Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 380/420
SAB Goblin 380/420 SAB Heli Division 380/420 - Goblin Helicopters Factory Support
Old 01-07-2015, 01:26 PM   #21 (permalink)
Originally Posted by Luigi_tuga View Post
This issue happens specially with high KV, around 1800 kv.
On 1300 kv there are less issues, even less around 900.
Less KV demand less processing/switching speed from the ESC
Hello.
Exactually corect answer.
1.
YGE ESC was working very well also.
YGE: 18 for timing or higer ,PWM Start with 8 (also auto-timing works good on YGE with Xnovamotors)
thank you.
xnovamotors_support
xnovamotors-support is offline        Reply With Quote Quick reply to this message
Old 01-07-2015, 07:07 PM   #22 (permalink)
I had nothing but good things to say about the motor or quality of it,the problem is these things should be tested before sending to the consumer,in my opinion anyway,had I known there would be issues I probably wouldn't have bought it.I was actually going to put the tareq motor in my 380,but was hesitant because I could never get the 1860 to work.
T.O.R.C.H.S member
ken234 is offline        Reply With Quote Quick reply to this message
Old 01-07-2015, 07:22 PM   #23 (permalink)
now im hesitant about this Xnova 2820-890KV moter this is the one i purchased i never had a yge 90 lv esc i have never used one before i bought the program card but i never had to play with timing before on a esc
BLAZE86DUBZ is offline        Reply With Quote Quick reply to this message
Old 01-07-2015, 09:45 PM   #24 (permalink)
No reason to be hesitant, that will be an awesome combo believe me.
The YGE defaults for timing and PWM are 18° and either 8 or 10 PWM, perfect.
SAB Heli Division Rotorquest
snemi00 is offline        Reply With Quote Quick reply to this message
Old 01-08-2015, 10:10 AM   #25 (permalink)
what governor you plan to use?
sturebergdahl is offline        Reply With Quote Quick reply to this message
Old 01-08-2015, 10:18 AM   #26 (permalink)
im not sure yet i have the spartin vortex fbl unit was going to try that
Old 01-08-2015, 10:57 AM   #27 (permalink)
Mayby this programing video will help you. http://vstabi.info/en/node/1476
Old 01-08-2015, 01:34 PM   #28 (permalink)
It's not a vbar
Old 01-08-2015, 02:11 PM   #29 (permalink)
are you thinking of trying the vortex gov with the YGE , see this
Spartan Vortex - eGov basic setup (in HD) w/ guide for YGE low voltage ESC (18 min 30 sec)
| Kraken 700 : Neo | Atom 6HV : Evo | Raw 580 : Neo | vbct |
Old 01-08-2015, 04:01 PM   #30 (permalink)
i wasent worried about the gov setup i was worried about the timing i never had to use a esc and moter combo and i had to set the timing
Old 01-08-2015, 04:19 PM   #31 (permalink)
timming on outrunner motor for YGE = 18
PWM 8-12 I think , gonna have mine at 10 and check the esc temp after flight
Old 01-08-2015, 06:10 PM   #32 (permalink)
so they dont have auto timing on yge?? u have to set it urself?
Old 01-08-2015, 06:15 PM   #33 (permalink)
You need to use the program card,I think auto timing is on the first page at the very bottom all the way to the right
T.O.R.C.H.S member
Old 01-08-2015, 06:19 PM   #34 (permalink)
well whats better ?? auto or reg timing for Xnova 2820-890KV 10P ?
Old 01-08-2015, 07:09 PM   #35 (permalink)
There is no auto for timing, only for startup power.
Try 18degrees for timing. Typical for all outrunners as previously mentioned.
Current favorites...
Oxy 3, Goblin 380, Logo 480Xx, Goblin 500, TBS Gemini, 250 FPV Quad Racers, bunch o' Planks, etc..
Inverted2112 is offline        Reply With Quote Quick reply to this message
Old 01-08-2015, 07:32 PM   #36 (permalink)
Actually on the program card for the YGE, there's a special section and AUTO Timing is there. When enabled, the static timing selection is cleared.
I don't care what you fly, just FLY!
para5063 is offline        Reply With Quote Quick reply to this message
Old 01-08-2015, 07:56 PM   #37 (permalink)
Yes and actually if you go on xnova website they recommend auto timing
T.O.R.C.H.S member
Old 01-08-2015, 08:00 PM   #38 (permalink)
orXnova XTS motors are not picky about ESC settings. Most default settings are just fine, but there are some things to consider. Please find setup examples below
Castle Creation ESC :
16Khz and 8 for timing.
Kontronik ESC :
Reset ESC by Mode 1, then use Autotiming Mode 4.
KOSMIK expert-setup sample for XTS-4530-480KV Motor: Mode 1 , then Mode 4. Go to advanced settings and select RI compensation= 12 ( this is the RM number of the XTS-4530-480kv motor which can be found for all our motors under technically details). P gain increase from 4 to 5.
(this is a advanced setup sample. the basic setup Mode 1 then Mode 4 will satisfied most pilots)
YGE ESC:
Autotiming and start with 8 PWM.
Scorpion ESC :
Current protection=normal/ (commander 160) insensitive/ (commander 130) /Motor-timing 5* . Gov. tuning 6-for P-gain and 7-for I-gain.
Hobbywing ESC :
Setup example: Platinum-50A-V3 with XTS 2618 series.
- Timing 8°
- PWM: 8Khz or 16Khz (Batteries are less warm with 8khz)
Heli specific setup:
T.O.R.C.H.S member
Old 01-08-2015, 09:07 PM   #39 (permalink)
My bad, its under special functions....
Can't say how many times I've used the darned thing and I had never noticed that....
Old 01-14-2015, 08:26 AM   #40 (permalink)
@ Helidirect, Delayed again! ETA now 1/21!
Fusion 180 - M2 Evo - RAW 420 - Fusion 550 - Tron 5.5 - Kraken 580 - Kraken 580n - Kraken 700 - Kraken 700n - Vcontrol Evo
vertico is offline        Reply With Quote Quick reply to this message
