FPV Dji F450 Editing, Crazy Proximity Tricks and a great flying day! (4 min 37 sec)
Old 04-14-2014, 01:14 AM   #33 (permalink)
Default For noisy ebay brushless gimbals
Silence Your Noisy Chinese eBay brushless Gimbal (3 min 26 sec)
Old 04-19-2014, 12:05 PM   #34 (permalink)
Default Tree maintenance
How to get your stuck quadcopter out of a tree - Blade 350QX (3 min 39 sec)
Old 04-28-2014, 10:32 PM   #35 (permalink)
Default ebay cheap 3 axis gimbal
Cheap eBay 3 Axis Brushless Gimbal (4 min 9 sec)
Old 05-16-2014, 05:11 PM   #36 (permalink)
Default Props, props, and more PROPS!
[ame]http://youtu.be/ulAaIbVMDrU[/ame]
Old 06-12-2014, 05:27 PM   #37 (permalink)
This is a simple one.
When taking the body shell off 1st put a rubber band around each arm. This will secure the two half's as you remove the 34 1.5mm screws. I found myself turning the QX over as I dealt with each screw on the bottom shell and if not careful components will try to escape from the inside.
4_Props is offline        Reply With Quote Quick reply to this message
Old 06-15-2014, 09:24 PM   #38 (permalink)
Does any one have a picture where they've drilled a hole presumably in the bottom of the motor pod to make it possible to apply some dry lube to the bottom bearing on these stock motors? I've installed my cnc prop adapters and it looks like we'll have to take them off to lube up the top bearings. Sure wish smallpartscnc would have put a small slot in the bottom of the adapters to be able to get some lube to the top bearing without having to take them off.
Tom T is offline        Reply With Quote Quick reply to this message
Old 12-30-2014, 09:46 AM   #39 (permalink)
Does the don't use locktite apply to the extreme cf props? I used tamiya locking gel on mine.
rubhamusan is offline        Reply With Quote Quick reply to this message
