Go Back   HeliFreak > R/C Electronics Support > EZNOV
EZNOV EZNOV Support Forum
Old 08-16-2015, 05:02 AM   #1 (permalink)
Unhappy Blade\Lynx 300X with Neuron (Tail issues)
Hello!
Helicopter: Blade 300X (lynx frame, lynx motor 4100kv, cc talon 35A, tail servo align DS426M). Neuron is installed from the bottom.
I have a proplems with tail waging. This problem occurs when you quick release the rudder stick, or when you flip.
Neuron config:
- Heli Size 450
- PID defaults
- Tail sevo Gyro Gain: from 20 to 50
On this helicopter were installed: vbar, beastX, ikon, gpro. There were no problems.
p.s. sorry for my English
lvsw is offline        Reply With Quote Quick reply to this message
Old 10-28-2015, 11:10 AM   #2 (permalink)
I just finished up setting up my Trex 250 with my neuron and I'm having the exact same issue with the tail.
Did you ever figure out a solution?
yakky is online now        Reply With Quote Quick reply to this message
Old 10-30-2015, 05:30 AM   #3 (permalink)
Thumbs down
The solution is not found. On "Blade 300X" and Blade 300CFX Stretch" this FBL is not working. The tail went crazy. Support EZNOV does not respond to emails (from official site).
Old 10-30-2015, 05:41 AM   #4 (permalink)
are you sure the tailgain is actually updated in the unit?
Have you tried adjusting the D-gain, when you say it oscillates after releasing the stick that could indicate you need to tune the D-gain.
Have you tried lower gains then 20%? is that 20% in TX or in Neuron?
GAUI X5 with Eznov Neuron and T10J
DannyvG is offline        Reply With Quote Quick reply to this message
Old 10-30-2015, 05:49 AM   #5 (permalink)
I've tried lowering the D-Gain and I-Gain. (from 5% to 70%)
In Neuron
Old 10-30-2015, 06:12 AM   #6 (permalink)
arent negative values also possible in the neuron? havent tried it but the GUI seemed to suggest it is possible.
Old 10-30-2015, 06:14 AM   #7 (permalink)
As I remember, it's possible. Will check in the evening.
Old 11-04-2015, 03:20 AM   #8 (permalink)
Hello,
When did you send the mail ? The queue is empty so either it has received an answer or we didn't receive it.
We use Neurons even on 180CFX, 130X, etc., so 300X should not be a problem.
Please make sure your tail servo neutral is ok (not too far from 1520/760Ás).
You can also try lowering the tail precomps (cyclic and pitch), and start with lower I and D (20% for example).
Thomas.
Otatiaro is offline        Reply With Quote Quick reply to this message
Old 11-04-2015, 03:36 AM   #9 (permalink)
Thumbs up
Originally Posted by Otatiaro View Post
Hello,
Hello!
The letter was sent 08-16-2015 through the "Contact us" form on the website neuron.eznov.com
1) Could you post the config for the Blade 300X?
2) And what is the value of Tail Gyro Gain are you using?
Tail Servo: Align DS426M
Neutral point: 1520Ás (This is the value I set in the config.)
Thanks for the advice!
Old 11-04-2015, 09:03 AM   #10 (permalink)
I seem to be getting closer. What has me sort of perplexed is the neuron seems to have a narrow band of p gain. My 250 wags terribly below 25% gain and above 35%. On other fbls dropping the gain usually means a dull tail, not whipping back and forth.
I have some slop in the tail, but its in the average range for a 250 which is plagued with slop. Is there a way to account for that slop in tuning?
Old 11-04-2015, 09:13 AM   #11 (permalink)
I have the Neuron on a Trex 250 and was getting terrible wag at first but now its pretty locked in.
Start with 20 on P gain
Turn D gain to 0
Turn I gain to 0
Turn off cyclic precomp
Turn off Pitch precomp
Use a throttle curve and not the governor until you have tail sorted.
Hover the heli and do pitch pumps. With I and D at zero you will find the tail will drift on take off. Adjust tail linkage until drift is minimized.
Increase I gain to 3% and then start increasing P gain in order to get the tail locked in. Increase it until you get a high frequency vibe then decrease just enough to eliminate it.
Once P gain is set adjust I gain slowly until all drift is eliminated or until you get a low frequency wag then reduce enough to get rid of it.
To set D check how the tail stops. If you notice overshoot increase D until the tail stops solid without any overshoot.
Now add back in just enough pitch precomp to keep the tail from kicking on hard pitch pumps.
Add just enough Cyclic precomp to prevent tail kicks on hard cyclic.
The tail will now be close and flyable. Fly the heli and fine tune the gains.
This is all assuming your tail is mechanically sound.
Nick_P is offline        Reply With Quote Quick reply to this message
Old 11-04-2015, 09:14 AM   #12 (permalink)
Yes, use a MKS 95i tail servo. Also do the double bearing mod if you have not already.
Old 11-04-2015, 09:21 AM   #13 (permalink)
Great stuff, thanks Nick. Not sure I'm ready to swap servos but I'll try the rest.
Old 03-15-2016, 01:18 PM   #14 (permalink)
Hello
i have start with this today with my Oxy 3
Turn D gain to 0
Turn I gain to 0
but still have tail bounce please can someone send me his setup for the tail for a 300class heli ? i don't now what to do anymore
best regards Joeri
YGE, www.yge.de
Xnova motors, www.xnovamotors.biz
SLS, www.stefansliposhop.de
Joeribar is offline        Reply With Quote Quick reply to this message
Old 03-15-2016, 04:37 PM   #15 (permalink)
https://youtu.be/dVgV9SlbDac
YGE, www.yge.de
Old 01-09-2018, 08:24 PM   #16 (permalink)
Hello,
Thomas.
That's what I did with my trx250 now I'll just need to tweak the stock gains but I lowered I gain and d gain to 20% and it's almost perfect don't understand why but it happened after the new update with the extra satellite Edition
backshed904 is offline        Reply With Quote Quick reply to this message
Old 01-09-2018, 08:38 PM   #17 (permalink)
Originally Posted by Joeribar View Post
Hello
Turn D gain to 0
Turn I gain to 0
best regards Joeri
did you ever get your heli sorted out???
after the update to add the second satellite my servos went crazy they started working after downloading the quadcopter firmware then I erased it and reload it to Healy firmware after on and off a few times it finally started working but I had the wag of death and did everything until I lowered the I and D gain down to 20% has fixed it I still have a little bit of tweaking on the stock game do that tomorrow let me know if you fixed yours I might be able to help
