Go Back   HeliFreak > Multi Rotor Support > Open Source Flight Controllers (CC3D, Ardupilot, etc.)
Open Source Flight Controllers (CC3D, Ardupilot, etc.) Open Source Flight Controllers (CC3D, Ardupilot, etc.)
Old 05-09-2015, 07:33 AM   #1 (permalink)
Default How to connect a Orange R615x to Naze 32
Hi guys, so here is my problem. I have been running Spectrum 6110e Rx on one of my quads. I now want to change it to a Orange r615X, so that i can later on just use cppm one cable. For now it is still wired as normal. I bind it to the Tx, but get no arming or movement from the receiver tab in Baseflight. Tried it with 4 Orange Rx's. Is there something i need to set in Baseflight to get it connected. If i put back the Spectrum Rx, everything works again. On this quad i am using a DX6i, but will later put it over to my DX 9. Thanks in advance.
Clinton1 is online now        Reply With Quote Quick reply to this message
Old 05-09-2015, 09:00 AM   #2 (permalink)
Is there a checkbox in the setup shop for that move in baseflight? I know there it's one in multiwii. I just tried it on mine and my sub trims were off on all the channels, and didn't seem to center up especially on yaw. One click either way on sub trim would be 4-5 numbers.
dparadowski is offline        Reply With Quote Quick reply to this message
Old 05-11-2015, 01:05 AM   #3 (permalink)
Hi, i dont think so, hence i am asking the question. I looked everywhere but cant seem to find the answer.
Sent from my GT-I9500
Old 05-11-2015, 10:15 AM   #4 (permalink)
When Im running my 615x I run the CPPM wire from the data/bind port to the 123 Naze Ports. Then under the setup tab on Cleanflight/Baseflight I click the PPM input box. From there its to the receiver tab to ensure that everything is working correctly and on goes the tuning.
Im not sure why you would wire up a 615x with all the wires like a spektrum as it is seriously easy just to wire it with CPPM. Plus less wires involved and tuning is cake.
Cpl Woody is offline        Reply With Quote Quick reply to this message
Old 05-11-2015, 11:17 AM   #5 (permalink)
Thank you for the reply - still no go, i plug in the cppm wire as described, then power up, Rx flashes for binding. I then bind my Tx and power down. When i power up, it goes into bind mode again, any reason why ?
Old 05-11-2015, 11:36 AM   #6 (permalink)
If its going back into bind mode it would be because the signal and ground pins are connected. So somewhere in your system you must have a short
Old 05-11-2015, 12:26 PM   #7 (permalink)
Thanks Cpl Woody, i am a idiot. I thought the pin layout was the same as Spectrum, so my signal and negative was the wrong way around. I turned everything, and you know what, it works brilliantly. Thanks for steering me in the right direction.
Old 05-11-2015, 01:04 PM   #8 (permalink)
You got it. That is usually what always happens to me. Some little plug or setting.
Old 07-26-2015, 01:02 AM   #9 (permalink)
Old thread but newbie with a question.
What type of model are you setting up in your transmitter for these quads?
I keep getting jumbled channel output orders on my dx9 using the 615x Rx and acro naze 32.
Goblin 380 / 500 / 700C / 700KSE / ZMR250/ QAV180/ VAS Banshee/ VAS Wraith Micro/ MSH Brain FBLs/ HW ESCs/ XNOVA Motors/ Jeti DS-14
UCPharmD is offline        Reply With Quote Quick reply to this message
Old 07-26-2015, 03:33 AM   #10 (permalink)
I just used the airplane model in the dx9, i have since moved over to the Taranis.
Old 07-26-2015, 10:22 AM   #11 (permalink)
Tried it this morning. Still no luck. Any links to how to change/reassign the channels so that they match up?
I have already switched the reciever setting to spektrum/jr. Not sure what else I need to do. I'm clicked the ppm box in the configure tab too.
Any ideas?
Old 07-26-2015, 10:36 AM   #12 (permalink)
HF MR Support
Default Settings
Any ideas?
Are you using PWM or CPPM?
Gaui 550(Need GOT ONE!) / KK2.1.5 steveis pro/ZMR250 / Alien 450 camera ship / HJ 450 all W/KK2.1.5 Steveis pro Estes Nano/ Hubsan X4 / Syma X1
AMA 953414 CONTRIBUTOR, TEAM LAVAQUAD
PTcaflyer is offline        Reply With Quote Quick reply to this message
Old 07-26-2015, 10:43 AM   #13 (permalink)
Cppm
Old 07-26-2015, 10:54 AM   #14 (permalink)
HF MR Support
Default CPPM
Did you see this?
OrangeRx R615X CPPM (3 min 41 sec)
There are other videos showing the NAZE as well
Old 07-26-2015, 11:06 AM   #15 (permalink)
That video is exactly what I need. Just need it for the naze board.
Old 07-26-2015, 11:13 AM   #16 (permalink)
HF MR Support
Here it is...
(2/8) Naze32 Flight Controller - Extra setup steps and configuration (18 min 36 sec)
Enjoy!
Old 07-26-2015, 11:40 AM   #17 (permalink)
Perfect!
Thanks a ton! I love this forum.
Old 07-26-2015, 11:53 AM   #18 (permalink)
HF MR Support
You're Welcome!
"Keep 'em Flying"
Old 07-27-2015, 01:09 AM   #19 (permalink)
Well, I test flew it today. Just a hover and it worked. Problem is now that I had to power the orange rx with a receiver pack. Is this normal?
Is this not getting power from the Naze board at all?
Old 07-27-2015, 01:34 AM   #20 (permalink)
Nevermind, im retarded. After plugging in the bec to the receiver , it works fine.
